Old 08-30-2004, 11:21 PM   #1
drdl
My Ride: 2003 330i
Are Dealers Obligated to Fix All TSB Issues?
Hi Guys,
I was looling around the internet and found a website that list a bunch of Technical Service Bulletins for different manufactureres. I have a March production 2003 330i and they list the following TSBs:
Safety Recalls
TSB Number Issue Date TSB Title
000403 MAR 03 Recall - Vermont State Mercury Warning Label
General Recalls
110703 MAR 04 Campaign - Engine Low Oil Level Warning
840104 FEB 04 Campaign - Telematics Control Unit Inspect/Replace
841803 FEB 04 Campaign - BMW Assist Inoperative
611103 JAN 04 Campaign - A/C/Lamp Control Module Reprogramming
841803 NOV 03 Campaign - 'BMW Assist' Inoperative
121102 DEC 02 Campaign - Starter Motor Replacement
120802 OCT 02 Campaign - Engine Wiring Harness Replacement
Service Bulletins
240703 MAY 04 A/T - GM5 Delayed Cold Start PARK to REVERSE Engagement
090398 APR 04 Car & Key Memory - Programming/Coding Explanations
120803 APR 04 Ignition System - Rough Running/MIL ON/Misfire DTC's
650104 APR 04 Radio - Reception Problems, Antenna Diagnosis
6420104 FEB 04 A/C - IHKA Causes Dead Battery/See Campaign 611103
510303 FEB 04 Body - Intermittent Exterior Mirror Failure
1120104 FEB 04 Engine - Cylinder Head Oil Leaks
1120204 FEB 04 Engine - Head Bolt Threads Pull Out of Block
240703 FEB 04 A/T - GM5 Delayed 'P' to 'D' Cold Engagement
6320004 JAN 04 Lighting - Switches OFF Late
110803 DEC 03 Engine - Cold Weather Valve Cover/Engine Damage
6320103 NOV 03 Lighting - Front Turn Signal Lamp Is Loose
6120403 NOV 03 Electrical - Battery Charger Sets Fault Codes
6620003 OCT 03 Keyless Entry - Remote Won't Lock/Unlock Vehicle
651403 OCT 03 Navigation System - Board Monitor Lamp Stays ON
840102 OCT 03 Navigation System - Erratic Performance
3320003 SEP 03 Suspension - Clunking Noise Over Bumps
121002 AUG 03 Engine Controls - MIL ON/EDK Throttle Faults Stored
841302 JUN 03 Cellular Phone - Discharges Vehicle Battery
110403 JUN 03 Engine - Mechanical Drive Belt Tensioner Noise
120603 JUN 03 Engine Controls/Emissions - OBD Readiness Code Setting
841402 JUN 03 Navigation System - Start-Up Delay in Cold Temperatures
640502 MAR 03 A/C - IHKA Blows Too Hot In Below Freezing Temperatures
651003 MAR 03 Audio System - Poor FM Band Reception
360103 MAR 03 Tires - Directional Tires, Mounting Precaution
840303 JAN 03 Navigation System - MK3, Difficulty Coding
840203 JAN 03 Navigation System - Volume Too Loud/Not Loud Enough
Are the dealers obligated to check my car for all issues and fix whatever is wrong with my car according to this list?
Thanks.
drdl is offline   Reply With Quote
Old 08-30-2004, 11:24 PM   #2
DrMooCow
My Ride: 335d
Send a message via AIM to DrMooCow
From what I understand from tsb's, only if you are able to duplicate the problem, then the dealer has to fix it. If you can't duplicate the problem, then they'll just blow you off.
DrMooCow is offline   Reply With Quote
Old 08-30-2004, 11:46 PM   #3
cgrizzly888
My Ride: 00 328i
Send a message via AIM to cgrizzly888
Exactly, they must be able to replicate the problem.
cgrizzly888 is offline   Reply With Quote
Old 08-31-2004, 10:08 AM   #4
richbmw323
My Ride: 2000 323ia SC'd
it also depends on the build date and VIN #
That Info is from where? ALLDATA.COM?
That is a good site but does not provide all the info.
OLD CAR - 2000 323ia Kompressor
2000 Sebring Silver Metallic Coupe C5 Corvette
richbmw323 is offline   Reply With Quote
Old 08-31-2004, 10:13 AM   #5
acitydweller
My Ride: e46 M3
you have to replicate the problem.
i was told they werent going to rebuild every M3 that was brought in just because the internet says there was a service bulletin... is that the customer service one gets with a premium grade car?
Laguna Seca Blue E46 M3
acitydweller is offline   Reply With Quote
Old 08-31-2004, 10:54 AM   #6
Tenchi
Just a Brand-wh0re Elitist
Tenchi's Avatar
My Ride: 330i, 535i
Send a message via AIM to Tenchi
Yes.....no?
Stay away from FedEx if you want your packages delivered in one piece.
Tenchi is offline   Reply With Quote
Old 08-31-2004, 01:12 PM   #7
marcio
My Ride: Mazda Miata
The above is the list that your dealer need to check for your car. And if you don't have Assist, then there are only two items: the first and the 4th item.
TSBs are just technical notes for the service people explaining how to fix a problem. It doesn't mean your car has a problem or might have a problem. If your car has the specified problem, the TSB shows the techs how to fix it.
A recall on the other hand indicates a potential problem, so it needs to be checked by the dealer, regardless if the car shows the problem or not. BMW, for marketing purposes, decided to bundle recalls with TSBs, so it gets a bit confusing, but the list you gave separates them, and I'm assuming they separated the recalls correctly. Recalls issued before the production date of your car are generally not relevant. Recalls for items you don't have in your car, like Assist, are not relevant either. And some recalls are only for some specific VINs. In short, assuming you don't have Assist, there are at most two items that your dealer has to check. Five if you have Assist.
marcio is offline   Reply With Quote
