Old 04-21-2002, 01:47 PM   #1
core
[]D[][]V[][]D[][]\[]
core's Avatar
My Ride: 2003.5 E46 ///M3
Clutching
Sup all, question - Can I shift from any gear to neutral without using the clutch? does this do any damage to the transmission if done too much? or it doesnt do any harm ?
core is offline   Reply With Quote
Old 04-21-2002, 03:11 PM   #2
Karl
Engineer
My Ride: 2001 330xi
If you're accelerating or decelerating, the gears will be pushing against each other, making it hard to move the lever out of an in-gear position. However, if you blip the throttle just right, the lever will pop out of gear easily. This is the proper way to do it without using the clutch, otherwise you'll be using unnecessary force to pull it out of gear, and you could be wearing down the gear teeth at the same time.
Karl is offline   Reply With Quote
