Cornering problem - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-28-2004, 01:28 AM   #1
_TomDoe_
My Ride: e46 touring
Cornering problem
I have 2 Q and hope you quys can help:
1.A month ago I mounted a new M suspension and M-135(all from a new 330i Clubsport ) and after a week I started notice problems when doing a right corner. The car sways more and when going fast(not much) the car is going up and down in a vertical way ( like the wheel is losing and geting grip, but not like ASC ). Since the suspension is new and so are the swaybars and the alligment is OK I dont know what to do. Is it possible that a bushing of the swaybar is broken? Also when I drive slow on a bad road the rear is swaying...
Problem 2:
Also I noticed that the front wheels are ( when slow parking in reverse or at driving uphill-at the top of it ) having like a small "losing"-like real small right-left losing. Maybe just because I changed the original 15-inch to M-135 and all is more direct or i could be the "bumerang"or what ?
Thanks in advance
_TomDoe_ is offline   Reply With Quote
Old 09-28-2004, 02:33 AM   #2
Commander FAT
Network Analyst
My Ride: 2002 330Ci
For #1: You did get a new alignment done, right?
For #2: Please explain again, I'm not sure what you mean.
Because the B isn't for bling.
Commander FAT is offline   Reply With Quote
Old 09-28-2004, 02:57 AM   #3
_TomDoe_
1.Yes i did, and it was like ok for a week, then it started.
2. Ok , i will try: you ride uphill and when you arrive at the top the front wheels are for a moment like "bobleing" right and left ( mind that the steer. wheel is not moving, but you can feel wheels like moving )... sorry, but its hard to explaine in english..
Old 09-28-2004, 07:32 AM   #4
mfino
I give up.........
My Ride: 00 323i SP-P blk/blk
Is it that you feel like the wheels are moving or do you actually hear noises, maybe like some clunking coming from the front? I would check the sway links first. Make sure they are torqued correctly. The shifting or having some play could be control arm issues... Sorry... I hope some of this information helps.
ECIS Intake | Shark Injector | Scorpion Exhaust | PG2 style rims, YOKOHAMA AVS ES100 235/40/18 | M3 Lip Spoiler | OEM Clears | Hamann Eyelids | M-Technik Front | M-Technik Sides | M-Aero Rear | 50% Tint | M3 Dead Pedal | MOMO Aluminum Pedals | UUC Gauges |Titanium Shadow Painted Trim
mfino is offline   Reply With Quote
Old 09-28-2004, 07:39 AM   #5
_TomDoe_
No noises, just a slight felling on the steering wheel like something is loose. What you think with torqued corectly ? ... btw. thanks for help.
Old 09-28-2004, 07:45 AM   #6
mfino
I give up.........
Well, with all the different changes you made, this is going to be a tough one to figure out. What size are the M-135 wheels? 17, 18? Jumping up that much from a 15" wheel will make the car perform very different. You are going to experience more tramlining, as you have a bigger contact patch on the road, so the tires will follow the imperfections on the road. Have you balanced your tires, or at least try and rotate them? This is a stupid question, but are you sure your lug nuts are torqued correctly?
Old 09-28-2004, 08:00 AM   #7
_TomDoe_
18 (225 front, 255 rear). You think that the nuts are loose?-that will be too easy for a solution ( Murphy ) anyway i will check..
Its the second problem that puzzles me most /since is the danger one /...i know:go visit local BMW...the problem is that they charge like a PRO and that the knowledge they posses is rather, khmmm, lacking to say the least.
