Sponsored by The Tire Rack
Old 08-04-2004, 11:15 PM   #1
smokin2000
Michelin Pilot Sport vs. Bridgestone S-03
I was wondering if anyone has used both these tires.
How do they compare to each other?
especially in tread life and handling.
smokin2000 is offline   Reply With Quote
Old 08-05-2004, 12:23 AM   #2
325 & 55
My Ride: 2001 325Ci Step
TireRack Comparison
Check out the many responses from purchasers of these two tires from the TireRack, should answer your question: http://www.tirerack.com/tires/survey...ay.jsp?type=MP
325 & 55 is offline   Reply With Quote
Old 08-05-2004, 09:34 AM   #3
Gary@Tirerack
Moderator
Gary@Tirerack's Avatar
My Ride: 1995 BMW M3
These two are feel nearly identicle when driven back to back in testing. If you're after the best of the best in Max performance, check out the newer Pilot Sport PS2, which was a slight step above even the S03 and older Pilot Sport.
http://www.tirerack.com/a.jsp?a=BN4&...ires/index.jsp
Refer to 'Gary/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by ordering through the sig link.
Click sig! -->
Gary@Tirerack is offline   Reply With Quote
Old 08-05-2004, 02:57 PM   #4
JordanM3
My Ride: 2003.5 M3 Coupe
Gary,
What about the Goodyear F1's? I live in Southern California, so I do not need to worry about snow, etc. Mainly concerned with noise, performance, and tread life. Considering the S-03's, PS2's, or the F-1's. I own a 2003 M3 with stock size 18's.
JordanM3 is offline   Reply With Quote
Old 08-05-2004, 03:07 PM   #5
djc986
My Ride: 330i ZHP
Originally Posted by JordanM3
Gary,
I have the F1 GS-D3 tires on my 04 ZHP. The tires are great. I replaced the OE Potenza RE040 with the F1's. These are much better. Steering response is better (more linear). Wet and dry grip is very good. Ride is good, not too firm and well damped. Noise is good.
djc986 is offline   Reply With Quote
Old 08-05-2004, 05:07 PM   #6
Gary@Tirerack
Moderator
Gary,
Very comparable to the S03 in nearly every catagory, just a notch below the PS2 in handling, but a slightly softer ride.
Click sig! -->
Old 08-05-2004, 06:46 PM   #7
hakjai
My Ride: 04' 330ci, 95' M3
with the prices of s03's and the discount on ps2's you cant go wrong with ps2s
04' Orient 330ci
95' Avus M3
03' (you guessed it...blue) R6
hakjai is offline   Reply With Quote
Old 08-06-2004, 09:00 AM   #8
MarkY
My Ride: 2001 330Ci
I've gotta give a to the PS2's. When my PS's wore out, I went with the PS2, on Gary's recommendation, and have been extremely happy. The tread design isn't as cool as on the PS, but the performance is noticeably better - and I thought the PS's were great.
2001 330Ci, GruppeM, BBS RS-GT
MarkY is offline   Reply With Quote
Old 08-06-2004, 09:27 AM   #9
e46fanaticperso
My Ride: car
ps2 is the go
e46fanaticperso is offline   Reply With Quote
Old 08-06-2004, 11:17 AM   #10
nzDave
My Ride: Darth Bimmer
Negative ghost rider, the pattern is full. I repeat, the pattern is full.
nzDave is offline   Reply With Quote
Old 08-06-2004, 01:23 PM   #11
330man
My Ride: Is sold
Send a message via AIM to 330man
How does TopGun play into this conversation????
At this point in the development of our society, there is virtually no writing which has not been plagiarized at least in part from another. I read that somewhere.
330man is offline   Reply With Quote
