Australia
Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 4.50 average.
Old 10-31-2012, 11:11 PM   #3541
DamoBMW
My Ride: '02 325Ci M-Sport
'02 BMW 325Ci 5MT M-Sport Individual Stratus Grey
DamoBMW is offline   Reply With Quote
Old 11-05-2012, 12:30 AM   #3542
Ballistic325
My Ride: slow and steady
Plus.... another VIN decoder in case you have not seen this before. Taken from another thread on the forums:
http://www.bmwvin.com/
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 11-05-2012, 06:59 AM   #3543
DeclanM3
My Ride: 332Ci
M3 driveshafts... No fun!
I think I might get a sticker made up "Breaking drivetrain components like a boss".
DeclanM3 is offline   Reply With Quote
Old 11-05-2012, 08:06 AM   #3544
Ballistic325
That sux. Legacy problem or something you did yourself?
I can help with
* RTABs
Old 11-05-2012, 09:13 AM   #3545
DeclanM3
My Ride: 332Ci
To be honest I'm not entirely sure. I did do a couple of launch controls at the drag strip but I'm pretty confident the issue was already apparent before this. I guess the launches could've aggravated the situation. So hard to tell as originally it just felt like DSC was kicking in. It wasn't until the issue got worse and I replicated it with DSC off that I realised something wasn't quite right.
Old 11-05-2012, 06:13 PM   #3546
rossim3
My Ride: myki
So is it fixed now? Have you done any launches to verify?
What's 50 grand to a ma'fkr like me? Can you please remind me.
rossim3 is offline   Reply With Quote
Old 11-05-2012, 06:25 PM   #3547
DesiredM
My Ride: E46 M3
Did you find at all when you accelerated hard that 2nd gear just had a flat patch like the car died and went back to normal when shifted into 3rd?
DesiredM is offline   Reply With Quote
Old 11-05-2012, 06:57 PM   #3548
DeclanM3
My Ride: 332Ci
Yeah did some hard pulls in it last night up hills etc. it's torque related so launches wouldn't easily replicate the issue as there isn't much stress on the driveshaft when you're spinning the wheels.
The issue was worst when accelerating in 2nd from low revs to 4,000 up a hill. I did plenty of these last night to test it and its smooth as silk now
It feels so good to be able to drive the thing properly!
I still can't chirp into second gear though. Although I don't change with my foot flat. I lift off slightly to put less stress on it. Maybe that's the problem. Or the 275's :-/
Nope. Never experienced anything remotely similar to that sorry mate. The power is linear and constant.
Do you have an issue where you lose power?
Old 11-05-2012, 07:35 PM   #3549
rossim3
My Ride: myki
Great to hear! All sorted now just in time for summer! Burnouts, Bitches and Beaches
Old 11-05-2012, 08:06 PM   #3550
DesiredM
My Ride: E46 M3
Yeah there are a few times where I have launched from a stop and shift into second and it's like the car hits a flat spot and drops to about 2000rpm and once it hits about 3000rpm it picks back up. I'm sure it was the DSC kicking in because of the crappy tyres I have on rear (that the dealer put on so it would pass road worthy haha)
Old 11-05-2012, 08:25 PM   #3551
ating
My Ride: 2004 M3
^ Turn DSC off and try again? It's obvious when DSC kicks in...feels like the car has died.
Evolve CSL airbox w/Alpha-N tune | KW v2 | Vorshlag Camber Plates | WORK Equip 18x10/12 | Dixis Ti exhaust
ating is offline   Reply With Quote
Old 11-05-2012, 08:27 PM   #3552
DesiredM
My Ride: E46 M3
Yeah it must be the dsc it's like the power is cut, time for new tyres
Old 11-05-2012, 08:40 PM   #3553
DeclanM3
My Ride: 332Ci
Is that the E46F equivalent of GTL?
Old 11-06-2012, 03:53 PM   #3554
CortinaD
My Ride: lots
Good to hear its all sorted now Declan.
CortinaD is offline   Reply With Quote
Old 11-06-2012, 04:43 PM   #3555
DeclanM3
My Ride: 332Ci
Cheers Dwayne. A few months and a few grand later haha.
It's so good to be able to drive the thing properly though and not have to limp away from traffic lights at the speed of a Getz (no offence )
Old 11-06-2012, 05:05 PM   #3556
CortinaD
My Ride: lots
Hahaha none taken, I gave the getz to my mum a couple years ago - I've had 2 new dailys since then.
While your M3 is running, mines at home broken Not sure the extent of the damage yet probably needs new cooling system as it was running on the red zone all day and I was focusing on that so much I broke my flippers and snapped some under tray supports etc after running wide. A quick pitstop to get a posit note to cover up the coolant gauge stopped me looking at it and I actually did some good times despite the temps.
Old 11-06-2012, 05:17 PM   #3557
DeclanM3
My Ride: 332Ci
Haha. So balla he keeps tracking the car when the coolant is in the red. Any idea what it got up to?
Old 11-06-2012, 05:24 PM   #3558
CortinaD
My Ride: lots
Oil temp was sitting at 120 so it isn't as bad as it sounds but it still needs to be addressed.
I'll plug the computer into and see if it threw any codes on the weekend.
Old 11-06-2012, 10:22 PM   #3559
DeclanM3
My Ride: 332Ci
I generally get to around 110-115 for oil and mid 90's for coolant on track days.
What do you think the issue was? Can't have been expansion tank if the temps were that low, fans would do nothing at the track.. Low coolant or thermostat?
Old 11-06-2012, 11:39 PM   #3560
CortinaD
My Ride: lots
I did the coolant 3 or 4 months ago so thats ok, coolant tank is ok, so only water pump/thermostat/radiator left. I'll replace the thermostat first and see how that goes.
It was 40 degrees track temp.
Rate This Thread
