Old 01-12-2005, 05:23 PM   #1
vmwerks
Past Site Sponsor
vmwerks's Avatar
My Ride: 330zhp Super Coupe
Send a message via AIM to vmwerks
Alignment angles
Exactly what is adjustable in terms of alignment for the front and rear on the E46 chassis?
vmwerks is offline   Reply With Quote
Old 01-12-2005, 06:14 PM   #2
InSuboRdiNaTioN
Mmm, Pancakes.
InSuboRdiNaTioN's Avatar
My Ride: Collects dust.
I can send you the alignment specs out of the Bentley manual if you like, that should tell you everything that is adjustable.
Shoot me an E-mail if you're interested.
Originally Posted by vincentvega9701
one moment, you're rolling. the next, you're blowing a guy for a sandwich
InSuboRdiNaTioN is offline   Reply With Quote
Old 01-26-2005, 04:43 PM   #3
Hellabad
Talking some answers:
FRONT: Only toe-in is adjustable easily. Many alignment shops will charge you a "2 wheel alignment" when they only set the front toe.
The camber actually is a teeeny bit adjustable, but only by unlocking the upper mount. The upper mount is unlocked by drilling out the little nubbie that is up through the body with the three mounting bolts. When you remove this nubbie, you never know which way you can slide the upper mount, but you can now slide it and adjust the camber.
Caster is NOT adjustable on an e46, and there actually should be no need for adjusting the caster unless you wreck the car. Adjusting, or actually correcting, caster should NOT be done with the upper mount because 99.999999% of the time, the caster error is from the bottom of the strut being bent, not the top.
REAR: Rear toe is adjustable on all e36 and e46 cars. This is also where error can accumulate to make the car steer to one side or the other (as opposed to "Pull" to one side or the other, but its the same result) A good alignment shop can use this to your advantage (thrust angle)
Rear camber is also adjustable on ALL e36 and e46, but I don't know why many shops say it is not, and try to weasel out of it. There must be some industry spec book or something that lists it as being non adjustable, but that would be incorrect.
Hope this helps, Jay Morris
Hellabad is offline   Reply With Quote
Old 01-26-2006, 10:49 PM   #4
tuckersmg
My Ride: 2005 m3
bolts
Can camber bolts be used on the M3 to get more neg dailed into the front end? I know the thread is only a year old but why not
tuckersmg is offline   Reply With Quote
Old 01-27-2006, 02:25 AM   #5
Bim Growl
Banned
Bim Growl's Avatar
My Ride: E86 3.2
Camber, Castor, and Toe are all you need to worry about... here is a useful chart, and instructions:
Name:	Wheel Alignment Specs.jpg
ID:	164001   Click image for larger version
Name:	Wheel Alignment Specs #2.jpg
Bim Growl is offline   Reply With Quote
Old 01-29-2006, 01:00 PM   #6
gbn
My Ride: 2002 325i
Great stuff! How much adjustment do you think there is? 0.5 degrees?
gbn is offline   Reply With Quote
Old 01-29-2006, 01:04 PM   #7
gbn
My Ride: 2002 325i
Alignment Kit
I have heard about camber bolts that you can get to make camber adjustments for the fronts. Don't know if they make them for E46. I think that these are for cars that have been lowered a lot or been in accidents and need to be adjusted.
Any one know more?
Old 01-31-2006, 04:29 PM   #8
Bim Growl
Banned
Bim Growl's Avatar
My Ride: E86 3.2
For camber, you can probably go up to 1.5 degrees neg. camber in front, and up to 2.5 degrees neg. camber in rear with the stock components.
If you add camber plates up front, you can go up to 3.5 degrees neg. camber.
If you add camber arms in rear, you can go up to 3.5 degrees neg. camber.
