Rating:
Display Modes |
#1 |
DIY Wiring Harness for CCFL angel eyes kits
Ok - these are the DIY instructions on how to build a wiring harness using a relay (with key remote option) if youre CCFL Angel Eyes kit didn't come with a wiring harness (usually the ebay kits - they only come with 4 CCFLs and two inverter boxes and instructions saying to wire to the parking lights). Credit given to everyone who pioneered these mods in the first place.
You will need these things (prices for what I paid - your cost may vary - especially if you have to buy packs of things like fuses): PARTS: One (1) 40 Amp 12 Volt SPDT relay with socket ($7.04) Five (5) Female spade connectors to go into the sockets ($0.81) Two (2) T-taps ($1.26) Four (4) pairs of male/female bullet splice connectors ($0.77) One (1) butt connector ($0.12) Two (2) watertight fuse holders ($4.31) Two (2) 5 Amp fuses ($0.60) Two (2) Ring connectors ($0.30) Lots of Wire - I used 4 colors (black, red, blue and green) and used about $6 worth of wire. You can use either 16 or 18 guage, but make sure you get the right connectors for the guage. On the T-taps, you might have to fold the wire over to make it bulky enough to get a good crimp. About $7 dollars worth of wire Roughly about $22.25 in parts (you'll actually pay a little more if you have to buy certain things in bulk - i.e. most the connectors). I think I spent a little over $27 today for parts I didn't have (I had some wire, butt connectors and the fuses - so the cost if you had to buy everything would be about $35). Braided fabric high temperature wire wrapping/sleeving (I didn't have any, but it's useful to hold the wires together. I'm not sure on the cost - I found a place online that was $0.25/foot but you had to buy some pretty big quantities. You might be able to find them at computer shops too. TOOLS: Crimping tool/plier/snips Electrical tape (optional if you want to clean up the wiring) TIME: Approximately 1.5 hours if you work fairly carefully. Last edited by Moeser09; 12-02-2004 at 09:07 PM. |
#2 |
STEP ONE
Cut the wire into the following lengths: One green wire of approximately 50 inches (for ECU trigger wire - it has to reach from the passenger side through the wire holder above the engine and to the ECU box). One blue wire of approximately 6 feet (for the interior light tap - length depends on how far you have to run the wire). One black wire of approximately 1 foot (for the ground) One black wire and one red wire of approximately 3 feet (for the passenger side inverter box) One black wire and one red wire of approximately 6 to 6.5 feet (for driver side inverter box) STEP TWO Crimp one of the ring connectors (for the positive battery terminal) on one end of one of the fuse holders and crimp one of the female spade connectors on the other end of the fuse holder. STEP THREE Crimp the ends of the two red wires together into one female spade connector. Crimp the ends of the three black wires together into one female spade connector. STEP FOUR Crimp a ring connector on the end of the shortest (1 foot long) black wire - this is for the ground connection. Pictures are in order from steps 2-4 |
#3 |
STEP FIVE
Put together the remote wire - see my thread for that (I'm too lazy to duplicate it). STEP SIX Plug all the female connectors into the socket until the snap into place - you should hear a click if you have it facing the right way. The bottom of the realy should have numbers next to the pins (30, 85, 86, 87 and 87a). You should arrange it so that you can determine which pin goes into which hole on the relay socket IT IS VERY IMPORTANT THAT YOU PUT THE RIGHT SPADES IN THE RIGHT PLACE ON THE RELAY SOCKET. Put the positive terminal fuse holder into socket 87. Put the negative spades (black wires) into socket 86 Put the green trigger wire into socket 85 Put the remote trigger fuse holder into socket 87a Put the positive spades (red wires) into socket 30. I put a zip tie at the base of the relay socket around the wires to hold them together. |
#4 |
STEP SEVEN
Time to group the wires. First - I taped up the shorter red/black wires together. Second - I taped the longer red/black wires and the green trigger wire together for the first 2/3s of the length from the relay socket. You'll want to leave the green trigger wire loose after that so it can run to the ECU box. Tape the red/black wires together after that point so they can continue together to the driver side inverter. [This where the braided wire wraps would be very useful - don't use the plastic stuff b/c it's too think to run along the car - especially through the wire holder above the engine]. |
#5 |
STEP EIGHT
When you go to install the the wiring harness and connect it to the angel eyes - crimp on bullet connectors at the end fo the harness and on the inverter box too. I reversed the male/female for the pos/neg to make sure that I didn't hook the wires to the wrong wire on the inverter. Also - I left the T-taps loose for the trigger connections until I was ready to tap them. Crimp the T's when you're ready to actually connect them. If you do that you'll have an easier time running the wire(especially with the interior trigger wire b/c you have to push it through the firewall). |
#6 |
STEP NINE
Snap in the relay when you get finished install the harness and hooking them up to the angel eyes. Once you do that - you're done. Use these links for the DIYS: Jake's DIY ECU Trigger Wire Removing headlights Remote Kit install Remote if you don't have footwell lighting Last edited by Moeser09; 12-02-2004 at 09:02 PM. |
#7 |
you have no idea how many people will love you for this |
#8 |
Just trying to help out.
Here's a picture of that "inferior" ebay kit I put in my car. The rings are very distinct in person (I taped the back), but the dang rings are so bright that they glow in pictures. I haven't figured out how to take a good picture of them yet. |
#9 |
I always wondered about those ebay Rings. thanks for the excellent write up. i will consider this mod for my M3.
Laguna Seca Blue E46 M3 |
#10 | |
#11 | |
All you have to do is run it - open the picture, resize to 800x600 and then save it. When you save it - it'll pop up another window - uncheck all of those boxes or it won't save the file as a smaller file. Shrinks my pictures from 1.5megs to about 30kb for posting. I got my kit off ebay a while ago and paid a lot more than they're going for nowadays. For $130-140 ($100 for ebay angel eyes and $30-40 for the wiring harness parts), you will have CCFL angel eyes comparable to the $380 Phosphyres (w/ remote kit). Incidentally, on the harness I made, I used 16 and 18 guage wiring, but you might get away with something smaller, the Wheelpower harness uses something like 20 guage or smaller wiring, it's very thin. I also used waterproof fuse holders which cost about 50 cents more a piece than the non waterproof ones on the Wheelpower harness. So, there is some flexibility in the design (I guess you can also use inline fuse holders if you wanted to). Hmm, now I'm tempted to redo my wiring harness ![]() Oh yeah - another good link on the install. Last edited by Moeser09; 12-03-2004 at 12:12 PM. |
#12 |
Banned User
My Ride: E46 330 and E30 325
I just bought a set of the CCFL angel eyes from autotecknic. What would be the difference in wiring it into the parking lights and this? Are there any safety issues involved with wiring it to the parking lights?
#13 | |
#14 |
#15 | |
p.s. I have had them for 2 months and I do drive the car daily...so far so fire |
#16 |
thanks....don't have much time but lets see if it works and how the quality looks online. I will post more when I have a chance to crop the better pictures.
#17 |
My Ride: 2003 330Ci Sport PKG
Looks good BostonVK. I finally finished the other half of mine today. For those that do not know I had to wire them to my fogs. I am pumped. Can't wait to show them off. To bad I came across this DIY thread post hoc. Oh well. I will probably change up in the future because I have to turn my fogs on for my eyes to work.
#18 |
i also got a set from autotecknic.com and they are great!
#19 |
Very nice write up!!!
Here is a picture of mine installed. Link to DIY installation.
#20 | |
