Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 10-26-2004, 02:28 AM   #1
Solid
Solid's Avatar
My Ride: `07 335i Sedan
Send a message via ICQ to Solid Send a message via AIM to Solid Send a message via MSN to Solid Send a message via Yahoo to Solid
Thumbs Up Egauges.com Steering column gauge pods review
After a 3 week wait (backorder) I finally got it.
http://www.egauges.com/vdo_acce.asp?...E46_ePod&Cart=
It replaces the upper plastic piece of the steering column. Everything fits perfectly and it has all the corrects holes as the OEM version. Each pod is completely removable and both 52mm and 60mm gauges fit very snug via a rubber insert. Both pods swivel so the angle is adjustable, and they provide holes to hide any wires. Overall, it's very clean and looks good IMO.
I've attached some pictures as an example of how it would look (the gauge really isn't hooked up).
I'm still waiting for my boost warning gauge from importparts.com, the screwed up my order and sent me a White Warning EGT gauge instead of a Silver Warning Boost Gauge, those idiots... So I'll have pics of that gauge installed whenever the mixup is done with.
Original Piece:
Side View. Notice the wire coming out of the back of the pod, this wire hides under the column piece:
Front View. Depdning on how you tilt the column, and your angle, it does block your view of the fuel and engine temp gauges, but you can still see the needles. Also note the left pod is completely removable:
Solid is offline   Reply With Quote
Old 10-26-2004, 04:02 AM   #2
Casanova
SoCal Europrojektz
My Ride: RX-8/E46
Send a message via ICQ to Casanova Send a message via AIM to Casanova Send a message via MSN to Casanova
looks good, but i think it covers too much info....i like to know when I'm throwing a fault code, and since i'm a step; what gear I'm in.
but if you like it, why listen to me...
happy it fits nicely
Drive Hard. Look Good. Be Loud. Get Some.
Director of Europrojektz Malaysia Chapter
Hamann GT-R Widebody | Modified AA-Tuning supercharger kit
My New Ride
Casanova is offline   Reply With Quote
Old 10-26-2004, 04:05 AM   #3
Solid
Solid's Avatar
I held the camera lower than head level, so you can see a little more of the cluster. I'm only going to use 1 pod (removing the left one) so seeing the codes will be fine. I guess it could be a problem if you used both...
Old 10-26-2004, 09:18 AM   #4
Nt_loader
ASA NO MO
Nt_loader's Avatar
My Ride: 1999 Golf
Not bad
Nt_loader is offline   Reply With Quote
Old 10-26-2004, 11:06 AM   #5
Will ZCPM3
Will ZCPM3's Avatar
My Ride: ///M3
looks pretty good
Will ZCPM3 is offline   Reply With Quote
Old 10-26-2004, 11:41 AM   #6
NICEBIMMER
My Ride: E38 750IL
Looks very good ...
00 E39 M5
Previous Bimmers-
00 328ci, 01 325i, 95 M3, 97 740i, 97 M3/4/A, 00 M5, 91 318i, 02 X5, 96 740iL, 96 E38 750IL
NICEBIMMER is offline   Reply With Quote
Old 10-26-2004, 12:08 PM   #7
Cali6869
BIG STUNNA
My Ride: ASA 323ci SK2, ///M5
not too bad....
Cali6869 is offline   Reply With Quote
Old 10-26-2004, 01:57 PM   #8
JC7727
JC7727's Avatar
My Ride: 01 330i
Send a message via AIM to JC7727
gauges alittle big?
Sponsored by Jlevi StreetWerks
FOR SALE: http://forum.e46fanatics.com/showthread.php?t=417026
JC7727 is offline   Reply With Quote
Old 10-26-2004, 02:04 PM   #9
Solid
Solid's Avatar
The gauge in the picture is a 60mm.
Originally Posted by JC7727
gauges alittle big?
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
