From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast
Old 09-27-2004, 02:14 PM   #1
David328Ci
Wohnhafter perverser Mensch
My Ride: Pimpin '99 Sentra X(
Send a message via AIM to David328Ci
Help me adjust my KW coilovers for better handling.
I have KW coilovers and for some reason it seems that they don't handle as well as the springs only suspension that I had on my old car. The dampening is set at factory set medium on front and rear. Also, the tire pressure is set at 40/38 psi. What do you guys recommend?
David328Ci is offline   Reply With Quote
Old 09-27-2004, 11:01 PM   #2
MrMotorwerk
Der Meisterstück
MrMotorwerk's Avatar
My Ride: '02 330Ci,'01 M3,M4
Are you trying to minimize the bouncing?
Instead of going by medium or soft or hard setting on your shocks, you should set the rebound of the shocks to minimize the bounce. When the car bounces, it means the rebound isnt setup to work with the springs.
Mr.Motorwerk
MrMotorwerk is offline   Reply With Quote
Old 09-28-2004, 09:35 AM   #3
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
Dave, is yours V3 or V2?
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 10-03-2004, 03:21 AM   #4
David328Ci
V2
Old 10-04-2004, 12:26 PM   #5
Mr Paddle.Shift
My Ride: B3 epsilon
Before I post a load of physics, when you mentioned "they don't handle as well", can you elaborate on that? Does it happen during high or low speed cornering? Fast or slow bumps etc?
Track blog.
Old 10-08-2004, 04:57 PM   #6
David328Ci
Through corners it just doesn't seem to grip as well has 328 did.
