Old 04-12-2002, 08:15 AM   #1
Gray Goose 330ci
Send a message via AIM to Gray Goose 330ci
Any DIY for foglights to be hardwired
Is there a way to hardwire the fogs to come on automatically when the regular xenon lights come on? Thanks.
Gray Goose 330ci is offline   Reply With Quote
Old 04-12-2002, 09:22 AM   #2
.Gravedgr.
Got M?
My Ride: '02 CBM M3
Send a message via AIM to .Gravedgr.
I'm pretty sure a thread started on this on the old forums, or on ************* earlier in the week. The last post I remember was something along the lines of "you need to hardwire it to your low beams" or something like that. Not very helpful, but there could have been more.:smile:
Past Present
.Gravedgr. is offline   Reply With Quote
Old 04-12-2002, 09:42 AM   #3
PowerDrift
can ya spare some change?
My Ride: 2000 323i
It not hard to do, there are 2 ways of doing it
1) You can either tap the wire going into your low beams and connect it to your fog lights
or
2) You can rewire the car from your relays and fuse box. This method is a little harder, but much cleaner. I did this for my friend's e36 328i before, but its been too long for me to remember what I did exactly. It took me a while to trace the wiring back from the relays to the fuses. Take a look at the DIY instructions for fog light instruction for the e46 on the circle BMW site. It will give you a better idea of what is going on.
Basically, you will use the power coming from the relay of your lowbeams instead of using the relay for the fog lights. The ground stays the same.
I prefer method 2 since its easier to undo and maintain's the use of the fog light's fuse.
HTH
PowerDrift is offline   Reply With Quote
Old 04-12-2002, 10:31 AM   #4
euroboy
My Ride: 328Ci
One day I am hopping to be able to send K-bus messages - this gives a total control over all devices connected to the K-bus ( which includes the lights ).
Peter
euroboy is offline   Reply With Quote
Old 04-12-2002, 10:43 AM   #5
.Gravedgr.
Got M?
My Ride: '02 CBM M3
WTF are K-bus messages? Is that like Morse code with your headlights?
Past Present
Old 04-12-2002, 11:13 AM   #6
euroboy
My Ride: 328Ci
When you press a switch on the steering wheel it now generates K-bus messages - most things are not hardwired in the car - they connect to a bus(es).
If you like to find out more, pick up a copy of the Bently E46 manual - great read ( about $80 ).
Peter
Old 04-12-2002, 12:38 PM   #7
Gray Goose 330ci
Peter
So our cars have hidden electronic features which we may possibly unleash?
