Old 11-03-2007, 06:43 AM   #1
sniper123
My Ride: 330ci tm12
Projector Trim Removal
Hi all
Want to spray my pfl coupe headlight trims, to black or hyperblack, but there is a piece in between the high and low beams that is titan silver which *looks* removable but so far no luck...
Does any body have any idea whether this is possible?
I'll try and find a picture.
sniper123 is offline   Reply With Quote
Old 11-03-2007, 01:19 PM   #2
HighVoltage
My Ride: 2007 335i
It is removable, however you have to dissemble the headlights to get behind them. There are a couple pins that need to be squeezed together and are only accessible once the whole inner headlight is removed from the housing.
Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive...like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
HighVoltage is offline   Reply With Quote
