What color is Antenna Amp wire lead? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Old 09-29-2004, 08:52 AM   #1
ttgolf
My Ride: 2004 M3 Convertible
Trying to install a new system in my 2004 M3 convertible. The radio wire harness diagram I got does not have the Antenna Amp wire lead. I am sure the car has a antenna amp which needs to remote ON. Can someone help me? Does my car require remote ON for Antenna Amp from the radio or is it always on since the Antenna Amp also works with phone and BMW Assist connection?
here is the wiring pinout I got?
Radio Connector --
1 - yellow/red left front +
2 - blue red right front +
3 - yellow/black left rear +
4 - black (not used)
5 - violet/white 12 volt switched (HU power line)
6 - blue/black right rear +
7 - white / red Not Used
8 - brown/orange left front -
9 - red/green + terminal battery connection
10 - white Not Used
11 - brown/orange right front -
12 - brown/orange left rear -
13 - grey/red illumination
14 - brown/orange right rear -
15 - brown ground
16 - white remote amp turn on
Thanks for your help
ttgolf is offline   Reply With Quote
Old 09-29-2004, 09:07 AM   #2
Canuck328i
My Ride: 09 Altima Cpe
Plain white wire. There are two - it is the one which is not twisted with a second wire (it is straight and alone).
According to your wiring codes, it is #16.
Mark
Canuck328i is offline   Reply With Quote
Old 09-29-2004, 11:24 AM   #3
Technic
My Ride: 2015 320i
Radio Connector --
10 - white Not Used
15 - brown ground
Check this wiring diagram for a HK system (courtesy of Pmmeke):
It seems to me that you need to tap into pin 10 on the amp connector (again, this is for a HK system) for the antenna turn on lead, if I understood you correctly.
Technic is offline   Reply With Quote
Old 09-29-2004, 12:56 PM   #4
ttgolf
Thank you. If I remove the factory HU and the factory amp I assume I probably should tap into PIN 10 in the amp harness.
If anyone disagrees with this please let me know.
