Sponsored by The Tire Rack
Old 08-18-2004, 10:29 AM   #1
CynicalWry
Doesn't like PMs...Email me
CynicalWry's Avatar
My Ride: 00 323i-05 cbr600rr
Send a message via AIM to CynicalWry
Got a flat tire and can't get the right size...
I'm looking all over the place, and can't find the right size S03 tire (235/40/18). Both my rears (one w/ a flat) need to be replaced so I wanted to put two used tires on to get me through the rest of the season and then replace them all in the spring. Can I go w/ a stagered setup? Any suggestions? Right now I have 235 all around.
is your friend
Authorized Umnitza.com installer
301-825-5871
http://www.robinsNestChildCare.com - - - - - http://www.tntTint.net
CynicalWry is offline   Reply With Quote
Old 08-18-2004, 10:31 AM   #2
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
235/40R18 S03 in stock $215 each.
http://www.tirerack.com/a.jsp?a=BN4&...ires/index.jsp
We'll need to see your wheel width/offset to see if you can stagger.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 08-18-2004, 10:56 AM   #3
CynicalWry
CynicalWry's Avatar
I have hamann HM2 in 18x8.5 i believe.
Old 08-18-2004, 10:58 AM   #4
Rudy@Tirerack
Moderator
Unless the offset is pretty far off, should be ok to use 255/35R18 rear.
