Sponsored by The Tire Rack
Old 11-06-2004, 12:15 PM   #1
guzplace
My Ride: 318Ci
gary, yokohoma tips on their website !!!
Hello Gary ..
I read this on yokohama webstie i can't understand it well
Choosing a wider rim: increases vehicular stability, steering response and cornering ability. A rule of thumb is to use a rim width 90% as wide as the tread width (not section width) of a performance tire for street applications. This provides a good balance between performance and ride quality. Always be sure that the chosen rim width is within the tire's range of acceptable rim width specifications
I have 16" x 7" wheels
i mounted 205/55 R16 tires on them
7 inch = 177.8 mm
my section width would be 205 mm
177.8 /205 = 86 %
would that be a better setup than mounting a 225/55 R 16 on the same wheel
177.8 / 225 = 79%
i mean what setup is better 205 or 225 knowing that they have nearly same diameter .....
guzplace is offline   Reply With Quote
Old 11-06-2004, 12:43 PM   #2
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
The fact is that the 225/55R16 end up being nearly an inch taller overall, not suggested. Use 225/50R16 if you're after a wider tire with about the same OD.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 11-06-2004, 01:04 PM   #3
guzplace
My Ride: 318Ci
I wrote 225/55 by mistake
i meant 225/50 R 16
but what do you think of this 90% tread width NOT section width Notion ...
is it true in this case ?
if we chose wheels that are 90% as wide as tread width .. what benefits ?
better handling
and how can we measure tread width
when they say this tire fits 6-7.5 RANGE
what is the best place in this range ? middle ? end of it ? start of it ?
Old 11-06-2004, 01:09 PM   #4
Rudy@Tirerack
Moderator
i meant 225/50 R 16
better handling
225/50R16 not even an inch wider, so while in theory it will help a bit in handling, its considered mostly a cosmetic difference. As long as you're in the rim width range you won't see much difference in handling on street applications. Since you're already changing tires though, may as well go wider if its not gonig to be used in the snow.
http://www.tirerack.com/a.jsp?a=BN4&...ires/index.jsp
Old 11-06-2004, 01:17 PM   #5
guzplace
My Ride: 318Ci
GARY thanks a lot man
but i just hope you can answer me on this
205/55R16 5.5-7.5 that's the range for my tire
what is the best wheel to install on this TIRE
the tire is a constant my variable is the wheel ...
16 X 7 comes near the end ... is that the best ?
Old 11-06-2004, 01:19 PM   #6
Rudy@Tirerack
Moderator
No best wheel width IMO. If you're on R compound ultra stiff race tires shoot for the higher end of the range in general. For street tires, makes very little difference.
Old 07-29-2005, 01:01 PM   #7
kalakuta1
My Ride: 323i
Gary,
I am about to purchase the 225/50 R 16s to replace my OEM 205/55 R 16s. These tires will be used in the snow. Do you recomend the switch? Will i run into any problems? Please advise.
Mike
kalakuta1 is offline   Reply With Quote
Old 07-29-2005, 01:15 PM   #8
Rudy@Tirerack
Moderator
Originally Posted by kalakuta1
Gary,
Mike
225/50R16 is slightly wider so not quite as good in the snow, but the difference isn't much (less than an inch) and should not cause problems.
