Old 12-19-2004, 09:38 PM   #1
gcipriani
My Ride: 2000 323i Sport-Prem
Coolant (over)fill?
Just followed this DIY to change my coolant... http://www.bmw325i.net/maint_coolant_change.shtml
Very good DIY, excelent pics, good write up. Highly recommended.
To finish the job I Refilled the system, as instructed, adding coolant until it begins to come out of the bleeder valve opening, free of bubbles. Drove around a while, checked the level, it appeared topped off (no need - yet - to add any additional coolant.) So here is my question...
Is it possible to overfill to coolant systemt? Searched the forum, but could not find a definitive answer. If I did add too much coolant, will this be a problem? Will too much pressure build up in the system or will it "overflow" to allow access coolant to escape, and hence, not over pressure the coolant system. I am guess I am concerned that if there were too much pressure in the system this could result in a blown head gasket or something.
Appreciate any insight on this...
gcipriani is offline   Reply With Quote
Old 12-21-2004, 03:55 AM   #2
Solid
Solid's Avatar
My Ride: `07 335i Sedan
Send a message via ICQ to Solid Send a message via AIM to Solid Send a message via MSN to Solid Send a message via Yahoo to Solid
The Bentley manual states nothing about damage if you overfill coolant, but it DOES for oil. So you should be ok if you overfill the coolant . As a note i nearly topped off my coolant before and have had 0 problems.
Solid is offline   Reply With Quote
Old 12-21-2004, 11:23 AM   #3
gcipriani
Thanks for the reply. Clicked through to the link on your car - sweet ride! Tell me more about your ipod set up - links would be helpful... what did you use to hook into your head unit?
Old 12-21-2004, 02:41 PM   #4
JM8571
My Ride: 2002 325i
Would it boil or flow out of the radiator cap? The system pressurizes and expands at driving temperatures. It may make a mess, and steam up the engine compartment, but I don't think it'll hurt anything.
2002 325i
Orient Blue, SP, HK, Bi-Xenon
Shark Injected, Conforti CAI, B&M SSK, Rogue Power Pulleys, Koni Sports, Turner RSM
Exploring the space with my cowbell!
JM8571 is offline   Reply With Quote
Old 12-21-2004, 03:02 PM   #5
teamdfl
Slow in, slower out
My Ride: 325it
An over filled coolant system will push coolant out the cap and any overflow tube attached to the reservoir at the filler cap neck. It will do no harm to the car.
Ed
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 12-22-2004, 11:58 AM   #6
gcipriani
Thanks for all your replies on this.
Old 12-23-2004, 07:05 PM   #7
///Mechanic
My Ride: None currently
It is basically impossible to overfill your coolant level.
///Mechanic is offline   Reply With Quote
Old 05-11-2005, 12:23 PM   #8
kalakuta1
My Ride: 323i
Blue smoke coming from the engine compartment as a result of a leak in the coolant resevoir....what does that mean? This question goes to the gurus on this board. My car is at BMW right now and i am just awaiting a prognosis on it.
kalakuta1 is offline   Reply With Quote
Old 07-20-2005, 01:35 PM   #9
Zamorskii
My Ride: 1991 M5
I don't know if that is related to coolant overfill, which I think it does, but yesterday my expansion tank cracked, and all the fluid ran away.
$75 flatbed + $86 for the tank + $22 for a galon of coolant = $183 in out of the blue expenses,
so watch your coolant level on hot days boys.
Sergey
Zamorskii is offline   Reply With Quote
Old 07-20-2005, 03:32 PM   #10
ADA
Banned
My Ride: 323ci
I did a complete cooling system flush (plus change the theromstats + water pump).
I accidently overfilled my coolant to the very top of the expansion tank/reservoir in Northern California. I drove my car NON-STOP from N CA to Central Texas and nothing happened to my car. My engine compartment by the reservoir/intake area was a little messy with "white water stains." I guess the coolant couldn't expand so it just leaked out of the cap and was gushing everywhere.
ADA is offline   Reply With Quote
Old 12-03-2012, 11:20 PM   #11
bassoutwest
My Ride: 2005 330Ci
you can do damage...
You can do damage to your car by overfilling the expansion tank. The cap has a pressure release valve on it but as pressure is released it causes a sudden drop in coolant pressure resulting in flash boiling of the coolant. This can cause so much air to rapidly build causing the water pump to be less ineficient and thus a sudden overheating of the engine.
For those of you who have had your engine overheat will know that it is already overheating before the temp dial begins to advance...It happens in seconds hardly any time for you to react. May lead to a waped engine head, scoring of the cylinder walls and its not a cheap fix.
It happened to me although my issue was due to a blown cap seal...fortunatly I had time to react before major damage was done. Not worth it dont tempt it.
bassoutwest is offline   Reply With Quote
Old 12-05-2012, 08:20 PM   #12
7xWDC-MSC
My Ride: 2005 325xi
You're talking about a malfunctioning cap, apples and oranges compared to what was discussed here.
7xWDC-MSC is offline   Reply With Quote
Old 12-05-2012, 08:30 PM   #13
///MPR77
My Ride: 02 ///M3 Tri-Ped
Ok, so nobody has mentioned that there is a float, and you check the level when the car is cold/kalt.
The tip of the float at Maximum should be flush with the rim of the filler, if it has gone beyond that, just use a turkey baster, and suck out I believe 6-7 full baster tubes, regardless check it as you're doing this and you will be sitting at the proper level, and this won't even be something you will need to worry about.
If you overfill your ET, you're risking blowing, or at the very least prematurely stressing the plastic seams of your ET.
BMW put the float there for a reason, and that is to determine the proper level.
Also if your ET is old, be careful not to put too much pressure on the float stick with the turkey baster, as the float does get brittle with age and could break.
Good Luck
Old 12-06-2012, 03:04 PM   #14
///MPR77
/ withdrawn.
