Australia
Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 4.50 average.
Old 04-27-2010, 06:55 AM   #1841
AussieM3
Location: Sydney, Australia ( Best Country In The World !)
My Ride: 2002 e46 M3 SMG Coup
Originally Posted by CortinaD View Post
Bummer. Yeah will try this first, hopefully fixes the problem. The car has 64k on the clock so it cant be too major.
Well fingers crossed mate., i hope it works, but mine had only done 83k and i was told its quite common between 60k and 90k. found out the exspensive way, that is I was told by the stealer that the Alt was fine and that it was only the battery so I bought a battery first another $400. But interesting enough, mine went after i had not driven it for about 6 weeks also then drove it a short distance and then the next morning when i when to drive off the red battery light came on.
AussieM3 is offline   Reply With Quote
Old 04-27-2010, 06:59 AM   #1842
AussieM3
oh and I forgot to add. If you overnight charge your battery with a trickle charger and your Alt is stuffed you have a range of 37klms before your run out of spark. Just so you dont get stuck like I did when waiting for the part to arrive...
Old 04-27-2010, 07:28 PM   #1843
CortinaD
My Ride: lots
I trickle it but will leave it in the shed until I sort it out. Will let you know, cross fingers its only the reg.
CortinaD is offline   Reply With Quote
Old 04-28-2010, 06:40 AM   #1844
ASSAIL
My Ride: E46 328, Jza80 Supra
lol, less if you have the stereo, lights and wipers on
oh, and anything with DFI (piezo injectors) youve got about 1km of driving, those suckers draw shitloads of voltage
ASSAIL is offline   Reply With Quote
Old 04-28-2010, 06:52 PM   #1845
AussieM3
Are they (piezon injectors) worth the investment? What sort of gain would you expect?
Old 04-29-2010, 01:02 AM   #1846
2filthy3
My Ride: e46 m3
If you want to buy the new car to put around them. Direct fuel injection, not a DIY upgrade, unless maybe you have an old diesel.
2filthy3 is offline   Reply With Quote
Old 04-29-2010, 05:21 PM   #1847
dvscoupe
My Ride: BMW E46 318i
Send a message via MSN to dvscoupe
I spent a couple of hours last night installing the new springs in my sedan to find that the 245/30/19 Kuhmo's on the 19x9.5 CSL rims scrub like an absolute bastard. I had to put the king springs back in the back it was that bad
The rim sits level with the guard. Is there anything I can do with the inner guard? or should I just look at smaller tyre?
dvscoupe is offline   Reply With Quote
Old 04-29-2010, 05:24 PM   #1848
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
^^ roll the guards
and smaller tyres
although alot of ppl think that 245 on 9.5's is already too small
but if the rim is sitting level with the guard, the actual rim will rub, even if u get smaller tyres
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
Old 04-29-2010, 05:30 PM   #1849
dvscoupe
the tyres clear the guards but it hits the inner guard about 2-3 inches above the outer guard lip.
Really annoying as I'm concerned that I won't be able to go smaller on the 9.5" rim and I'm not a fan of the stretched tyre look.
Old 04-29-2010, 06:18 PM   #1850
dvscoupe
u wont fit a 255 on there if u intend to run it low.
im using kw's on the lowest setting with continental 245/35/19's on the rear (same offset and width rim as you listed) and i had to lip the rear guards slightly
heres pics:
I found this in another thread, with the new springs I have it sits like that but scrubs. How did they run the exact same setup and rims without the hassles??
Old 04-29-2010, 06:22 PM   #1851
YGOAMG
^^ his rolled the guards im pretty sure
and also Conti tyres have a more rounded sidewall than other tyres
@PeterMarquez346
who da F done that?
Old 04-29-2010, 09:41 PM   #1852
dvscoupe
I just had another look and my car actually has 255/30/19 Kuhmo's under it. The rims are 19x9.5 and I'll check the offset tonight. The rim and tyre package was on the car when i got it. Doing some reading tells me that these will scrub
Old 04-30-2010, 12:38 AM   #1853
shannon1
shannon1's Avatar
My Ride: 2001, 318i
Hey dvscoupe, when you pulled out your king springs, did you find out what type they were and if they had been cut or not?
Also, did you get any final pics of your car with the kings still in once they had settled and before you put the new springs in? Would be interesting to see the before and after pics.
Shannon.
shannon1 is offline   Reply With Quote
Old 04-30-2010, 12:45 AM   #1854
dvscoupe
yeah they where originally King Spring Lows which had been cut. I do have some photo's somewhere of it with the kings in it but they had been chopped.
Cheers
Dion
Old 04-30-2010, 01:00 AM   #1855
shannon1
shannon1's Avatar
My Ride: 2001, 318i
Damn, I'm looking to get a set of king lows and was going to offer to get your old ones, but since they're cut, no thanks.
Shannon.
Old 04-30-2010, 01:09 AM   #1856
YGOAMG
Cheers
Dion
Baller
@PeterMarquez346
who da F done that?
Old 04-30-2010, 04:47 AM   #1857
ASSAIL
replied to pm
Originally Posted by YGOAMG View Post
^^ roll the guards
and smaller tyres
na rim wont rub, the tyre will though
u wont fit 255's on there at anywhere near that height
nope, not rolled
combination of cutting and some persuasion
Old 04-30-2010, 05:42 AM   #1858
dvscoupe
It's taken a lot of massaging but it is nearly done.
Pics in the E46 Sedan thread
Old 04-30-2010, 09:15 AM   #1859
ASSAIL
looks good man. still got the 255's on there?
Old 04-30-2010, 04:47 PM   #1860
dvscoupe
yeah man but i'm still having a couple of scrubbing issues
Rate This Thread
