Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 09-26-2004, 07:56 PM   #1
nleeumd
My Ride: BMW 330Ci
Send a message via AIM to nleeumd
Headunit Install Wiring Harness
I have a 330Ci with HK, can i juse use a wiring harness and plug in my new HU, do or I need to reroute and avoid using the stock HK amp all together. Any help would be appreciated.
'01 BMW 330Ci | PP/CWP/SP/XE/KVT-915DVD | M3 Lip Spoiler | M3 Strut Bar | Jim Conforti Intake | UUC Sway Bars | Philips Ultinon 6000k HID Upgrade | Philips Ultinon 6000k HID Foglights | JL Audio Stealth Box | Clears All Around | 18" ASA AR1's |
nleeumd is offline   Reply With Quote
Old 09-27-2004, 08:30 AM   #2
ca1242
My Ride: 2003 330i
You could do it that way. Depending on the output on the head unit you are using, your results might vary. To do it right, you need an adaptor.
Old 09-27-2004, 08:45 AM   #3
nleeumd
My Ride: BMW 330Ci
what type of adapter?
I want at least the same sound quality as my current setup. I am looking to install the KVT-915DVD but I am hearing mixed things about running through the stock HK amp and double amping, and introducing distortion.
Old 09-27-2004, 08:48 AM   #4
04E46
My Ride: 04 M3
Double amping is usually not good. The HK has a variable input so it will accomodate.
I tried it and didnt like it. I ripped everything out and ran new everything.
Now I am happy.
Try it. If you like it - good, if not then you can try something else.
2004 Titanium M3 6 Speed.
04E46 is offline   Reply With Quote
Old 09-27-2004, 08:52 AM   #5
ca1242
My Ride: 2003 330i
If you want better sound quality, your approach might not be the best one. By only upgrading the head unit, at best, you will have the same quality as with the factory head unit. You will not get better sound quality or more power than what you already have.
You might want to consider either upgrading the whole thing, or replacing amps/speakers with aftermarket.
Old 09-27-2004, 09:06 AM   #6
nleeumd
My Ride: BMW 330Ci
yeah
I am not looking for specially better sound, I am content for the sound quality now, I just don't want it degraded. If I bypass the HK amp, don't I need new speakers too since the HK uses different ohms?
Old 09-27-2004, 09:12 AM   #7
ca1242
My Ride: 2003 330i
They did not make it easy to upgrade. You could use the facroty speakers and bypass the amplifiers, but you need to either build custom crossovers for the speakers or have a channel of amplification for each speaker and use amplifiers with built-in crossovers, which is a very expensive option.
What are you trying to improve? You want more bass, louder stereo, more features (i.e. xm radio, mp3 player)?
Old 09-27-2004, 09:17 AM   #8
nleeumd
My Ride: BMW 330Ci
More features
I am just looking to install an indash monitor so i can have the ablity to view my mp3 collection, the KVT-915dvd. I am happy with the sound quality now.
