Sponsored by The Tire Rack
Old 08-03-2004, 07:19 PM   #1
wingswest26
My Ride: 2003 330xi
Send a message via AIM to wingswest26
Tire Pressure
What are the optimal tire pressures for a 330xi with sports package (run flat tires). Would 35 PSI be alright on all four tires?
2003 Black 330xi w/ all options
wingswest26 is offline   Reply With Quote
Old 08-03-2004, 07:37 PM   #2
guest1016
fanatical
My Ride: .
Send a message via AIM to guest1016
just read the tag in your drivers side door jamb bro....
guest1016 is offline   Reply With Quote
Old 08-03-2004, 07:43 PM   #3
wingswest26
My Ride: 2003 330xi
30 to 35 front
35 to 42 rear
Old 08-04-2004, 07:32 PM   #4
guest1016
fanatical
My Ride: .
Originally Posted by wingswest26
30 to 35 front
35 to 42 rear
then 35 front would be on the high side and 35 rear would be on the low side, but they are both acceptible numbers, so most likely it would be ok. also check the load ratings, it you don't carry much cargo, the tire pressure can be dropped for example, but it should still be kept within that range. if it was me, (like i do on my own car) just split the two, maybe 33 front, 38 rear for example....
Old 08-04-2004, 07:46 PM   #5
HW323ci
My Ride: 323ci manual
would that be an understeer biased combo?
323ci manual / bbs rk / toyo t1-s 225/45ZR17
i'm bored as hell!
HW323ci is offline   Reply With Quote
