Old 08-22-2004, 11:31 AM   #1
HiMiles
My Ride: 99 328i
RR PSS9 Popped Out....Pics Included
I was driving on Friday when I heard a loud pop and after that my car felt pretty unstable over bumps. Needless to say, my right rear PSS9 popped out (Pic#1 as opposed to left rear shock Pic#2.) THe bolt and the sleeve were still attached as you see in Pic#1 and Pic#3. I had to take the bushing out of the shock's lower end, then press the sleeve in all back together (Pic#4 & 5) I'm not sure if its because of the 19x10 that I have in the back is putting a lot of pressure but that's a first for me. I will attach a pic of the OEM sleeve that comes in the OEM shock, and it is T-shaped to prevent such thing. So I guess they've thought of that for a reason. Please let me know if you had this happen to you. Thanks
ID:	89531   Click image for larger version
ID:	89532   Click image for larger version
ID:	89533   Click image for larger version
HiMiles is offline   Reply With Quote
Old 08-22-2004, 11:36 AM   #2
HiMiles
My Ride: 99 328i
Pic of the OEM shock's lower end with T-Shape Sleeve
Here's the OEM one, and it is design to prevent the shoch from popping out.
Name:	OEM Rear Shock.jpg
Old 08-22-2004, 05:42 PM   #3
Ausfahrt
Groccery Getter
My Ride: Touring/550
Send a message via AIM to Ausfahrt
This was discused a long time ago. Anyways what you need to do is get a heavy duty WASHER from Home Depot or Lowes and then bolt the bolt over it. Make sure the washer is slightly larger than the bolt/rubber thing on the shock. Oh and paint the washer black or whatever color you like so it wont rust as easily.
Ausfahrt is offline   Reply With Quote
Old 08-26-2004, 06:46 AM   #4
shd
My Ride: classified
Bilstein is including big washers for more than 1.5 years now. Take a look at my post about this
http://forum.e46fanatics.com/showthread.php?t=56755
shd is offline   Reply With Quote
Old 08-26-2004, 12:02 PM   #5
BlueBimmer
My Ride: A4 Avant 2.0T
Yes this happened with my Bilstein sport shocks also. There's supposed to be a washer included with the kit to prevent this from happening. If you look at the install instructions, you'll see where they tell you to install the washer.
BlueBimmer is offline   Reply With Quote
Old 08-26-2004, 05:28 PM   #6
HiMiles
My Ride: 99 328i
Washer
Mine must have been the first generation. Do you think I can buy these washers seperately? Any idea? If Bilstein or their distributors don't sell these seperate, then I will check with Home depot. Thanks guys for the feedback. Much appreciated.
Old 08-27-2004, 04:31 AM   #7
shd
My Ride: classified
There is nothing special with these washers, just go buy them where you are able.
Old 08-27-2004, 11:59 AM   #8
Ausfahrt
Groccery Getter
Like SHD said they are nothing special. I bought mine at Home Depot and they work just as good if not better because of the thickness of the washers I bought. Dude your wasting your time if you have to wait for Bilstien to send them to you.
Old 08-27-2004, 12:53 PM   #9
VMW Racing
Past Site Sponsor
My Ride: 330i ZHP
hey
Does this only affect bilsteins?
Cavan
VMW Racing is offline   Reply With Quote
Old 08-27-2004, 09:22 PM   #10
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
My PSS9 kit did not come with washers but I had to go to Home Depot to buy some...
Old 08-27-2004, 11:07 PM   #11
Ci FLY
has 1 FLY Ci
My Ride: genato
same EXACT thing happened to me. one of my shocks popped out the other one was sliding off half way. the shock that completely came off, i had to take off and send to bilstien to install new bushings and a sleeve. the other side (pic attached) i used some wd-40 and a vice grip to put it back into place. bilstein sent me 2 washers for free, and i asked for spanner wrenches and they sent those for free too. all i had to pay for was shipping and for the bushing and the metal sleeve, a total of 9 dollars. the whole process took around 4 days
Ci FLY is offline   Reply With Quote
Old 03-17-2006, 09:19 PM   #12
LIV4SPDjr
My Ride: 2001 330ci
WOW I guess what happend to me too
[img=http://img111.imageshack.us/img111/2944/bals3bo.jpg]
LIV4SPDjr is offline   Reply With Quote
Old 03-17-2006, 09:21 PM   #13
LIV4SPDjr
My Ride: 2001 330ci
try this
[img=http://img111.imageshack.us/img111/2944/bals3bo.th.jpg]
Old 03-19-2006, 01:19 PM   #14
HiMiles
My Ride: 99 328i
PSS9s
Originally Posted by LIV4SPDjr
Just get the washers from Home Depot. They are a buck each. I have no issues anymore. It takes 20 minutes to add the washer (when it's not popped) and about 2 hours if it is (since I had to make my own designed tool to push it back in.) Good luck.
M
Old 04-03-2006, 11:29 AM   #15
Surk
My Ride: C Blk E46///M3
I used my old RSM top washers inverted towards shock body
Surk is offline   Reply With Quote
Old 05-03-2006, 11:23 PM   #16
guest081516
Banned User
My Ride: N/A
What tool or rig do you guys use to press the bushing into the shock.. my OEM one popped off and I just want to press it and add a washer....
guest081516 is offline   Reply With Quote
Old 08-13-2006, 12:04 AM   #17
BlackChrome
No more E46 :(
BlackChrome's Avatar
My Ride: 2001 3.0L Ci
This happened to me today, too!
BlackChrome is offline   Reply With Quote
Old 04-29-2010, 01:43 PM   #18
C4RLOS
My Ride: 2003 325Ci
I've had Bilstein PSS's in my 325 for a year and a half. A few days ago... heard a loud pop from the rear passenger side and I noticed my shock popped out of place as well... Any better solutions than the ones already discussed?
FOR SALE: pre-facelift sideskirts and front and rear bumpers | 19" hyperblack VMR V715 wheels (in sig)
C4RLOS is offline   Reply With Quote
Old 04-29-2010, 02:47 PM   #19
zugellos
My Ride: '02 330i
Common sense would have kept these things from popping out in the first place.
Use of washers is the only fix you need.
zugellos is offline   Reply With Quote
Old 05-02-2010, 05:34 PM   #20
C4RLOS
My Ride: 2003 325Ci
Any idea how to take out the rear shocks? Like I said, same thing happened to me. I took the bolt off to install a washer between it and the shock ring, but the sleeve came out so now I have to press that back in. I didn't do the installation myself so I'm not really sure how to pull the shock out. I got to the nut in the trunk, but I seem to turn it with the socket, yet it doesn't appear to loosen up. Any help? Sorry, I'm a noob when it comes to all this. I've had my car at school, so I haven't really driven/worked on it much in a long time.
