Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 09-29-2004, 12:07 AM   #1
///NYCM3
My Ride: 2001 TiAg M3
Send a message via AIM to ///NYCM3
amps under rear deck
anyone have any pics or info on mounting the amps under the rear deck. I wash thinking of putting them on a folding hinge so i can adjust the settings easily. I am just worried that they wont cool properly upside down.
///NYCM3 is offline   Reply With Quote
Old 09-29-2004, 07:01 AM   #2
PLAZAMAN
My Ride: FourPointEightEyeS
im gonna do the same thing. But im also gonna use a fan to help cool.
PLAZAMAN is offline   Reply With Quote
Old 09-29-2004, 08:34 AM   #3
low
OG e46fanatics lurker!
My Ride: is outside
thats the way mine is mounted
Pretty girls in bikinis...
Originally Posted by kwang1
no one ask you to click on it cry baby :cry: now I can see why Dougsun doesn't like you either.... sigh....
- I've been victimized with BOARD DRAMA!!! :lmao:
low is offline   Reply With Quote
Old 09-29-2004, 08:47 AM   #4
PLAZAMAN
Pics?
Old 09-29-2004, 10:13 AM   #5
low
My Ride: is outside
my amp isnt in right now...im waiting for it to come back. im bugging my installer for them..i'll post as soon as i get them.
Old 09-29-2004, 12:09 PM   #6
rcurley55
My Ride: 2001 IR M3 Coupe
this is not the recommended way for an amplifier to be mounted - while it may work, no mfg would recommend it, you are working against the design of the heat sink when you mount an amp upside down.
I'm not saying it will fail, but it certainly isn't good for the amp.
Life's too short not to be M-Powered
rcurley55 is offline   Reply With Quote
Old 09-29-2004, 12:18 PM   #7
PLAZAMAN
Even with a fan?
Old 09-29-2004, 12:46 PM   #8
dan4081
My Ride: 2000 323i
I had a fan cooled Kicker 800a4 mounted upside down under my rear deck. I loved having it out of the way, hidden but easy to get to. It lasted a little over a year before it stopped working. I brought it to a local electronics shop, and was told it died because of heat build up. I had thought the fan would keep that from happening, but it didnt.
I do believe that it would have been fine if I had built a shelf under the rear deck and mounted it right side up. Like NYCM3 said, maybe a hinged shelf so you can get to it easier is the way to go.
dan4081 is offline   Reply With Quote
Old 09-29-2004, 01:33 PM   #9
low
My Ride: is outside
mine isnt mounted upside down
Old 09-29-2004, 01:39 PM   #10
ca1242
My Ride: 2003 330i
It is not a good idea to mount an amp upside down. Can you get away with it? sure. You are just stressing the amp a bit more than normal, possibly reducing it's life span.
A good way to approach mounting amps under the deck is to build a "shelf". YOu could put hinges on the rear part of the shelf and supports in the front pat.
Old 09-29-2004, 01:41 PM   #11
ca1242
My Ride: 2003 330i
... Also, if you do decide to mount the amp upside down, mount it to a board and not directly to metal. A lot of times, it causes noise problems.
Old 09-29-2004, 03:12 PM   #12
phildo
My Ride: '02 M3, '90 325i
bluecougar has her amps mounted under the rear deck. looks good imo.
phildo is offline   Reply With Quote
