Sponsored by The Tire Rack
Old 08-17-2004, 08:35 AM   #1
///ACS330Ci
Artist formerly k/a Steve
My Ride: ACS/M-Technik 330Ci
Send a message via ICQ to ///ACS330Ci Send a message via AIM to ///ACS330Ci
Track tire pressure question, Michelin vrs. Conti
Have any of you track guys switched from Conti's to Michelins and found you needed to make notable changes in your tire pressures?
I just replaced my Conti Contact 2's with Michelin Pilot Sport PS2 tires. I took them to the Nürburgring Nordschleife for the first time yesterday and they were sliding around quite a bit with the same pressures as what I used with the Conti's. Not snap and bite you kind of slides, but gradual four wheel drifts that seem to happen at lower corner speeds than the Conti's which I really didn't expect with the softer Michelins. The problem is they kept pushing me wide on my exits. The rubber didn't ball up as much as on the Conti's which is a good thing, but I need more mid-corner grip. Any thoughts?
  • Checkout Project HyperWorksMCS HERE
  • View My Other Automotive Project HERE
///ACS330Ci is offline   Reply With Quote
Old 08-19-2004, 10:24 AM   #2
///ACS330Ci
