Old 01-18-2005, 11:48 PM   #1
Pan
My Ride: BMW 323i
Question What to look for when buying used? (BMW 323i)
Hello all fanatics. I've been looking over the site for the last few days because i was looking for information about the BMW 323. I'm considering purchasing a 1999 323i with 75,000 miles, manual transmission. Here are the options:
POWER WINDOWS,LOCKS,MIRRORS AND MOONROOF,16" ALLOY WHEELS,DUAL POWER FRONT HEATED SEATS,DUAL FRONT AND SIDE AIRBAG,TRACTION CONTROL,XENON LIGHTS,AM/FM RADIO,SINGLE CD,KEYLESS ENTRY,SECURITY SYSTEM,TINTED WINDOWS,BLACK EXTERIOR WITH BLACK LEATHER INTERIOR.
I do not believe it has the sport package. The car looks like it is in excellent shape and is very reasonably priced (to me at least). I do not plan on modding it at all, which is why I'm not pursuing a 328i.
I am new to BMW, and this would be my second car purchase ever. What are some known issues with the 323's at this mileage point? Other concerns I should look for/have a dealer inspect? Any help would be greatly appreciated.
Pan is offline   Reply With Quote
Old 01-19-2005, 01:30 AM   #2
CC Nomada
My Ride: 98 ///M3/4/5 Silver
Send a message via ICQ to CC Nomada Send a message via AIM to CC Nomada
I have a 99 323i with around 73k on it. So far no real major problems luckily. One thing I would sugguest is remove the valve cover over the spark plugs and take a look. I replaced my spark plugs at 72,800 and found a small oil leak from a bolt between the 4th and 5th cylinder.
Also one of the first things you may want to do if you buy the car is change the spark plugs, especially if they are the originals. I think they are supposed to last till 100k or so. Mine probably would have but over the last 10k or so I've noticed a decrease in my MPG. I replaced my spark plugs with Denso Iridium IK20s. Few days after I changed them I had a friend (someone I drive with a lot) in the car and as I climbed past 3500 and shifted at about 5000 or so, he was like, "wow nice power and sounds nice too." To me they made a noticable differance, especially in the higher RPMs, they also seemed to give the engine a sweeter sound lower down in the RPMs too.
CC Nomada is offline   Reply With Quote
Old 01-19-2005, 09:48 AM   #3
Big Willy
My Ride: 2000 323CI
YEAH DONT FORGET TO SEARCH THIS SITE FOR INFO ON SUB FRAME DAMAGE.
YOU DONT WANT TO HAVE TO DROP 2-3 THOUSAND TO FIX THAT. I HAVE A 00 323CI AND HAVENT HAD ANY MAJOR PROBLEMS YET
Big Willy is offline   Reply With Quote
Old 01-19-2005, 09:51 AM   #4
Staszek
Are we there yet??
Staszek's Avatar
My Ride: Now a daily drive
Send a message via AIM to Staszek
While its really more prevelant on the coupes then the sedans I would have a mechanic/body shop check the subframe to make sure its not cracked, that is a known issue on the early model 3's. Like the other post, I would replace plugs check to make sure there are no leaks. My car is a 2000 323 with almost 114k on it right now and it runs really strong, had one major problem with the trans at 112k (manual) but that was fixed for $1300 which I dont think is that much considering how long I have had the car with really no problems.
Euro Delivery Thread
///M3-6MT:dance:
Staszek is offline   Reply With Quote
Old 01-19-2005, 10:28 AM   #5
richietherocket
My Ride: 323iT Wagon
Send a message via Yahoo to richietherocket
Things that have come up on my 323 Wagon are:
1--Try to find out if the control arms have been replaced. These are notorious for going out and it's about 350-400 bucks to get them fixed.
2--Brakes need to be replaced and that is another 300 or so. Unless you DIY and then it will be much less
3--Check for Subframe damage as already stated. You can pull the trunk mat up and then pull the two rubber plugs and shoot a flashlight down to see if there are any cracks
Good luck. Mine is a dream to drive. It has about 79000 miles on it and mine is a 2000. They will last forever if you do the maintanence on them
Rich
richietherocket is offline   Reply With Quote
Old 01-19-2005, 11:36 AM   #6
akhbhaat
Lying, drunken cheat
My Ride: German Civic
At 75,000 miles, things to watch for and replace:
-Control arms and control arm bushings (most cars will be on their second if not third set by 75k, assuming they've been cared for)
-Spark plugs will need replacement (I recommend between 50k and 60k, honestly)
-Transmission fluid should be changed
-Differential fluid changed
-Coolant flush
-Check for power steering leaks
-Windshield guard at bottom of windshield, probably will be cracking
-Wheel bearings (I had one go at 49k)
Common problems which may or may not appear upon inspection (but will likely occur sooner or later regardless):
-Sunroof shade
-Window regulator
-Control arm bushings
-Wheel bearings
Also check the alternator, power steering pump, radiator for leaks.
No significant quantities of judgment-impairing narcotics were consumed during or before the creation of this message.
akhbhaat is offline   Reply With Quote
Old 01-19-2005, 07:25 PM   #7
iverson2k10
My Ride: 2000 323i(sold) -
Send a message via AIM to iverson2k10 Send a message via MSN to iverson2k10
i got mine a used 323i with 100,000 miles yr 2000 for 10,500 and it got everything u have including cd changer in the trunk
iverson2k10 is offline   Reply With Quote
