Sponsored by The Tire Rack
Old 08-19-2004, 05:47 PM   #1
tnguyen24
My Ride: 525i
will these wheels fit a E46 M3 ???
my friend is wanting to buy 19x8 FRONT 19x9.5 REAR wheels off a 530 to put onto his E46 M3. will they fit without custom mods?
E46 M3 offets : 47mm in the front, 27mm in the rear. (iffy)
E39 530 offsets : 20mm all the way around
tnguyen24 is offline   Reply With Quote
Old 08-19-2004, 05:51 PM   #2
notE46
Where am I?
My Ride: M Coupe
it's not the offset the hub diameter is larger on the E39 i belive 74mm vs 72.5mm on the E46
it will not work
'87 325iS Sold but not forgotten.
'08 MINI Cooper S Mellow Yellow
'00 M Coupe Dakar Duck
'02 330ia
notE46 is offline   Reply With Quote
Old 08-19-2004, 06:02 PM   #3
tnguyen24
My Ride: 525i
not @ all? so theres NOTHING we can do to make it work?
Old 08-19-2004, 06:03 PM   #4
notE46
Where am I?
My Ride: M Coupe
how are you going to reduce the hub diameter to make it fit the E46 hub?
add more metal?
it' cant' be done safely at all, so NO.
'02 330ia
Old 08-19-2004, 07:01 PM   #5
machined
My Ride: E91
check and see if the hubs are interchangeable?
machined is offline   Reply With Quote
