Sponsored by The Tire Rack
Old 02-23-2005, 12:08 AM   #1
Mrbanshee
My Ride: 2001 330i
Send a message via AIM to Mrbanshee
Tire Size Question
I have a 2001 BMW 330i with the sport package M double spoke 68 rims. The front rims are 17 x 7.5 and the rear rims are 17 x 8.5. The stock sizes are 225/45-17 on the front and 245/40-17 on the rear. I wanted to know if a 235/40-17 could fit safely on the 17 x 7.5 rim. I also wanted to know if a 235/45-17 could safely fit on the 17 x 8.5 rim? Thank you very much and God Bless.
Mrbanshee is offline   Reply With Quote
Old 02-25-2005, 12:54 AM   #2
325 & 55
My Ride: 2001 325Ci Step
Staggered set up & tire sizes..
IMO you are currently running the best tire set up (looks & performance) for the staggered 17x7.5 and 17x8.5 wheel combo. I'm currently running the same set up with my OEM Style 71's, and there's plenty of meat in the back. The section width on a 245/40 is 9.77.
FYI, according to my Goodyear Eagle F1 GS-D3 tire spec guide: the approved rim with for the 235/40-17 (section width 9.50) is 8.0 - 9.5. The approved rim width for the 235/45-17 (section width 9.30) is 7.5 - 9.0.
325 & 55 is offline   Reply With Quote
Old 02-25-2005, 01:45 PM   #3
Mrbanshee
My Ride: 2001 330i
Thanks. I went to the Bridgestone tire site and looked up the rim size specs and spoke with Tirerack. Then, I called Bimmerworld and spoke with them. I am going to stick with the factory tire sizes. I thought I could change the handling characterics by changing tire sizes. I realize that the only way to get neutral handling is through more serious custom suspension set-ups.
