Closed Thread
Old 03-08-2005, 01:42 AM   #1
Hartge330Ci
My Ride: Depends on the day..
Send a message via AIM to Hartge330Ci
Just found US version of hidden menu....
I had it in German, which I can read fluently, but didn't really want to translate it. Well, I just found the US version flipping through my Bentley service manual on page 620-4 and 620-5. I do not have a scanner, but can someone scan this on here, so it's on this site?
Sponsored by:
Wheelpower
JLevi Streetwerks
LeatherZ
Bimmerfreak
Thank you Stoptech !! My newest sponsor!
Hartge330Ci is offline
Old 03-08-2005, 02:20 AM   #2
InSuboRdiNaTioN
Mmm, Pancakes.
InSuboRdiNaTioN's Avatar
My Ride: Collects dust.
Give me a name of the page or something so that I can search my Bentley CD and pull it up, and then take some screen shots.
Unless it is the same info as this:
Instructions to access the hidden OBC functions:
1. Hold Trip Reset while turning ignition key to on position
2. OBC should show "Test"
3. Use Trip Reset to select function 19.0 that unlocks all the features
3. Wait for display to show "Off"
4. Depress Trip Reset for 1/4 second and release it
5. With no delay press Trip Reset several times to select one of the following function s
BMW E46 On-Board Computer (OBC) Hidden Codes
nr example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
Originally Posted by vincentvega9701
one moment, you're rolling. the next, you're blowing a guy for a sandwich
InSuboRdiNaTioN is offline
Old 03-08-2005, 02:27 AM   #3
Hartge330Ci
That's it.
Sponsored by:
Wheelpower
JLevi Streetwerks
LeatherZ
Bimmerfreak
Old 04-01-2012, 02:42 AM   #4
CrazyOneToo
My Ride: 1999 328i 4dr
00 End of test
Can I set my car to auto lock the doors after taking off by using this menu or is that a bmw programming issue??
Right now my car does not lock them for me.
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline
Old 04-01-2012, 02:45 AM   #5
Guest021715
Account closed.
No you can not. Purchase the BMW Scanner 1.4 from xcar360.com. It is $32, and its a code scanner/programming tool that every E46 owner should have.
Guest021715 is offline
Old 04-01-2012, 04:29 AM   #6
CrazyOneToo
Kewl that looks like just what I need.
Since my car has the underhood port also should I get the adapter....
(16 pin female to 20 pin male)
Old 04-01-2012, 07:34 AM   #7
shanneba
My Ride: 2003 330Ci
Yes you need the adapter to read anything besides the OBDII engine emission data.
Connections to any other system/module will be through the 20 pin port under the hood. (ABS/Air bag?DSC/Transmission, IHKA, GM5 etc)
Join BMWCCA
shanneba is offline
Old 04-01-2012, 08:22 AM   #8
Dirty330i
My Ride: 04 330i, 07 Z4M
Is this the case for all our cars or b/c he has an older model? I just ordered PA Soft and didnt think I needed the 16-20 pin adapter?...
Dirty330i is offline
Old 04-01-2012, 09:03 AM   #9
shanneba
My Ride: 2003 330Ci
Lots of great E46 info in the Wiki-
http://www.bimmerfest.com/wiki/index...vice_indicator
It only applies to the cars with the 20 pin socket under the hood. I believe model years 1999 - mid year 2000 have the 20 pin connector.
When BMW removed the 20 pin socket under the hood, all modules/systems can be accessed through the 16 pin connector (the ONLY one the new cars have)
Join BMWCCA
shanneba is offline
Old 04-01-2012, 09:15 AM   #10
Dirty330i
Ah ok thanks that was what I thought but when I read your earlier post I thought I ****ed up and should have ordered the adapter.
Thanks again
Cheers
Old 04-01-2012, 12:51 PM   #11
CrazyOneToo
OH that's great!!! I got the trial version. LoL
I will order the adapter cable when I order the scanner.
I wont need the technical stuff tho. Just want to be able to change settings without going to a dealer...
auto door lock, window function, daytime running lights, etc.
BTW What lights are on when the DRL are enabled and what would be the difference between EU, US, and US2?
Thanks for your help!!!
Old 04-01-2012, 10:44 PM   #12
fire730
My Ride: 01 325iT - 04 Burb
This is all I need to disable my DRLs? I have an 01 325iT. Just making sure.
Why does everyone say the dealer has to do it for $100+ or an Indy with a GT1?
fire730 is offline
Old 04-19-2012, 07:25 PM   #13
tmckinl
My Ride: Jet Black 1999 328i
Send a message via ICQ to tmckinl
only windows XP?
Anyone used this device with Vista or 7? The site says it's only compatible with Windows XP. Who still has a computer with XP on it?
tmckinl is offline
Old 04-19-2012, 07:59 PM   #14
Kayoige
My Ride: 2000 323I
I got it up and running with the 20 pin connector on Windows 7 64 Bit.
Make note that without the 20 pin you can still view and clear codes, you just cant code anything (enable/disable features).
Kayoige is offline
Old 04-19-2012, 08:35 PM   #15
Guest021715
Account closed.
Yes. People are ignorant of their options or just too lazy to do it themselves, so they end up overpaying.
Fully compatible with Win7 32-bit. 64-bit requires a workaround.
323/328 owners (any BMW under 2000MY) require the 20 pin adapter.
Old 04-19-2012, 09:00 PM   #16
BM3R 330
My Ride: 2002 330i
Sheesh I thinkI need to get this...
I wanna be able to program my cars features
I have a small signature
BM3R 330 is offline
Old 04-19-2012, 09:46 PM   #17
Andy2108
My Ride: SpecE46 & E46 M3
More details? I just ordered a scanner.
Andy2108 is offline
Old 04-19-2012, 09:48 PM   #18
Guest021715
Account closed.
http://forums.bimmerforums.com/forum....php?t=1622061
Old 04-19-2012, 10:03 PM   #19
Andy2108
Andy2108 is offline
Old 04-19-2012, 11:22 PM   #20
Stinger9
My Ride: '04 330Ci
Inner halogen lights are on if you have DRL's activated.
Same lights that come on if you pull back on the light stalk.
Stinger9 is offline
Closed Thread
