Australia
Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 4.50 average.
Old 09-04-2012, 04:59 AM   #3421
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
Bulbs out and coolant
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
Old 09-04-2012, 08:05 AM   #3422
shook
My Ride: E46 328ci
Yeah I know what the bulbs were lol.
Coolant light went off after a but but just double checked and it just needed half a water bottle.
Sent from my GT-N7000 using Bimmer App
shook is offline   Reply With Quote
Old 09-05-2012, 09:35 PM   #3423
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
http://www.ebay.com.au/itm/BMW-E46-2...item4166c3ba9f
Pulo?
E46 Coupe is offline   Reply With Quote
Old 09-05-2012, 11:01 PM   #3424
CortinaD
My Ride: lots
Originally Posted by DeclanM3 View Post
A video of how I lost said tow hook cover for those interested...
Looks like you had a few moments How'd the car go?
CortinaD is offline   Reply With Quote
Old 09-05-2012, 11:15 PM   #3425
YGOAMG
Originally Posted by E46 Coupe View Post
Nah ..
kinda want that extended boot handle though...
@PeterMarquez346
who da F done that?
Old 09-05-2012, 11:58 PM   #3426
JS330
My Ride: '01 330Ci 3 Pedals
Originally Posted by YGOAMG View Post
Nah ..
I rang that guy from a tip off from E46 Coupe about led harness and the guy that answers is a complete cvnt
Wanted $120 per harness for each tail light....FOR AFTERMARKET HARNESS. WTF?!?!?
I hope he isn't using Pirelli condoms..
JS330 is offline   Reply With Quote
Old 09-06-2012, 12:00 AM   #3427
YGOAMG
What do u mean harness?
@PeterMarquez346
who da F done that?
Old 09-06-2012, 12:01 AM   #3428
E46 Coupe
E46 Coupe's Avatar
LOL.. like every BMW wrecker.. a complete twat!
I think if you ask Jall very nicely he can try and flash your LCM for you...
Old 09-06-2012, 01:13 AM   #3429
DeclanM3
My Ride: 332Ci
Car went really well considering. Didn't want to use 2nd gear due to the diff problems so couldn't push it 100%, probably not such a bad thing though I still had an absolute blast!
Interestingly the 'moments' in all the YouTube videos were all intentional on in laps. I wanted to push the limit of grip and see how easy it is to predict and then recover once grip was lost. Turns out it's incredibly easy to spot and recover from.
I only had 1 real moment where my heart had a brief pause. The first corner can be taken at about 130kmh in my car after hitting 180+ on the straight. I hadn't been getting perfect runs out of the last corner as I was wary of the wall, I had also struggled with my braking point and entry into the first corner, I felt I was braking too early. Anyway, I addressed both issues at once (better run out of the last corner then later braking). Needless to say I missed the apex by a couple of metres. Still was no where near close to running off or spinning though
Did you see my post in the thread relating to the diff bush?
DeclanM3 is offline   Reply With Quote
Old 09-06-2012, 01:34 AM   #3430
CortinaD
My Ride: lots
Yeah, you are lucky you have a track that can get up to those speeds, ours there is really only a couple of spots where you can get up to 170/180 depends on the power. I have 2 track days next week, the weather has been **** here for the last few so I am hoping it improves for next week
How did the rest of the car go with the street tyres, brakes etc - they held up ok? How were your seats? I am getting annoyed with sliding around in the stock seats with the factory belts because they don't hold you in.
Old 09-06-2012, 03:51 AM   #3431
Jall
My Ride: 328Ci
This I can do.
If I make it out to the SAM I'll bring my laptop for anyone that wants any coding done.
Think I need a bigger toolbox, spending more time rearranging the tools than I do using them. Or I can just stop buying more stuff.....
Anyone got any bargain hookups?
Jall is offline   Reply With Quote
Old 09-06-2012, 07:27 AM   #3432
DeclanM3
My Ride: 332Ci
Tyres were alright considering they are cheapies that were on the car when I got it. They got hot after a few laps of pushing them and started to lose grip, wasn't really an issue though.
Brakes were fine. I bled the brakes and put in RBF600 but didn't bleed 100%. I followed the instructions 100% but the pedal was a tiny bit squishy. Will need to get that fixed. I also lost a couple of chunks from my front right brake pad which was the one under the most stress. I suspect they are old pads so I've ordered stoptech street performance pads.
Also seem to have developed a humming noise under brakes which sounds like it could be due to the farked pad or there being pad deposits. Hoping the new pads and a bit of 600 grit sand paper can fix the issue.
When I do the front diff bush I'm also doing the rear cover, seals, oils and rear bolts. Is there anything else you recommend I do whilst the diff is out?
Old 09-06-2012, 07:53 AM   #3433
YGOAMG
Understood Declan, Plan A is working well, Plan A
Every thing seems fine, pace is good
@PeterMarquez346
who da F done that?
Old 09-06-2012, 07:57 AM   #3434
JS330
Im not sure if my car can be programmed for LED's
july/01 build date :S
The aftermarket LED tail lights come with an adapter harness with capacitors and resistors in them to stop bulb out warning and the check voltage spikes, so i wanted some to make a harness out of but I'm pretty handy with a solder iron
Do you guys think $400 for a full led tail light set with harness and internal boot lights is a fair deal?
Originally Posted by Jall View Post
This I can do.
That would be amazing Jall! even If I don't get the tails, I really would love my unlocking to trigger the lights to flash twice!!
Old 09-06-2012, 08:08 AM   #3435
Tiag46
My Ride: e46
Not really, I got my OEM's LED tails for cheaper than that!
Im pretty sure you can get new ones cheaper off ebay.
*Wrecking* - Heaps of parts available.
http://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is offline   Reply With Quote
Old 09-06-2012, 08:38 AM   #3436
JS330
That is off ebay, and it didnt sell
Im going to low ball him 250
Old 09-06-2012, 08:46 AM   #3437
DeclanM3
My Ride: 332Ci
Who's P1? Dwayne or?
Old 09-06-2012, 05:43 PM   #3438
YGOAMG
Yes but he hasn't pitted yet. We think his going for a longer stint on the primes.
Should we try one in Italian? Like Alonso and Andrea??!! Hahaha
@PeterMarquez346
who da F done that?
Old 09-06-2012, 06:23 PM   #3439
DeclanM3
My Ride: 332Ci
Cazzo piloti di GP2!
I have a feeling this would've been said in Spa...
Old 09-06-2012, 07:00 PM   #3440
YGOAMG
Sh1t GP2 driver??
Btw go check my prediction for monza... I've put a certain Brazilian in the top 5 !!
@PeterMarquez346
who da F done that?
Rate This Thread
