Old 12-17-2004, 02:48 PM   #1
ACir
My Ride: 2000 328i 5 spd
Oil change how to?
Ready to make my first DIY oil change. But drain pan does not fit under car - too low to the ground. How do I do this? Do I use ramps to raise front end? If I do this will oil drain completely? This is my 3rd BMW and I never had this problem before. Any suggestions will be greatly appreciated.
ACir is offline   Reply With Quote
Old 12-17-2004, 02:52 PM   #2
berserker
My Ride: 2000 328i stick
drive up on some wood....
here is what you want to read....near the bottom is a 2000 328i.
http://forum.e46fanatics.com/showthr...highlight=jack
And remember to use the GOOD oil:
castrol Syntec 0w-30 (made in GERMANY only)
Mobil 1
or the BMW 5w-30 from the $tealership.
and make sure you torque the pan bolt and filer housing using a torque wrench!
berserker is offline   Reply With Quote
Old 12-17-2004, 03:24 PM   #3
SonTon2003
My Ride: 2002 BMW 330Ci
Why do you need to torque the bolt or the filter housing? Just tighten it.
SonTon2003 is offline   Reply With Quote
Old 12-18-2004, 03:29 PM   #4
stock328ci
My Ride: gas guzzler
then how do you reset the oil service mileage thingy when you first turn the key??
stock328ci is offline   Reply With Quote
Old 12-18-2004, 05:02 PM   #5
PCGuRu2K
My Ride: E70 X5M 2012
Send a message via AIM to PCGuRu2K
RESETTING OIL SERVICE INDICATOR:
If your OBC needs to be reset after completing your oil change, there are two ways. NOTE: If you miss a step, just turn the key back off and try again:
A. Model Year 1999 to Mid-2000: You should have the older round 20-pin DLC connector under your hood behind the battery terminal, you need to use a small length of wire to connect (short) pins 7 and 19 for 3-5 seconds with the ignition key in position 1 (Accessory).
B. After Mid-2000: You should not have the 20-pin DLC connector. You only need to hold the left odometer reset button while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done.
PCGuRu2K is offline   Reply With Quote
Old 11-02-2005, 11:19 PM   #6
mike greco
My Ride: M3
thanks
mike greco is offline   Reply With Quote
