Old 08-27-2004, 08:13 AM   #1
trdehmer
My Ride: 2000 328i
How to replace front turn signal bulb? 00 328i
Looks like the drivers side turn signal bulb burnt out (I hope thats it compared to an electrical issue). I took a quick peek before work to see how easy it would be to replace. Doesn't look so easy - so, I do I replace it? What needs to be removed to get at the bulb and what kind of bulb is it?
trdehmer is offline   Reply With Quote
Old 08-27-2004, 08:37 AM   #2
cgrizzly888
My Ride: 00 328i
Send a message via AIM to cgrizzly888
Read the owner's manual. You need a screwdriver to release the corner light, very simple.
cgrizzly888 is offline   Reply With Quote
Old 08-27-2004, 08:49 AM   #3
Alex
Mom says I'm a catch
Alex's Avatar
My Ride: E46
Send a message via MSN to Alex
.........all you need is a thing, long screwdriver to push down on a lever (use a flashlight to see where you're pushing) and at the same time, pull the corner light to release.
Alex
A lap dance is so much better if the stripper is crying.
Alex is offline   Reply With Quote
Old 08-27-2004, 08:53 AM   #4
trdehmer
My Ride: 2000 328i
Any idea what type of bulb I need to get? Figured I stop at Champion auto on the way home to get the bulb......
Old 08-27-2004, 09:00 AM   #5
Alex
Alex's Avatar
My Ride: E46
I don't think they have it at Champion, you need a 2-pin bulb, I believe it's an 1156 or 1157 bulb
Alex
Old 08-27-2004, 09:01 AM   #6
acitydweller
My Ride: e46 M3
champion should be able to look up the bulb type for your car. Alternatively you can check www.sylvania.com under the automotive lighting application section for the details.
acitydweller is offline   Reply With Quote
Old 08-28-2004, 01:35 AM   #7
HamannGirLR714
My Ride: e92 Sparkling Graph.
Send a message via AIM to HamannGirLR714
1156 bulb use nail filer to file down on side or its a 7506 bulb exact fit. theres a hole right on top of corner lense when u pop hood. use flathead to push down to release then pull a little on lense while doing so to come out.
HamannGirLR714 is offline   Reply With Quote
Old 11-17-2004, 12:43 AM   #8
scoliosis
My Ride: 2000 323i
Sylvania says to use 7528 as bulb replacement. It has 2 positive contacts and 2 filaments. This is the WRONG replacement bulb. Took the bulb out of my car and it only has 1 positive contact and 1 filament. I'll check 7506 next and see if it'll fit. Thanks.
scoliosis is offline   Reply With Quote
Old 11-18-2004, 12:15 AM   #9
scoliosis
My Ride: 2000 323i
7506 is the correct bulb type. Just replaced mine and it's all ok now.
Old 11-18-2004, 12:28 AM   #10
BMW330xi01
My Ride: 98 Skyline
if its a turn signal then its 1156 front and rear turn signals, reverse and OUTSIDE bulb set on the tails its a 75XX on the inside set on the tails
NO LONGER INSTALLING IN CONNECTICUT. I AM LOCATED IN JAPAN NOW
LUIS ESCOBAR
L.EscobarJr@yahoo.com
INSTALL PHOTOS
BMW330xi01 is offline   Reply With Quote
Old 09-30-2012, 07:35 PM   #11
Lysander
My Ride: 2000 328i
Exclamation Replacing Turn Signal Bulb
After 8 yrs ownership of a 328i I have to say that this site and others is the source of as much misinformation as helpful information. First of all, you do NOT push down on anything to release the lens and the owners manual is basically useless, as it simply says "release the lever" but doesn't tell you how.
Looking through the oval hole, the first thing you'll see is a black flat piece of plastic. Do NOT push down on this or the silver-colored prong sticking out from it. Look a bit deeper and you'll notice a white tab, no more than 3" deep, so
you don't (as some claim) need a long screwdriver and a straight edge is no more helpful than a Phillips as you just need to get the screwdriver behind the tab and push it away from you, thus causing the end of the screwdriver to
push the lens out. It doesn't take a lot of force, so if it's not budging, you're behind the wrong tab. After it pops out, simply turn the receptacle and then the bulb to replace it. To reinstall, line up the prongs into the slots and push in until it clicks. (With all due respect, if you're giving advice, first be sure that it's correct).
Lysander is offline   Reply With Quote
Old 09-30-2012, 08:52 PM   #12
pablofe
My Ride: BMW 323ci
Many thanks for this note. Was not having any success pushing down on the other two "tabs", and yours was the only helpful post I could find out there.
Many thanks!
-Pablo
pablofe is offline   Reply With Quote
Old 10-01-2012, 12:38 PM   #13
John in VA
My Ride: '00 Farngrün 328i
Looking through the oval hole, the first thing you'll see is a black flat piece of plastic. Do NOT push down on this or the silver-colored prong sticking out from it...
I beg to differ. Perhaps you have aftermarket turn signals, but for my stock units on an unmolested 10/99-production 328i it is necessary to put downward pressure on the plastic tang to release the unit. It clicks/locks into place when reinstalled.
John in VA
'03 530i
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 10-02-2012, 08:39 AM   #14
Lysander
My Ride: 2000 328i
Mine is also late '99 with original lenses, so it seems that there was
at least two versions. A great example why it's so important to qualify
statements with "your's may be different..."
