Sponsored by BAVSOUND
Old 12-15-2004, 10:50 PM   #1
djabaley
does anyone read my p0sts?
My Ride: 325 slushbox
question about wire into doors: rcurley55 - your advice would be good
Ok, so I was browsing the carsound.com boards today, and I ran across rcurley's sound domain page. Of particular interest was this bit about running wires into the doors: http://www.sounddomain.com/memberpage/656122/3
Preview:
Let me say that's the most helpful information I've ever seen about this issue. My question is this...
This is an excellent method. Does anybody have any other ideas? I'm in the final stages of re-doing my system, and I'm tired of compromising and using the factory wire. Also, I already have all of the speaker wire run, so there's no stopping now Any advice?
djabaley is offline   Reply With Quote
Old 12-16-2004, 12:17 PM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Why don't you and rcurley get a frickin room!
Seriously, what added value does 14 ga wire have over the factory 16 ga? Unless you are powering your mids by a couple of hundred watts, I don't think that there is any value added.
I like the install a lot... especially the PPI Art series amps.
Preview:
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-16-2004, 01:45 PM   #3
rcurley55
My Ride: 2001 IR M3 Coupe
haha, this thread is funny - I was going to post my method, but I thought I would wait for a bigger update....
This method will only work with something like a 14ga standard wire. You MIGHT be able to squeeze in two pair of 16 ga, or something larger if you used a Canare StarQuad speaker wire.
This method is so freakin easy it's scary - 15min a door tops.
Life's too short not to be M-Powered
rcurley55 is offline   Reply With Quote
Old 12-16-2004, 01:47 PM   #4
rcurley55
No cutting of factory system. With this method, the car goes back to stock...and the increased size can't hurt.
Thanks - I should be done by the first of the year because of all the time off I'll have over the holiday season.
Old 12-16-2004, 02:11 PM   #5
djabaley
bigjae owns me
Basically, when I got the car I didn't have a lot of time to work on it, but I knew that I would quickly grow tired of the factory system. What I did was do about half of the install myself and then use my normal shop to do the other half in terms of fabrication and the like.
Looking back on it now, I'm not happy with some of the compromises both I and they made. I just want djabaley's system version 2 to be the best I could muster.
Also, I already ran the speaker wire - so it's full speed ahead damn it.
Old 12-16-2004, 04:10 PM   #6
bigjae1976
bigjae1976's Avatar
Djabaley,
haha.
rcurley,
I know you have told me about the liquid glass stuff you used on your head unit trim. Where do I get it from and how does it work? Is it like pourable bondo?
Old 12-16-2004, 04:13 PM   #7
rcurley55
I didn't use liquid glass - that's something that tim ballie (www.hzemall.com) uses.
I used something from evercoat called icing - comes in a tube or can - pink label. I also used ultimate bondo and dynaglas
Old 12-16-2004, 04:27 PM   #8
bigjae1976
bigjae1976's Avatar
Sorry, I meant the dynaglas.
Old 12-16-2004, 04:30 PM   #9
rcurley55
dynaglas works just like bondo, only it's stronger b/c it has glass fibers in it. you can get it all kinds of places - i have tapplastics.com local to me. Just mix in the hardener and you are good to go.
I use it for structural things - like building up thickness in parts that are for trim only that I have fleeced, or to fill gaps in parts. It's pretty strong, but you get lots of air bubbles with it, and it doesn't spread very smooth - it's what I start with if I need to build up.
check out the build ups of alpine's demo cars, yato and brown live by the stuff...
Old 12-16-2004, 05:24 PM   #10
Jason@BavSound
My Ride: Cars/Trucks/Bikes
Combine dynaglass with fiberglass resin, and you get a speadable, sandable, evenly coated mixture. Use the liquid MEK hardener, and this stuff is incredible!
Extremely versatile!
We use it to line subwoofer enclosures, and for any application where smooth, evenly distributed strength is required.
For dash pieces, while it isn't necessary to use dynaglass, it certainly never hurts.
Chassis flex will crrrrraccckkk your dash pieces if they aren't up to par!!
Jason W. Seaver | Bavarian Soundwerks
i: www.bavariansoundwerks.com
e: jws@bavariansoundwerks.com
p: 678.388.9538
Jason@BavSound is offline   Reply With Quote
Old 12-16-2004, 05:42 PM   #11
rcurley55
intersting idea jason.....I like to add cab-o-sil filler to resin to make it a bit thicker - it's great for spreading on the outside/inside of a fiberglass part - self leveling - makes a flat surface, and would seal the box perfectly.
Old 12-16-2004, 06:58 PM   #12
Jason@BavSound
Another great thing about that mixture is that after you have made your initial mold for the enclosure, you can just pour it in like soup and slosh it around in there.
About 3 minutes later, its evenly distributed, and you can begin builing up your layers from the inside.
Very time efficient. We can get together a complete mold of the spare tire well, fabricate the enclosure, start to finish: two hours! Including covering the enclosure and loading it with a woofer!!
Give it a try. Just mix it until it is the consistency of really thick soup.
Don't forget that respirator!
p: 678.388.9538
Old 12-16-2004, 07:00 PM   #13
rcurley55
are you suggesting to lay down the first layer of glass, then this concoction, only to follow up with more glass?
Old 12-16-2004, 07:09 PM   #14
Jason@BavSound
No. What you do is frame your creation. Stretch mold fabric over it. Resin the mold fabric. Allow it to dry. Resin the mold fabric again, from the top.
Now, make the "concoction", and begin to build up your layers internally.
This eliminates all that crazy sanding of dynaglass, which SUCKS!!!
Just keep building up internal layers using the "concoction", and you're done in no time!!
Of course you'll still need to use some spray bondo on the surface to smooth things over, but you'll spend a minimum amount of time breezing through that with some 120 grit!!
p: 678.388.9538
Old 12-16-2004, 07:31 PM   #15
rcurley55
nahhh, not my cup of tea...
I prefer to stretch my fleece, then let cure for 24. once cured, I apply layers to the rear of knytex....I'd never use any kind of concoction like that for a structural part (i.e. part of a sub box). I could see that for a trim piece, but not for structure.
I never apply fiberglass directly to the "show" side unless absolutely necessary...
