Old 11-01-2004, 11:39 AM   #1
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
Send a message via AIM to niL
Are the bolts on the header attached to the header?
Well i bought a TSE2 from a local fanatic (thanks!) and upon going to crack open the bolts by the headers, i notice one bolt is broken and the other 3 is rusted. i'm going to take a pic just now but now i have no clue how i'm gona install the TSE2 with this broken bolt. the stock exhaust isnt leaking so the seal must be good still between exhaust and headers. any tips guys?
edit: the other 3 are rusted, gona use some rust eater on them but any tips for not breaking them like this already broken one?
2001 330i rebuilt from the salvage yard
From start to finish...
niL is offline   Reply With Quote
Old 11-01-2004, 11:51 AM   #2
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
pics..
ID:	97275   Click image for larger version
ID:	97276   Click image for larger version
Old 11-01-2004, 11:52 AM   #3
S2Krazy
A Flammable Plumber
S2Krazy's Avatar
My Ride: ****ED UP CL
Send a message via AIM to S2Krazy Send a message via MSN to S2Krazy
that sux .... i would just save me the trouble and the headache and cut them off
S2Krazy is offline   Reply With Quote
Old 11-01-2004, 12:29 PM   #4
RVBoy
My Ride: 330i
Send a message via ICQ to RVBoy
Cut all the nut and bolts and replace it with the new one. Use dremel tool to cut them bolts
Eddie
RVBoy is offline   Reply With Quote
Old 11-01-2004, 12:41 PM   #5
HIGH_HEAT
Formerly DINAN_3er
HIGH_HEAT's Avatar
My Ride: Was DINAN_3er NOw SC
Send a message via AIM to HIGH_HEAT
damn that sucks man !! jesus ... ya def get a dremel and cut them off...
HIGH_HEAT is offline   Reply With Quote
Old 11-01-2004, 12:53 PM   #6
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
what do you guys think i should do for the already broke one? it seems to be rusted to the otherside of the header. should i drill through it?
Old 11-01-2004, 01:27 PM   #7
RVBoy
My Ride: 330i
Can you punch it and get it out? if not go ahead drill it out and put a new bolt. Make sure you have a new gasket usually they call donought gasket for exhaust...
eddie
Old 11-01-2004, 03:47 PM   #8
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
eddie
well i've been punching them with a hammer and cold chisel with no luck, it looks like it's part of the header or just really jammed in there. i cracked one side of the exhaust off no problem, the one with the broken bolt, now has 2 broken bolts. i tried cutting the broken bolts with a dremel only to break the cut off disc's. i have a heavy duty grinder that i'm gona use if this continues i cant seem to find replacement bolts for this in the ETK either so i guess i have to drill through them carefully, i cant afford a new header
Old 06-08-2013, 08:19 AM   #9
BigDRick323
My Ride: 2000 323i
How did this go, I'm in the same position except I'm willing to remove mine since I have new bolts and nuts ready to go. What's the best way to get the old ones out?
Old 06-08-2013, 09:46 AM   #10
HiHoBrian
My Ride: 05 M3
Re: Are the bolts on the header attached to the header?
Thread appears to be 9 years old, but to try to help, torch it red hot then punch it out. Some are bolts some are pressed in studs. Either way cut it flush heat it red then punch it out.
HiHoBrian is offline   Reply With Quote
Old 06-08-2013, 01:41 PM   #11
Stinger9
My Ride: '04 330Ci
niL gave up on us back in '09, so be optimistic and he'll be back soon to unravel this dilemma!
Old 06-19-2013, 08:50 PM   #12
BigDRick323
My Ride: 2000 323i
here's where I am.
Old 06-19-2013, 09:32 PM   #13
HiHoBrian
My Ride: 05 M3
Use an oxyacetalyne torch to heat the flange red hot then hammer them out. The look like the press fit studs to me. (Not threaded in) You could also cut them flush and drill them out, but drilling is only half as fun as torching your car.
Old 06-20-2013, 08:22 AM   #14
BigDRick323
My Ride: 2000 323i
They're not threaded in, just rusted in at this point i think.
Sent from my LG-MS870 using BimmerApp mobile app
