Sponsored by BAVSOUND
Old 09-24-2004, 05:05 PM   #21
randomtask976
My Ride: C5 Z06 330i
properly matched (gain),
with no overdriving
no x-over or EQ
puere amplification
in 1 volt out 2volts
you can put a pyramid amp against any "SQ" car amp, and you will not be able to tell them apart, and if you think you can.... there is a guy that will give you $10K on the spot
randomtask976 is offline   Reply With Quote
Old 09-24-2004, 05:20 PM   #22
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
with no overdriving
no x-over or EQ
puere amplification
Yes, but my US Amps will run a lot longer than a Pyramid Amp with the same output, that's the difference. There is an audible difference when an amp reaches its thermal limits. Heat makes things all weird. Heat and vibration are the two environmental factors that kill amps.
My US Amps will be operational long after the Pyramid dies...that's the difference.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 09-24-2004, 05:43 PM   #23
randomtask976
build quality and longevity was never an issue,
sure some amps are built better than others, but this discussion was about sound quality not lifespan
Old 09-24-2004, 11:06 PM   #24
Ron@Streeteffectz
OK, so you're saying if you put 3 different amps on the same set of speakers you wouldn't be able to tell a difference???
Ron@Streeteffectz is offline   Reply With Quote
Old 09-25-2004, 10:47 AM   #25
bigjae1976
bigjae1976's Avatar
I don't agree withthe theory that all amps sound the same...they don't. I think upgrading your amp can be one of the most dramatic improvements you can make. Right now, I have a RF Power 551s running my fronts. I plan to get a US Amps 150x2 amp. Similar power but I expect the US Amps to sound better than my RF amp when its 100 degrees outside and the volume has been turned up for awhile. I don't expect to hear a difference at low volume level.
The difference is the build of the amp and its potential. At high volume, an overbuilt amp will not only last longer and play longer, it will still be able to accurately reproduce dynamic music passages without clipping. Pyramid amps can't.
Old 09-29-2004, 05:00 PM   #26
randomtask976
properly matched, with no clippping, not likely, by ear of course, if you use an O-scope, of course you can plot a difference,
a watt is a watt in any amp, same as a HP is HP in any car
