Old 10-15-2004, 03:34 PM   #1
vaio76109
My Ride: Race Cars
My idea for stock, ecis, and conforti intake mod.
Well my idea for the stock, ecis and conforti intake has been to give each of these intakes more air from the kidney area. However, if you look at where the air intake in the grill is, its kind of up and out of the way. The air just kind of gets there by chance, theres no direct path directing air up in the intake.
My idea to is extend a plate down roughly 1" or so into the kidney grill area to "ram" more air into the intake. So after going to Lowes today i came back with this...
Its a "Thermoplastic All-Flash No-Calk Roof Flashing" made of out a roughly 1/16" medium strength plastic/rubber. Its black and looks rather OEM. I also bough some nuts, bolts, and washers.
I plan on cutting roughly 3" of the flat part of this roof flashing and running about 1.5" of it up into the intake in the kidney grill and using the nuts and bolts to attach it. This plastic piece should be at about a 45* angle and stick down about 1" and should gather quite a bit more air.
Here are some before pictures
It should stick down about as far as the higher bar in the kidney grill
A look up, as you can the air intake is rather up and out of the way.
I dont really feel like getting started today, maybe tomorrow.
vaio76109 is offline   Reply With Quote
Old 10-15-2004, 03:44 PM   #2
BattleWagon
My Ride: Colnago CT-1
Novel idea, good luck. Let us know how it goes and if worth the effort.
BattleWagon is offline   Reply With Quote
Old 10-15-2004, 05:20 PM   #3
vaio76109
My Ride: Race Cars
Ok, i decided to start, but then got immediately stuck trying to remove the grill intake piece. There 3 little button like things. The one on the driver side slides out pretty easily, however the other 2(on the passenger side) i cant get to come undone. The one of the passenger side front looks like it supposed to slide out like the drivers side one, but i cant get it to. The one on the passenger back tho doesnt look like it slides out. Has anyone ever removed this piece?
Old 10-15-2004, 05:49 PM   #4
Gametrade
Gametrade's Avatar
My Ride: 01 330i Blk/Tan
Keep tabs on the price also, so you can see if the effort is worth it in the long run.
Originally Posted by bluecougar
damn gametrade you are a hottie!
Gametrade is offline   Reply With Quote
Old 10-15-2004, 06:00 PM   #5
vaio76109
My Ride: Race Cars
So far im at $6.22, and i dont see any other costs.
Old 10-15-2004, 06:10 PM   #6
JCz04Bimmer
JCz04Bimmer's Avatar
My Ride: 2004 330Ci & 06 Z4MC
Send a message via AIM to JCz04Bimmer
I have removed the piece before. All I can remember is that you pop the center little nub up and then you can sorta work it off. Don't worry, those rivets are like 2cents if you happen to break one and I doubt you'd be able to break the intake piece because thats a bit more substantial of a piece.
JCz04Bimmer is offline   Reply With Quote
Old 10-15-2004, 06:11 PM   #7
vaio76109
My Ride: Race Cars
What do you mean the center nub?
And that $0.02 is 110 miles away.
Old 10-15-2004, 06:13 PM   #8
JCz04Bimmer
I wish I had my car in front of me! The rivit has like a smaller circular part to it right? The whole rivet kinda looks like 2 concentric circles... the larger being the boundary of the rivet and the smaller being slightly raised. I was able to just pop the center part out and KEEP pulling up. Keep pulling until it seperates. I think
Old 10-15-2004, 06:18 PM   #9
vaio76109
My Ride: Race Cars
Taking pics, brb.
Old 10-15-2004, 06:21 PM   #10
JCz04Bimmer
Smokin' cigarette, brb
Old 10-15-2004, 06:33 PM   #11
vaio76109
My Ride: Race Cars
Smoking
Improving car
Ok this is how looks installed:
This is how far ive gotten it so far:
The 2 clips i cant get undone:
Another pic of the 2 clips i cant get undone, as you can sort of tell the clip in the foreground slips in/out, but the one in the background i have no idea how it works:
Old 10-15-2004, 06:50 PM   #12
BattleWagon
Smoking
Improving car
use little flathead screw driver to pry the center button-like piece up a little than use thumbs or needle nose pliers to get out all the way.
EDITED: I meant pull the center piece as far as it goes and then pull the entire plug out by pulling up on the larger diameter flat section.
Old 10-15-2004, 07:00 PM   #13
vaio76109
My Ride: Race Cars
Got it, thanks.
Old 10-15-2004, 07:17 PM   #14
sheefo2k
sheefo2k's Avatar
My Ride: vrm psh - 02 325ci
smoking is great
Performance BMW car
Sponsored by :
www.euro-spec.net
www.bimmian.com
BMW Motorwerks
support:
www.vmwerks.com
www.esstuning.com
www.my330i.com
sheefo2k is offline   Reply With Quote
Old 10-15-2004, 07:22 PM   #15
Staszek
Are we there yet??
Staszek's Avatar
My Ride: Now a daily drive
Send a message via AIM to Staszek
Posting on this because I want to see if this works then I am getting you to make one for me lol!
Euro Delivery Thread
///M3-6MT:dance:
Staszek is offline   Reply With Quote
Old 10-15-2004, 07:29 PM   #16
vaio76109
My Ride: Race Cars
Well right now im cutting away with a phucking knife, not a saw, a knife. So far the cutting has been a PITA, but im almost done with the cutting.
Old 10-15-2004, 07:43 PM   #17
vaio76109
My Ride: Race Cars
Old 10-15-2004, 08:15 PM   #18
BattleWagon
Looking good, I like it!
Maybe you should mount it underneath instead of inside the intake, that way you do not loose any intake area as it looks pretty small to begin with. Just a suggestion. Any air leakage underneath is not a big deal.
Old 10-15-2004, 08:24 PM   #19
vaio76109
My Ride: Race Cars
Good, idea. I havent thought of that, ill try it and see how it works out.
All for performance sake, right?
EDIT- oh yea i have one prob, i dont have a drill
Old 10-15-2004, 08:34 PM   #20
dbtheo
Bahn Burnah
dbtheo's Avatar
My Ride: 323i/ 3.0
I want to see what happens too...
dbtheo is offline   Reply With Quote
