Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
#1 |
Anybody have the pin outs for the HK Speaker switch on the center console?
I have the older switch wich is a single button, not a part of the panel that newer models have. It's a six pin connector. I think it only uses the four leads. +12v (accy,ignit) Ground dimmer lead switch to HK amp Much thanks if anybody has it. |
#2 | |
Figured it out.
In case anyone wants to know
Pin Use Color Pin 3 12v (hot in acc,start and ignition) Red/Yellow stripe Pin 4 Ground Brown Pin 5 Light module Blue/Red stripe Pin 6 Amp signal Yellow/Black stripe Pins 1 and 2 are not used. Quote:
OEM Clears lights, OEM matte aluminum interior trim, OEM aluminum pedals,OEM Xenon's w/tit trim,UGDO.
#3 | |
Do you know what the switch does? It sends a positive? signal to HK amp to enable the spatial effect? I know it makes the system sound different I leave mine on all the time so whats the point of having the switch?
#4 | |
You would turn it off if you are getting poor radio reception and did not want the spatial effect to worsen your sound. Also, some audiophiles claim that it sents the center of the sound stage to an area near the center of the car.
I prefer the switch on as well. Quote:
