Sponsored by The Tire Rack
Old 02-22-2005, 02:12 PM   #1
NY323i
Meathead ///Member
NY323i's Avatar
My Ride: My Bike...
Losing 5 lbs per wheel..
Hey fanatics, im looking at superleggera 19x8 at 21 lbs and asa ar1's 19x8.5 at 26 lbs. Would the reduction of 5 lbs per wheel help out alot in performance for my 323? This is what is stalling my purchase right now.Any opinions are appreciated.Trying to not spend much either.
thanks
NY323i is offline   Reply With Quote
Old 02-22-2005, 02:13 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Yes, 5lbs in wheel weight is ALOT. It's rotational mass, meaning it weighs a lot more in terms of actual weight as it needs to be rotated instead of just pulled by the car.
Old 02-22-2005, 02:15 PM   #3
BMW3
My Ride: C32 ///AMG
i went from acs type 3 (24.5 pounds each) to bbs rg-r (19 pounds each) and i definitely notice a difference when accelerating
The Ultimate Driving Machine
BMW3 is offline   Reply With Quote
Old 02-22-2005, 02:17 PM   #4
Dalton
I'm hot 'cause I'm fly
My Ride: goes wshh
screw em both, get 18" ssr comps...15lb a pop
Dalton is offline   Reply With Quote
Old 02-22-2005, 02:19 PM   #5
ice_man
My Ride: is collecting dust
Send a message via AIM to ice_man
if you want to the bets combination of performance & looks, you have to go with 18"s, screw the 19"s if you care a lot about performance.
Tiefer, Breiter, Schneller!
ice_man is offline   Reply With Quote
Old 02-22-2005, 02:22 PM   #6
NY323i
Meathead ///Member
NY323i's Avatar
My Ride: My Bike...
Im stuck in the middle about performance and looks thats why im having a hard time deciding.I just want something that wont hurt my 323i performance,and something that is either a dark color rim or a rim i can powdercoat the center
Old 02-22-2005, 04:27 PM   #7
L-I-B
My Ride: makes my day
same position
L-I-B is offline   Reply With Quote
Old 02-22-2005, 04:35 PM   #8
S2Krazy
A Flammable Plumber
S2Krazy's Avatar
My Ride: ****ED UP CL
Send a message via AIM to S2Krazy Send a message via MSN to S2Krazy
S2Krazy is offline   Reply With Quote
Old 02-22-2005, 05:00 PM   #9
unionjack
Conceited Prick
unionjack's Avatar
My Ride: 997.2 C2S | ML350
I believe 1lb of unsprung weight is equivalent to 7lbs of sprung weight.
unionjack is offline   Reply With Quote
Old 02-23-2005, 05:18 PM   #10
coocoohead
My Ride: bmw 330ci
Wow.....
coocoohead is offline   Reply With Quote
Old 02-24-2005, 10:00 AM   #11
Blue
My Ride: car
thanks
those ASA AR1's in 18" are 24lbs, 17" are 21.2lbs. If you want 19"s, go with the 5lbs lighter superleggeras.....they weigh the same as the 17" ASA's!
how much are those superleggeras?
Blue is offline   Reply With Quote
