Old 01-06-2005, 04:20 PM   #1
Rob Levinson * UUC Motorwerks
Rob Levinson * UUC Motorwerks's Avatar
My Ride: 7s, M5s, M3s, others
NEW! UUC stainless steel brake lines available for all E46 - intro special!
(actual product differs slightly in appearance)
"Performance tune" your braking system.
Stainless steel brake lines for improved braking performance
100% MADE IN USA and DOT-APPROVED
Original brake lines are rubber and can expand under the normal pressure of use. This expansion of the brake line negatively affects the brake caliper piston travel, and makes for mushy pedal feedback.
UUC's Stainless Steel Brake lines are used to "performance tune" your braking system.
* Inner TeflonŽ line is covered with woven stainless steel braid that will not expand under pressure. The advantages include better brake pedal feedback and a firmer pedal, along with superior brake modulation. Results will be immediate.
Technical features:
  • fully compliant with DOT Standards (MVSS-106)
  • lines burst-tested to 6000psi
    (maximum tested pressure from a BMW braking system is 1200psi)
  • TeflonŽ inner line covered with a woven layer of stainless steel and covered in an abrasion-resistant material (translucent blue plastic covering).
  • plastic end pieces protect assembly, no exposed steel fibers to stick fingers.
Introductory pricing:
$95 4-line kit for 1999-2005 3-series and M3
CLICK HERE TO ORDER
Professional installation recommended.
Installer responsible for correct fitting and bleeding procedure as recommended by BMW.
As brake line installation is a safety-related item, installer assumes all responsibilities and risks associated with brake line replacement.
(c)2004 UUC Motorwerks
- Rob Levinson * UUC Motorwerks * 678-679-5360 * uucmotorwerks.com
BIG BRAKE KIT HEADQUARTERS!
ALL CURRENT UUC SPECIALS:
-[ CLICK HERE ]
Rob Levinson * UUC Motorwerks is offline   Reply With Quote
Old 01-07-2005, 01:11 PM   #2
Updated Pic
This is the E46 kit:
Old 01-07-2005, 01:12 PM   #3
Staszek
Are we there yet??
Staszek's Avatar
My Ride: Now a daily drive
Send a message via AIM to Staszek
ohhhhhhhh nice!
Originally Posted by Rob Levinson * UUC Motorwerks View Post
What if leprechauns installed them while unicorns watched? :D - Rob
Staszek is offline   Reply With Quote
Old 01-07-2005, 01:33 PM   #4
opelrsx
My Ride: '04 330CI Mpack
Send a message via MSN to opelrsx
what are the benefits? Also, how about the installation costs?
2k4 330CI Mpack JET BLACK -- GONE
opelrsx is offline   Reply With Quote
Old 01-07-2005, 02:53 PM   #5
Alex
Mom says I'm a catch
Alex's Avatar
My Ride: E46
Send a message via MSN to Alex
He posted the benefit:
BTW, Very nice product Rob
A lap dance is so much better if the stripper is crying.
Alex is offline   Reply With Quote
Old 01-07-2005, 03:15 PM   #6
Installation is pretty easy, just uncscrew the original fittings and screw the new lines in. You have to bleed the brake system afterwards, but that's also a good idea (brake systems should be bled ever 12-30 months depending on usage style).
If a shop were doing the installation, figure 1-2 hours max. If you are already having a brake service done (new pads/rotors), then the lines should only add another 30 minutes' worth of labor.
- Rob
Old 01-07-2005, 03:25 PM   #7
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
If only this were a DIY install (I don't have a break bleeding system ) I would do it
Old 01-07-2005, 03:29 PM   #8
A pressure bleeder is really not that expensive... heck, a lot of people make their own from a Home Depot pressurized sprayer bottle, some hose, and a spare brake reservoir cap.
- Rob
Old 01-12-2005, 10:52 PM   #9
ADA
Banned
My Ride: 323ci
Rob,
Be HONEST with me Rob. I have already ordered the TSE3, UDP, and Shark injector from you. Therefore, all I am asking is for an honest answer.
For NORMAL driving, do I need these stainless brake lines. I have a little over 60,000 miles on my 2000 323i. Should I replace my brake lines.
You are killing me Rob! I am spending way too much money!!!!!!!!!!!!!!!!!!!!!!!!
ADA is offline   Reply With Quote
Old 01-12-2005, 10:56 PM   #10
vaio76109
My Ride: Race Cars
Originally Posted by ADA
Rob,
I know you asked Rob but my answer is no, you dont.
vaio76109 is offline   Reply With Quote
Old 01-12-2005, 11:19 PM   #11
Rob,
"Need"? No. You don't "need" any modifications. You don't even "need" a great car like a BMW. You can always get by with less.
But if you want improvements, if you want to fine-tune your precision driving instrument, then there are specific tools to do that job. Stainless steel brake lines are one such tool.
You will notice a change in brake pedal feel. It will be firmer, easier to modulate, less spongy, and certainly better in any DE setting.
Also, you should realize that brake lines are considered maintenance items. Many people ignore them, but they are supposed to be changed every few years as the OE-style lines get brittle with age and start to crack. If you've got a '99 or '00 model, the car really is due. For newer models, it's pre-emptive maintenance, but obviously an improvement at the same time.
- Rob
Old 01-12-2005, 11:32 PM   #12
Presns323i
No Show, No Go
My Ride: E46[Retired], 2.0T
Send a message via AIM to Presns323i
ahhhhhhhhhh let me think about this one.........
Presns323i is offline   Reply With Quote
Old 01-12-2005, 11:38 PM   #13
InSuboRdiNaTioN
Mmm, Pancakes.
InSuboRdiNaTioN's Avatar
My Ride: Collects dust.
Any idea how long the introductory pricing will last? And what the price will be after that? Thanks
Originally Posted by vincentvega9701
one moment, you're rolling. the next, you're blowing a guy for a sandwich
InSuboRdiNaTioN is offline   Reply With Quote
Old 01-12-2005, 11:42 PM   #14
JCz04Bimmer
JCz04Bimmer's Avatar
My Ride: 2004 330Ci & 06 Z4MC
Send a message via AIM to JCz04Bimmer
Saw these today over at UUC's shop. Very nice product and a decent price too. Too bad these came a few weeks to late. I just did a full brake pad/fluid change. No need to go through that process again anytime soon. Maybe in a few months?
JCz04Bimmer is offline   Reply With Quote
Old 01-13-2005, 04:55 AM   #15
KillFox
KillFox's Avatar
My Ride: 2001 330xi
Send a message via AIM to KillFox
lol you release them a week after I buy my new brakes and lines....
Sig by 325i-Vizon
KillFox is offline   Reply With Quote
Old 01-13-2005, 05:35 AM   #16
LakeShow
Millennium Bankers Mortgage
LakeShow's Avatar
My Ride: is almost finished!
Send a message via AIM to LakeShow Send a message via Yahoo to LakeShow
Sweet product Rob
Supporting Sponsors:
* DPE * Euro-Spec * Technik * WestCoast Auto Sound *
LakeShow is offline   Reply With Quote
Old 01-13-2005, 06:02 AM   #17
acitydweller
My Ride: e46 M3
those look pretty
Laguna Seca Blue E46 M3
acitydweller is offline   Reply With Quote
Old 01-13-2005, 07:49 AM   #18
I think the $95 program price is scheduled for a few weeks. After that, they may be $129.
- Rob
Old 01-13-2005, 10:17 AM   #19
Carbon_Fiber
Banned
My Ride: zoom zoom zoom..
How much is installation usually for such parts?
Carbon_Fiber is offline   Reply With Quote
Old 01-13-2005, 10:20 AM   #20
You get a brake fluid flush done at the same time. I would expect a shop to charge 2 hours or less.
- Rob
