Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 09-15-2004, 10:24 AM   #1
02BMW330ci
My Ride: Z4M, 335i, 135i
Send a message via AIM to 02BMW330ci
Exclamation First the Diff mount, Now the Subframe. **Pics**
Well, I have already had a broken diff mount. Which I had taken care of. But i have over looked a serious issue. Sub frame is now tearing near the Wheel well under the car. This car has never been in an accident before and theres no way a sub frame is a wear and tear item. But its giving now.
Anyone with a 3, I would recommend you go out and look VERY carefully under the whole rear of the car and check for subframe tears. I just noticed mine after checking if my diff mount is holding up.
Something needs to be done about this. I will start a patition thread against BMW. For those of us who are out of warranty we will not spend thousands on repairs. BMW has to take action. If you can not have this problem fixxed i strongly suggest selling your car before it becomes a larger issue for you and ends up costing you an arm and a leg to fix.
ID:	92257   Click image for larger version
02BMW330ci is offline   Reply With Quote
Old 09-15-2004, 10:28 AM   #2
CtrlAltDel
www.piratecove.org
My Ride: 2007 335i Coupe
Send a message via ICQ to CtrlAltDel Send a message via AIM to CtrlAltDel
wow
good luck man
Yeah I havent updated my sig yet with my 335, kill me.
CtrlAltDel is offline   Reply With Quote
Old 09-15-2004, 10:29 AM   #3
gig
My Ride: 2000 328i
Man that sucks big time. I'm gonna go check mine now as you've got me sufficiently worried. It'd be good to start a petition just in case.
gig is offline   Reply With Quote
Old 09-15-2004, 10:57 AM   #4
02BMW330ci
i started a patition post, sign there if you have this problem.
Old 09-15-2004, 11:05 AM   #5
Cuore_alfa
alfisti & bimmer fan
My Ride: 01 Toyota Corolla CE
Send a message via MSN to Cuore_alfa
hummm, do a search someone collect a list a few months ago.
this start whit the 323/328 99-00, now is affecting the 325/330 01 and a few M3s..
8C Competizione
Cuore_alfa is offline   Reply With Quote
Old 09-15-2004, 12:04 PM   #6
02BMW330ci
my cars an 02
Old 09-15-2004, 12:15 PM   #7
BattleWagon
My Ride: Colnago CT-1
What are the non-visual symptoms...clunking noises in the rear, vibrations, bad handling in corners? Thanks,
BattleWagon is offline   Reply With Quote
Old 09-15-2004, 12:17 PM   #8
02BMW330ci
Sounds of metal rubbing agaisnt each other, sounds kinda like twisting metal. Vibrations, loose feel when cornering. The obvious stuff..
Old 09-15-2004, 03:00 PM   #9
sycE46
My Ride: 323ci
Is your car still under warranty? BMW should fix it.
sycE46 is offline   Reply With Quote
Old 09-15-2004, 05:20 PM   #10
PS323CI
My Ride: 2000 323CI
I Once Took Mine In For Cpo Warranty And Told Me '' Hit Object On Highway''. Wtf!! I Never Ran Any Type Of Debris On The Highway. Ne Ways I Got An Estimate For $3800.oo At Local Body Shop.
AIM:PATSE46
PS323CI is offline   Reply With Quote
Old 09-15-2004, 05:25 PM   #11
02BMW330ci
ouch...
and no my car is not under warranty any more..
Old 09-15-2004, 05:25 PM   #12
Jeff43
next mod: recaro child seat
My Ride: smells like surf wax
Sorry to see you going through this, Art...
take a look at this thread from a few months ago...
http://forum.e46fanatics.com/showthr...light=subframe
interesting how BMW Germany is recognizing it, but BMW USA is turning a blind eye....
Jeff43 is offline   Reply With Quote
Old 11-09-2004, 11:50 PM   #13
BLK BLUR
My Ride: Hpf m3,360,R8,M4
how the **** does something like this happen to a 60 thousand dollar car
BLK BLUR is offline   Reply With Quote
Old 12-19-2005, 11:50 AM   #14
gcwaterski
My Ride: 997.need i say more?
Is there any measure you can take to prevent this from happening?
gcwaterski is offline   Reply With Quote
Old 12-19-2005, 12:06 PM   #15
AndrewE46
My Ride: 325
AndrewE46 is offline   Reply With Quote
Old 12-19-2005, 01:10 PM   #16
vert
My Ride: MINI Cooper Hatch
Send a message via AIM to vert
Can someone describe exactly where i should be looking for this sort of problems? I've seen it in pictures, but it's hard to tell what is that actually a picture off. Do i have to take the wheel off etc. I have ramps so i can put the rear end of the car on that. Thanks.
vert is offline   Reply With Quote
Old 12-19-2005, 01:37 PM   #17
crumpet
My Ride: burned down
Send a message via AIM to crumpet
yes, get a subframe re-inforcement kit.
crumpet is offline   Reply With Quote
Old 05-06-2007, 08:02 PM   #18
JUANCHI29
My Ride: 2000 323CI
my subframe just went on me should i keep driving my car liek that until i fix it?
JUANCHI29 is offline   Reply With Quote
Old 05-06-2007, 08:27 PM   #19
MysticBlau330Ci
My Ride: 330Ci '04 & M4 2016
NO, once it tears it has lost a HUGH amount of it's structural integrity and can progress RAPIDLY and unpredictably. You have no real idea how fast it will spread or when it will "give". The suspension components need a strong support base to work properly. The car's handling can become unpredictable quickly. If it happens to "give" while you are comming down a fast reducing radius corner and a semi is traveling in the opposite direction.......well that's kind of a worse case but you get the drift.....no pun intended
MysticBlau330Ci is offline   Reply With Quote
Old 05-06-2007, 08:30 PM   #20
BartenderPlease
My Ride: '03 540i/6 M-Sport
I'm glad you searched for the issue you are having instead of creating a thread on it.
Don't drive it unless you can't help it.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
