Sponsored by BAVSOUND
Old 10-06-2004, 01:07 AM   #1
egyptnads
Banned
My Ride: 2000 silver 323i
Send a message via AIM to egyptnads
enough airspace for 2 jl 12w7 w7??
i recently purchased a trunk setup custom made for our trunks. its a false floor and the spare is removed. it has two spots open and the previous owner used 2 12w6's in there. now my question is, is there enough airspace to put two 12w7s in there? i know they will fit, but i dont want my bass to be sufficated. what should i do? and is a 1000 watt amp enough to run them both?
egyptnads is offline   Reply With Quote
Old 10-06-2004, 01:21 AM   #2
low
OG e46fanatics lurker!
My Ride: is outside
find out what the size of the boxes are from the previous owner and check the jl site to see if that amount of space can accommodate dub7s
Pretty girls in bikinis...
Originally Posted by kwang1
no one ask you to click on it cry baby :cry: now I can see why Dougsun doesn't like you either.... sigh....
- I've been victimized with BOARD DRAMA!!! :lmao:
low is offline   Reply With Quote
Old 10-06-2004, 02:02 AM   #3
egyptnads
Banned
here let me take some pictures. does anyone have two w7s in their ride?
Old 10-06-2004, 02:05 AM   #4
egyptnads
Banned
well here are the enclosure recomendations:
Enclosure Recommendations:
Sealed Range: 1.25 - 1.625 cu. ft. (35.4 - 46.02 ltrs.)
Recommended Sealed Volume: 1.375 cu. ft. (38.94 ltrs.)
Fc: 44.7 Hz
F3: 40.4 Hz
Qtc: 0.792
Ported Range: 1.5 - 2.25 cu. ft. (42.5 - 63.7 ltrs.)
Recommended Ported Volume: 1.75 cu. ft. (49.56 ltrs)
Recommended Tuning: 32 Hz
Port Type: “Slot” ports are recommended. See Data Sheet for detailed info.
Old 10-06-2004, 02:43 AM   #5
egyptnads
Banned
here are the pics...
this is like the maxium space you can get with the spare tire space avaliable. the box is made of fiberglass. what do you guys think?
Name:	sub panel 001.jpg
Old 10-06-2004, 02:45 AM   #6
egyptnads
Banned
some more pics...
Name:	sub panel 002.jpg
ID:	94293   Click image for larger version
Name:	sub panel 003.jpg
ID:	94294   Click image for larger version
Name:	sub panel 004.jpg
Old 10-06-2004, 02:53 AM   #7
///NYCM3
My Ride: 2001 TiAg M3
Send a message via AIM to ///NYCM3
That size is perfect for 2 12w6v2's, definately not enough room for the 2 12w7's. besides a 1000/1 will power the w6's well, but is not nearly enough for the 2 dub7s
///NYCM3 is offline   Reply With Quote
Old 10-06-2004, 02:54 AM   #8
egyptnads
Banned
but the w7s look nicer LoL. yea and i dont think the cover would have fit the w7s.
Old 10-06-2004, 03:00 AM   #9
///NYCM3
Check out the IDmax subs, they look hot and r cheaper. But i dont know what space they need i think its a little less.
Old 10-06-2004, 03:23 AM   #10
egyptnads
Banned
hmm...
but are they up to par with the w7/w6s? how bad would it sound if i fit two w7s in my enclosure?
Old 10-06-2004, 05:31 AM   #11
CynicalWry
Doesn't like PMs...Email me
CynicalWry's Avatar
My Ride: 00 323i-05 cbr600rr
Send a message via AIM to CynicalWry
by the looks of things, two 12w7s w/ two 1000/1 amps (yes, you will need two to power that setup) would not work well in that box. The fiberglass doesn't look very think so I would think it would flex too much.
is your friend
Authorized Umnitza.com installer
301-825-5871
http://www.robinsNestChildCare.com - - - - - http://www.tntTint.net
CynicalWry is offline   Reply With Quote
Old 10-06-2004, 11:34 AM   #12
DamUTRIPPIN
My Ride: E60 530i
Send a message via AIM to DamUTRIPPIN
1. that enclosure's too small for dub-7's--they require LOTS of airspace!
2. a 1000/1 is definitely NOT enough power to push a pair of w7s--they require LOTS of power!
DamUTRIPPIN is offline   Reply With Quote
Old 10-06-2004, 11:38 AM   #13
low
My Ride: is outside
mmmmm...IDMAX. now theres a subwoofer that caught my attention
Old 10-06-2004, 11:42 AM   #14
low
My Ride: is outside
yes, i would say they are on par or maybe even better with the w6v2. heard a w6v2 and it actually sounded quite nice. and IDMAX to the W7? i think the w7 will go lower, i heard one 10 in a car and it sounded nice and deep, fairly clean. people who have spent a good amount of time with w7s and MAXes say the MAXes are more "musical". so take it for what thats worth. I really doubt youd be disappointed if you heard a MAX.
Old 10-06-2004, 11:51 AM   #15
MNbmw330ci02
My Ride: 04 VERT M3, 07 335i
nice system i have the same setup! you should be fine with power but i dont know exactly about the airspace. i had 2 500/1 going to each sub with the amps turned all the way down and it was fine. now i'm trying out the 1000/1 but havent installed it yet. i can ask my installer and get back to you on the sub install. i'm pretty sure you'd have to change up though?
MNbmw330ci02 is offline   Reply With Quote
Old 10-06-2004, 01:01 PM   #16
Gametrade
Gametrade's Avatar
My Ride: 01 330i Blk/Tan
I dont think the top board on that box is thick enough for 2x 12w7's. Im thinking some cracking or major flexin going on!!
Originally Posted by bluecougar
damn gametrade you are a hottie!
Gametrade is offline   Reply With Quote
Old 10-06-2004, 03:49 PM   #17
egyptnads
Banned
the fiberglass is pretty thick actually. i guess two w6v2s are what i have to go with. but how bad would 2 w7s sound in that box?
Old 10-09-2004, 05:09 PM   #18
egyptnads
Banned
do you think that box could be retrofitted to fit 2 10 inchers instead of 2 12 inchers?
Old 10-09-2004, 05:46 PM   #19
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
You can build a similar box but mount the woofers with the cone facing inside of the box. That will save you some space. Sealed enclosures are forgiving with regards to int vol by as much as +/- 20%. But if you are an anal audiophile, you'll want to get as close to spec as possible. A smaller enclosure will produce a more pronounced midbass "bump" and will be less efficient.
You could do some cutting and fiberglassing to make 2 10's fit. But why did you buy the box in the first place if you are going to do that?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 10-09-2004, 06:48 PM   #20
egyptnads
Banned
dont know, the box was really cheap, 220 total. total cubit ft in the box is about 2.1 or 2.2 27s take up between 1.35-1.6. so i think im pretty good with the space setup. i think i will be goin with one amp since its more effiecent.
