#1 |
[]D[][]V[][]D[][]\[]
HID Xenon Headlamps
Can someone please post detailed instructions on how to install these headlamps.. http://www.bekkers.com/details.php3?XenonHIDHeadlights They are supposed to be plug an play but I am a n00b who doesnt know what he's doing.. Anyone in this forum ever done it? Please post info plus pics if possible..
thanks a lot |
#2 |
The first step is to find a flat wall so you can mark the existing beam pattern with chalk. This will help you fine tune the height adjustment on the new lights.
step 1: put masking tape on bumper to prevent scratching. step 2: remove body colored trim below headlight. step 3: unhook electrical connections to current lights. step 4: remove the 4 bolts securing factory lighting assembly. Remove assembly. step 5: Insert Bekker xenon assembly and install the 4 bolts that secure it in place. step 6: hook up the electrical connection to the xenon low beam and to the halogen high beam. (they use the same connectors as the halogens, therefore, no modification is necessary) step 7: reintall body colored trim below headlight. If you buy them let me know when you're going to install them and I'll give you my cell # in case you get stuck. You shouldn't though because it's pretty easy. |
#3 |
hey, do you guys know what color temperature they are? and maybe if anybody has some pictures, i'd like to see them. thanks
#4 |
Did you really spend 900 on those OEM HID headlamp?
" If the horesepower means everything to u, then why not get a Supra instead?!"
#5 |
hey 900 for the bekkers isnt bad...go to ur dealer and ask for them expect a 1200-1500 price
#6 | |
>:P
When you installed yours did your computer have to be reset by the dealer??
Tit Silver 2000 328i. sp/pp/5spd.
oem clears, DIY silvervisions, hamann shadow grille, gen 2 DAE's, silver headlight trim, UUC RKIII..more to come. |
