Old 08-30-2004, 01:24 AM   #1
asiangear
My Ride: 323 2000 Ci
Gas Pump stops when tank is not full
I notice sometimes when I fill up at my local Chevron, the gas pump will stop when the tank is not even near full. For instance it would stop at 5 gal from filling a near empty tank. Somtimes it stops around 12 gal. This doesn't happen all the time and I used different pumps each time to make sure that it wasn't a faulty pump. Any clues to this mystery?
USC Internet: We are the 1%, in lightning-fast porn download (Brazzers at the speed of light)
asiangear is offline   Reply With Quote
Old 08-30-2004, 01:33 AM   #2
iastute
My Ride: 03 E46 M-sport
May have something to do with how much pressure the pump exerts as it fills your tank. Do you press the pump trigger fully (highest pressure)?
These things have an auto shut-off feature that gets triggered even when the tank is not full yet. Happens to me often that even if the fuel sloshes around in the filler tube (or pipe), the pump stops. I found out then after this instant, pressing the pump trigger lightly will resume the filling...sometimes for a lenghty period before the tank is filled. You can eventually fill your tank to the brim.
iastute is offline   Reply With Quote
Old 08-30-2004, 01:46 AM   #3
asiangear
Thanks for the tip. I'll give that a shot next time.
Old 08-30-2004, 11:34 AM   #4
4open
My Ride: 04 330i performance
air pocket
Hey. it's an air pocket problem....I think all BMW's have that problem at the pump. The rubber sleeve that covers the pump neck will build up an air pocket cause the sleeve doesn't fully cover the gas nozzle, so it sets off the sensor on the pump to stop sending fuel through. I don't know of anything that can be done about that, just have to make sure the pump is inserted all the way into the nozzle.
-Ohan (4open)
4open is offline   Reply With Quote
Old 08-30-2004, 03:23 PM   #5
Soundwave
My Ride: 330i M Performance
I had a similar problem when I filled up my car as well. My car would only take 0.5 litres before kicking off each time when I know my tank was 1/4 tank empty. (Trying to top up when the gas went down in price) I tried lifting the nozzle a little out, I tried moving that rubber flap that is on the nozzle to let air in, I tried various amounts of pressure in squeezing the trigger all with no success.
I found that if I let the tank go down to half full, I could fill it up another 1/4 tank. After a while of driving and repeating the half tank fill for a few more times, my car finally allows me to fill up the tank. Don't know why this worked for me.
Soundwave is offline   Reply With Quote
Old 08-30-2004, 04:14 PM   #6
Tenchi
Just a Brand-wh0re Elitist
Tenchi's Avatar
My Ride: 330i, 535i
Send a message via AIM to Tenchi
not my car but then again, i dont shove the nozzle all the way in
Stay away from FedEx if you want your packages delivered in one piece.
Tenchi is offline   Reply With Quote
Old 08-30-2004, 04:21 PM   #7
Bimmerista
My Ride: God's Chariot
I've never had this problem
Bimmerista is offline   Reply With Quote
Old 08-30-2004, 04:44 PM   #8
deletedpenguin
deletedpenguin's Avatar
My Ride: is gone!
I had this issue just the other day. Again.
...so far though, it's only at Shell stations.
Stefan | American by birth, Swedish by heritage, Australian by choice.
My current photo galleries.
deletedpenguin is offline   Reply With Quote
