Old 10-28-2004, 02:41 PM   #1
trippinbillies4
trippinbillies4's Avatar
My Ride: '02 Mini, '13 FR-S
DDE Install Questions
Hey guys, a few questions regarding the install of my $149 JLEVI DDE's:
1) What is positive and negative coming out of the balasts? Stripd or all black?
2) Does the polarity of the white cables from the actuall rings make a difference?
3) What the heck is everyone talking about ring one and two? I just slid the clips onto the op flat part of the lights, and they both look right... Is that not correct? I don't see how i is even remotely possible to break these? What am I doing wrong?
__________________________________________________
'02 Mini Cooper #40HS, '13 Scion FR-S #40CS, '12 Ducati SF848
trippinbillies4 is offline   Reply With Quote
Old 10-28-2004, 02:42 PM   #2
trippinbillies4
One more:
When you go to the ECU, do you just find any red wire with a white stripe?
Old 10-28-2004, 02:52 PM   #3
mach330
My Ride: E90 AW ///M3
1. it doesn't matter which polarity.
2. same as above
3. ring should be interchangable.
look for a red/white stripe with gold/orange small lines going across it. there's only one in the ECU.
Now..hurry up with the pix...
Rated /// M
mach330 is offline   Reply With Quote
Old 10-28-2004, 03:20 PM   #4
trippinbillies4
Thanks bud!
One more:
When the two white plugs come out of the ballast, is one plug left ring 1 and one plug ring 2, or is one plug both positive and one plug both negative?
Old 10-28-2004, 03:25 PM   #5
CtrlAltDel
www.piratecove.org
My Ride: 2007 335i Coupe
Send a message via ICQ to CtrlAltDel Send a message via AIM to CtrlAltDel
it doesnt matter for the ballasts
one end plugs into the rings, the other plugs into the wires running to the ecu
its not as hard as you think
Yeah I havent updated my sig yet with my 335, kill me.
CtrlAltDel is offline   Reply With Quote
Old 10-28-2004, 03:44 PM   #6
mach330
Thanks bud!
One more:
it doesn't matter. just plugin one dde to one white plug (don't intertwine). the other side of the ballast should be the power source/w trigger. if you're still having problems. give me your email and i'll email you the colored instructions.
Rated /// M
Old 12-12-2004, 10:22 AM   #7
beemerdriver
My Ride: '04 320 Cd
2. same as above
I can't seem to find that red/white wire with yellow lines.
I have a '04 320Cd
beemerdriver is offline   Reply With Quote
Old 12-12-2004, 01:18 PM   #8
PoorGuyX3
My Ride: 2004 X3 2.5i
Send a message via AIM to PoorGuyX3
i'm having trouble finding the right wire to tap on the ECU interface.
I have an 05' 330i ZHP and so far I have found 2 wires that are red/white stripe with yellow blocks around it.
Which one should I use?? I'll take a picture and post it to this thread so you'll know what i'm talking about.
My Rides -
2004 X3 2.5i
2005 330i ZHP
PoorGuyX3 is offline   Reply With Quote
Old 12-13-2004, 12:21 AM   #9
PoorGuyX3
Ok,
I now have pics from the computer wiring harness...
This is the big picture...
This is the cable towards the front of the ECM...
This is the cable towards the back of the ECM...
My Rides -
2004 X3 2.5i
2005 330i ZHP
Old 12-13-2004, 12:29 AM   #10
mach330
i don't think it should matter. but for me, i tapped mine to the wire closer to the windshield.
Rated /// M
Old 12-13-2004, 12:29 AM   #11
BMW330xi01
My Ride: 98 Skyline
Originally Posted by PoorGuyX3
Ok,
either one that cable just snakes around as long as u tap into the cable thats RED/WHITE/YELLOW hashes you will be 100% a OK
NO LONGER INSTALLING IN CONNECTICUT. I AM LOCATED IN JAPAN NOW
LUIS ESCOBAR
L.EscobarJr@yahoo.com
INSTALL PHOTOS
BMW330xi01 is offline   Reply With Quote
Old 12-13-2004, 04:59 AM   #12
beemerdriver
My Ride: '04 320 Cd
I don't find the cable in any of these two pictures.
You have 2 cables, I nothing
Old 12-13-2004, 09:07 AM   #13
PoorGuyX3
So now that I know I can use either cable, I have another question...
What is the best place to run the wires from the halos through the headlight to the ballast?? Does anyone have a picture of this?? I have not seen, nor read in any instructions of where to run the leads from the halos throught the headlight.
Thanks,
PoorGuy
My Rides -
2004 X3 2.5i
2005 330i ZHP
Old 12-13-2004, 10:03 AM   #14
Moeser09
My Ride: 2k1 M3
The back of the highbeams/daytime running lights has a rubber cap that, if you peel that back a little bit you can feed the wires from the CCFL rings through that hole and then pull the rubber cap back snug on the back of the light fixture.
Moeser09 is offline   Reply With Quote
Old 12-13-2004, 08:55 PM   #15
PoorGuyX3
Thanks dude!! I finally got them installed....
My Rides -
2004 X3 2.5i
2005 330i ZHP
Old 12-13-2004, 10:43 PM   #16
Moeser09
My Ride: 2k1 M3
No probs - looking sweet dude.
Old 12-17-2004, 09:10 PM   #17
The Chosen 330i
My Ride: 2004 330i ZHP 6spd
how well do these DDE's light up the road at night?
The Chosen 330i is offline   Reply With Quote
Old 12-17-2004, 09:21 PM   #18
JCsE46
(oOO \ (||||)(||||) / OOo)
JCsE46's Avatar
My Ride: 03 E46 JB, 08 MBE350
Send a message via AIM to JCsE46 Send a message via MSN to JCsE46
Duh! these are not headlights. You weren't suppose to light up only the DDE's at night.
JCsE46 is offline   Reply With Quote
Old 12-17-2004, 09:24 PM   #19
The Chosen 330i
Old 12-17-2004, 10:56 PM   #20
JCsE46
JCsE46's Avatar
