Old 10-20-2004, 12:45 PM   #21
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
Originally Posted by proveg
Some Audi freinds of mine said that they have an antenna under the back seat that can be rewired or exposed and will increase range over 200 feet.
Anyone knows where the antenna is on E46 (sedan)
In the rear window
davidwarren is offline   Reply With Quote
Old 10-20-2004, 06:02 PM   #22
nEVERCLEAR
My Ride: 323
Originally Posted by davidwarren
In the rear window
That sucks, in my S2000, when I installed the OEM alarm it had a 10" or so wire that laid in the area under the cluster and that was the antenna. I added a few feet and ran it to the rear of the car and up around the roll over hoop. I had lots of things removed during a stereo install and I am obsessive
Anyways I could lock/ unlock from the opposite side of a mall parking lot. That came in handy when I needed to let someone get something from my car.
On a similar note, I broke my cell phone antenna (Damn Motorola's ) Not being good with a soldering iron, I wrapped a piece of thin gauge silver wire around the broken antenna knub and soldered it in several places and I get the best reception ever. I never replaced the phone since it works better than any phone I ever had.
Thinking about a Honda or VW Dont buy from East Coast Honda - VW Read about my experience here
Some people dream of speed-others create a damn jet powered shopping cart.
Curious about VoIP and Vonage click here
nEVERCLEAR is offline   Reply With Quote
Old 10-20-2004, 06:07 PM   #23
nEVERCLEAR
My Ride: 323
Upping my post count
Change the battery, mine started getting short and not working right and it was the battery.
I have an 00 323 so if you have a new type key that charges in the ingnition you don't change the battery at all.
Old 10-23-2004, 04:46 AM   #24
Mike Benvo
Past Site Sponsor
My Ride: Dinan E60 ///M5
Send a message via AIM to Mike Benvo
Mike Benvo is offline   Reply With Quote
Old 10-23-2004, 04:46 AM   #25
Mike Benvo
Past Site Sponsor
Originally Posted by invidious_D
Hold key pressing the metal part on the underside your chin. It will increase the range for 100s of feet. I know it sounds dumb but I'm dead serious. I can unlock my car from the 8th floor of my work building just like I was 5 feet away.
-D
use that trick everday because my range is horrible
Old 10-23-2004, 10:46 AM   #26
BMuu328i
My Ride: 99 328i
"Chin" trick works because alarm remotes use Radio Frequencies to arm/disarm. Your body acts as an extended range antenna. Just like when you have an old radio/boombox etc. and you touch the antenna the station sounds good. Station sounds good because your body is acting like an antenna. Similarly, your body acts as an RF antenna extension for your key fob.
NOTE: Doesn't work on TV remotes since they are infrared signals.
BMuu328i is offline   Reply With Quote
Old 10-23-2004, 10:59 AM   #27
budman
-not a mod-
budman's Avatar
My Ride: ..
make sure you open your mouth when you do it
-Gunnar
budman is offline   Reply With Quote
Old 10-25-2004, 02:10 AM   #28
invidious_D
My Ride: 2003 BMW 325i
Also talk like a robot, it helps.
This is where your signature should go.
invidious_D is offline   Reply With Quote
Old 10-25-2004, 01:23 PM   #29
Djguebin
My Ride: 325xi
bump
Djguebin is offline   Reply With Quote
Old 10-25-2004, 01:33 PM   #30
WhiteDagger
My Ride: 330i
Send a message via AIM to WhiteDagger
Originally Posted by Djguebin
bump
Why are you bumping this?
The correct answer has been given. BTW, if you need more info on this topic, just search the forum...there are PLENTY of threads on this same topic.
WhiteDagger is offline   Reply With Quote
Old 10-25-2004, 01:53 PM   #31
bearing01
My Ride: 02-E46/86-E30
Originally Posted by Dev
Will this pose any radiation problems (e.g cell phones debate)?
Key under chin won't cause any radiation problems. It's not like a cell phone because a cell phone blasts out -20dBm or more to hit a tower which is a mile away, through an antenna which concentrates the power in a particular direction... that peirces your head. The little battery in the key emits much less power than say... a computer monitor or microwave oven or chordless telephone. My guess the key frequency is a few hundred MHz at most. Your head acts like a big capacitor to increase the gain of the key antenna... making it look longer. (It also make you feel like-one with your car... doesn't it?)
You also don't want your car antenna to be extended or gain increased to give you extra long range. Ever be washing your car with your keys in your a$$ pocket and lock/unlock the car? You don't want to be in the house or somewhere and accidentally unlock the car.
bearing01 is offline   Reply With Quote
Old 10-29-2004, 03:03 AM   #32
WhIte///D3MON
My Ride: 02 OG/Cinn M3vert
wow cant wait to try, anyone have a better technique, so im not lookin like a fool with my key on my chin
WhIte///D3MON is offline   Reply With Quote
Old 11-09-2004, 01:28 AM   #33
TedPre
My Ride: 2003 325i and 1990 5
Originally Posted by DionikesX
Ya, the BMW-forums has a sticky on its e46 forum that gives you some tips and tricks for your e46. The chin trick is one of them, but there a lot more. Like how to get into the cars diagnostic modes and the such. There is a lot of stuff that will blow your mind.
As far as the chin thing goes...can anyone explain why that works? Who figured that one out? Oh I will just touch the key to my chin...I bet that will increase range.
Your Body becomes the antenna
TedPre is offline   Reply With Quote
Old 06-21-2008, 06:05 AM   #34
RiFo
My Ride: E46 M3
Send a message via MSN to RiFo
Originally Posted by MIAMITOPAZ View Post
yeah just hold it up to your chin
** if you got braces i heard you get up to a mile
HAHA that made my day man !!
Drive To The Satisfaction...
Mods: Rear Smoked LEDs | Front Smoked Corner Lights | 8000K HID | BMC Drop-In Panel | Matt Black Kidney Grills | White CCFL | Matt Black Side Grills
RiFo is offline   Reply With Quote
Old 06-21-2008, 11:40 AM   #35
Dreamliner330
My Ride: 330xi
I just swallowed my spare key ...now every time I do a crunch, my damn trunk pops open.
...I may have made that up.
Dreamliner330 is offline   Reply With Quote
Old 06-23-2008, 02:02 AM   #36
swoobies
My Ride: '03 M3
if i hold it next to my dong i get an extended range of 3"
swoobies is offline   Reply With Quote
Old 06-23-2008, 03:31 AM   #37
bmw_dna
Modded
My Ride: e60 525 - e46 vert
only?
bmw_dna is offline   Reply With Quote
Old 06-23-2008, 03:32 AM   #38
RiFo
My Ride: E46 M3
haha enough with the dongs chat
Old 06-23-2008, 10:52 PM   #39
swtguysb
My Ride: E46, E53, BB6
I get an extra range of 8" in the morning ...
I Iforged I Eurospec I Hamann I EAS I Bimmerblvd I Instylegraphics I TWS I Jlevis I
swtguysb is offline   Reply With Quote
Old 06-24-2008, 11:56 PM   #40
deadpass
My Ride: 01 330i
I have a wireless remote for my camera that has very poor range, but if I put my finger on the antenna my range triples. Perhaps using your finger on the metal part will yield the same result for the key.
deadpass is offline   Reply With Quote
