From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast
Old 11-29-2004, 10:40 PM   #1
GODZPEED
My Ride: garage M T :(
Send a message via AIM to GODZPEED
how much camber ????????
looking to get some feedback on what some of you fanatics are running, camber wise, front and rear for autocross and track events. thanks.
GODZPEED is offline   Reply With Quote
Old 11-29-2004, 11:01 PM   #2
AndyZHP
My Ride: BMW
-3 to -3.5 in the front, -2.5 in the rear
- 1987 BMW 325is
- 2002 BMW M3
- 2003 BMW 540i Sport
AndyZHP is offline   Reply With Quote
Old 11-29-2004, 11:25 PM   #3
rumatt
My Ride: 330i
Huh? I thought around -1.3 up front was max on the E46.
EDIT: Doh, you got camber plates?
rumatt is offline   Reply With Quote
Old 11-29-2004, 11:26 PM   #4
mach330
My Ride: E90 AW ///M3
a friend of mine has -1.25 in the front and -2 at the back. i'm gonna try that setting on the next auto-x event. my car currently has -0.5 all around.
Rated /// M
mach330 is offline   Reply With Quote
Old 11-29-2004, 11:38 PM   #5
rumatt
My Ride: 330i
Does anyone know the factory camber setting? Around -0.5 maybe?
I punched out the alignment tabs and pushed them toward the center for some extra negative camber (another -0.5? ) I'm wondering if I'm anywhere near max? (around -1.3 is max, I think)
Old 11-30-2004, 12:25 AM   #6
AndyZHP
My Ride: BMW
When I set my car up for the stock class last season, I had an alignment to set max negative camber all the way around... this is all I got.
http://www.bimmerfest.com/forums/showthread.php?t=49459
Yep, those help quite a bit.
- 1987 BMW 325is
- 2002 BMW M3
Old 12-10-2004, 11:59 PM   #7
BWoodson
My Ride: '03 330i Imola ZHP
Send a message via Yahoo to BWoodson
Andy,
I was thinking you were the guy my favorite alignment mechanic (Bill at Performance Alignment in Cincinnati) set up. He said he setup my car the same as yours (another '03 ZHP). But he was only able to get about -1.0 in front; he dialed down rear camber to about -1.5 or so.
Same as you -- my alignment tab has been punched out. But you've got to do something else to these e46s (camber plates, etc.) to get more then -1 to -1.5 of camber out of the front end.
Come on...give up the scoop...I'm going through front tires like a bandit here!
-b.
B On Trak
BWoodson is offline   Reply With Quote
Old 12-11-2004, 12:36 AM   #8
bjo
My Ride: 04 m3, 03 x5, 95 m3
e36 and e46's love lots of front camber. i run -3.5deg front -1.8 rear.
bjo is offline   Reply With Quote
Old 12-11-2004, 10:02 AM   #9
AndyZHP
My Ride: BMW
Originally Posted by BWoodson
Andy,
-b.
To get more then -1 degrees of camber up front you're going to need camber plates for sure. I recently bought the new E46 camber plates from TC Kline Racing. These plates have totally transformed the handling of the car. I would highly recommend them!!
http://www.tcklineracing.com/monoball.htm#camber
- 1987 BMW 325is
- 2002 BMW M3
Old 12-11-2004, 11:46 AM   #10
Spiral Prophet
Über-Geek
Spiral  Prophet's Avatar
My Ride: '01 Topaz Blue 330ci
Send a message via AIM to Spiral  Prophet
i have -2.5 all around.. but i definetly need to go with more up front.. probably -3.0
i have the ground controll camber plates
~T|/\/\
Spiral  Prophet is offline   Reply With Quote
Old 12-11-2004, 11:50 AM   #11
rumatt
My Ride: 330i
Wasn't there a post somewhere sayign that although these camber plates increase camber, they actually reduce castor? And some argue castor is much more important that camber.
Any thoughts on this?
Old 12-11-2004, 06:01 PM   #12
AndyZHP
My Ride: BMW
The caster on the E46 is not adjustable and comes stock with about 4.4 degrees. TC Kline's camber/caster plates actually have quite a bit of caster adjustment. I have max caster set with these plates and am running about 7.2 degrees.
- 1987 BMW 325is
- 2002 BMW M3
Old 12-11-2004, 10:15 PM   #13
bjo
most of the adjustable camber plates can adjust caster. i have the motorforce plates and i have @ 6deg caster.
Old 12-12-2004, 11:54 PM   #14
Spiral Prophet
Über-Geek
The ground controll camber plates have a ton of caster adjustment on them also..
~T|/\/\
Old 12-27-2004, 06:32 PM   #15
Machan
My Ride: 330i and 325CiC
sorry to threadjack, but how did you punch out the alignment tabs. Can you post a pic?
Does it look like my shock tower shown in this thread:
http://forum.e46fanatics.com/showthread.php?t=220070
if you are a European car fanatic and you live near Chicago check out:
http://www.euroteknik.com
Machan is offline   Reply With Quote
Old 12-28-2004, 09:06 PM   #16
jmsanders78
My Ride: 328i, Z4
Spiral Prophet - I just checked GC's website and it looks like the camber plates they make don't work with stock springs. Is that wrong or do you have a GC suspension setup? Thanks!
jmsanders78 is offline   Reply With Quote
Old 12-29-2004, 04:33 AM   #17
Spiral Prophet
Über-Geek
Yeah they don't work with stock springs.. i replaced my front springs that came with my pss9 setup with eibach race springs... springs need to be straight cylinder shaped and not cone shaped... but it was a good thing.. the billstien springs are progressive rate where the eibach's are a straight rated spring..
~T|/\/\
