Old 12-16-2004, 02:19 PM   #1
jstar41
My Ride: TopazE46|MontegoE92
how to replace low beam xenon bulbs?
guys.. i was searching for a DIY to change the xenon bulbs from my low beams and did not find anything good.. anyone knows how to swap these out??
JSTAR41
jstar41 is offline   Reply With Quote
Old 12-16-2004, 03:03 PM   #2
mikeson
My Ride: 99 323I
turn and out the block bulb holder plastic, then the bulb will come out.
good luck
OEM xenon retrofit, Auto light/rain sensor DIY, OEM fog DIY,..........so many things DIY since 2000 :)
mikeson is offline   Reply With Quote
Old 12-16-2004, 03:11 PM   #3
smood1
My Ride: slow323i
Bump...Yea I need to change a burnt out bulb in my headlights too...any links for a DIY...
smood1 is offline   Reply With Quote
Old 12-16-2004, 03:25 PM   #4
smood1
My Ride: slow323i
Just did a search this might help...
http://www.e46fanatics.com/howto/how...hp?howto_id=24
Old 12-16-2004, 04:40 PM   #5
mikeson
My Ride: 99 323I
Originally Posted by mikeson
...block bulb holder plastic,....
black bulb holder, sorry miss type.
Old 12-17-2004, 12:48 PM   #6
jstar41
is the only way to remove the bulb is by taking off the entire headlight enclosure??
JSTAR41
Old 12-17-2004, 01:26 PM   #7
mikeson
My Ride: 99 323I
No,
what year is yours? taking out the bulb, you don't have to take out the whole head light housing.
as I said before, just un screw the black ring type buld holder.
Old 12-18-2004, 01:58 AM   #8
jstar41
it's a 2001 325ci with OEM Xenon low beams..
No,
JSTAR41
Old 12-18-2004, 02:42 AM   #9
KillFox
KillFox's Avatar
My Ride: 2001 330xi
Send a message via AIM to KillFox
1) Take the dust cap off; being a 2001 it should be made out of hard plastic, and its a round piece on the back of the headlight.
2) turn the bulb ignitor (i think) that is black/red w/ a caution sign on it, and pull it off. Then simply pull the xenon bulb out of the headlight.
3) reinsert new bulb w/o touching glass and undo the previous steps.
If its your highbeams, you need to simply turn the locking ring on the black bulb holders that do not have a dustcap over them, and pull out. Then pull the bulb out of that holder, and place the new one in the old ones spot. Then reinsert the holder to the headlight and turn the locking ring the opposite way to lock it into place.
Sig by 325i-Vizon
KillFox is offline   Reply With Quote
Old 02-22-2006, 12:52 PM   #10
Born Again
Born Again's Avatar
Location: Tis quite a statement. Where do you live - where do we all live? in our minds? our souls? our bodies?
My Ride: She aint much 330ci
cool - im sitting on 6000k bulbs - in the go thanks!
best mod to date : OEM grocery bag holder
Originally Posted by Zell View Post
E46Fanatics - the Honda community of gun owners. Keep staying classy, I'm sure you all are going to be excellent examples of how to keep gun rights from being infringed. :facepalm:
Born Again is offline   Reply With Quote
Old 02-22-2006, 03:41 PM   #11
Born Again
Born Again's Avatar
wtf - one of them is fuked up
Old 02-23-2006, 07:21 AM   #12
JoeK
99% Stock
My Ride: 03 330
The manual should have pictures describing how to change them, not a hard task at all. The only problem is the left side because there's no space in that area. You have to shove your hand down there and hope things click together.
JoeK is offline   Reply With Quote
Old 02-03-2014, 04:27 PM   #13
TzuZen
My Ride: 2003 330 Ci Cab
The manual sucks. It's unusable for this change out of low-beam xenon bulb. In my opinion, it's intentional so we will go, like sheep, to the shop to get it done.
Rrrrrrrrrrrr
TzuZen is offline   Reply With Quote
Old 02-03-2014, 04:31 PM   #14
TzuZen
Mine is an '03. The dust cap appears to be a hard plastic cap 2.5-3.5 inches in diameter. I've looked at innumerable videos and I haven't seen anyone's look like mine.
Does that just twist off CCW? Or is it screwed in place?
I don't want to take the whole headlight assembly out. Frustrating.
Old 02-03-2014, 04:58 PM   #15
TzuZen
Dig a bit and I think I found what I was looking for here:
http://forum.e46fanatics.com/showthr...9544&highlight
I do ok on the DIY with some pics. I have small hands.
