Thread Tools Search this Thread Rating: Thread Rating: 57 votes, 4.98 average. Display Modes
Old 02-18-2009, 01:33 AM   #61
YOnpds
My Ride: E46
Update: Replaced my sensor today. Car is back to normal! Woohoo!
Thanks everyone for the DIY.
Oh yeah, I got the sensor and "o" ring from one of our sponsors here; www.bimmersecialist.com
My part came in two days and the price for OEM BMW sensor was only $100.
YOnpds is offline   Reply With Quote
Old 04-05-2009, 05:21 PM   #62
reynaldo
My Ride: 2001 325i Sedan
Send a message via Yahoo to reynaldo
thank you for this DIY just did mine today. Very easy but take your time.
reynaldo is offline   Reply With Quote
Old 04-09-2009, 06:56 PM   #63
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Doing mine tomorrow!
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 07-14-2009, 08:30 PM   #64
aqualabs83
My Ride: 1999 323i
thanks for the info
aqualabs83 is offline   Reply With Quote
Old 10-15-2009, 07:15 AM   #65
Chris C
My Ride: 2001 325Ci
Thanks as well. I replaced my intake camshaft sensor with this DIY and it took me about 2 hours. The hardest part for me was threading the connector back to the connection for the wiring harness. I also lost (and thankfully found) the metal clip that secures the sensor's connector to the wiring harness. Don't lose those little metal clips. I called the dealer to see if I could just get a replacement clip after it slipped from my fingers while trying to reattach it to the wiring harness. The dealership told me that BMW doesn't sell the individual clips and I'd have better luck at a junk yard unless I wanted to buy a new wiring harness (yeah, right...) Anyway, I got lucky and found the clip. Just a warning to be careful with those clips...
Chris C is offline   Reply With Quote
Old 10-15-2009, 08:48 AM   #66
NicB.
My Ride: 2000 BMW 328i
I did mine a couple weekends ago. Definitely recommend tying a piece of twine to the bottom end of the CPS sensor cable and then pulling it out at the top of the engine. Then you just tie on the new one and pull the string back the other direction.
The hardest part for me was removing the VANOS solenoid. I couldn't believe how tough that sucker was to budge! Other than that, piece of cake.
NicB.
NicB. is offline   Reply With Quote
Old 10-16-2009, 06:16 PM   #67
Chris C
My Ride: 2001 325Ci
That's a great idea about using twine. I wish I had thought of that.
Old 10-31-2009, 08:20 PM   #68
Oz Striker
My Ride: '00 330Ci, '07 350Z
Can i just check that when you reinstall the Vanos that you tighten until you hear an audible click, and not to a specific torque setting?
My YouTube Channel incl Muffler delete vids: http://www.youtube.com/user/OzStryke...view_as=public
My blog on E46 DIYs & Mods http://lifewithabmw.blogspot.com/
Oz Striker is offline   Reply With Quote
Old 11-01-2009, 06:24 PM   #69
Chris C
My Ride: 2001 325Ci
I don't recall hearing an audible click when tightening it. Perhaps someone else can chime in. I just made sure is was fairly snug. I haven't had any problems.
Old 11-05-2009, 06:33 PM   #70
userml1653
My Ride: 01 325ci,740il,98 m3
where are you guys ordering it from? im not sure if i should get it from tischer or bavauto
userml1653 is offline   Reply With Quote
Old 11-06-2009, 08:00 AM   #71
NoVaDreier
My Ride: 2001 325i
Buy it from Tischer or a local dealer. BavAuto is cheaper, but it's an aftermarket part without the 2-year BMW guarantee.
NoVaDreier is offline   Reply With Quote
Old 11-24-2009, 02:48 PM   #72
Dan99
My Ride: 2001 330xi
I'm going to be doing this, this weekend.
Dan99 is offline   Reply With Quote
Old 11-24-2009, 06:20 PM   #73
Solidjake
Zero. Leaks.
Solidjake's Avatar
It's easy stuff
Old 12-01-2009, 06:43 PM   #74
Dan99
My Ride: 2001 330xi
Thanks OP!!!!
Everything went well. However there was a point when I took out my old camshaft sensor and it looks a bit different from the one I ordered from tischer, but it still fits and everything is working like a charm. I was a bit scared at first, thinking that I got the wrong one.
Old 01-12-2010, 11:34 PM   #75
dancendan
My Ride: 2001 325i
I've been having rough idle for awhile, and then periodically my car would stall taking off from a red light, then it started having a hard time starting, then the stalling got worst. Check engine light gave code PO340 which was the CPS, which is the CPS on the exhaust side (on the front of the engine block, passenger side). Took about 30-min to swap out. 5mm allen wrench needed, and there's only one bolt holding it on. Be sure to oil the new o-ring going on before pushing on. This cured my problem. No more code and driving great. I was very surprised by the power gains. I think my car has been running weak for some time now, and maybe I just started getting use to it.
dancendan is offline   Reply With Quote
Old 01-14-2010, 05:14 PM   #76
Chocolate Lab
My Ride: 2000 328i black 5-sp
I need to do this. Got the 3040 code (IIRC - Autozone code sheet is at home) and have all the symptoms of stalling and low power at takeoff, but am wary of doing this. I change the oil and do routine maintenance on mine but this seems more complicated. Is the hardest part getting the solenoid off? It looks like 5mm L-shaped allen wrenches are cheap at Harbor Freight, and I have some stiff wire to route the cable.
I dunno, for some reason I'm hesitant to do this. But my car has had this problem for a few months now.
Chocolate Lab is offline   Reply With Quote
Old 02-09-2010, 12:17 AM   #77
b_123
My Ride: BMW
Isn't P0340 for the CPS on the INTAKE side, not the EXHAUST side?
b_123 is offline   Reply With Quote
Old 02-15-2010, 09:20 PM   #78
perryjason
My Ride: BMW 330i
camshaft sensor
Just want to make sure this DIY is for my problem I'm having. I have the P0340 code as well and it goes away after two days. The car has trouble accelerating and has trouble idling sometimes as well. The code said Camshaft position sensor A - Bank 1 circuit malfunction. Is the DIY on the first page supposed to fix this problem? I just want to make sure it isn't the exhaust sensor. I plan on getting it from bavauto, part number: 12 14 1 438 081. Thanks in advance.
perryjason is offline   Reply With Quote
Old 03-14-2010, 11:11 PM   #79
leeroy74
My Ride: 2002 3251
camshaft intake sensor
Had the same issue... replaced the part with a aftermarket bilstein part #12 14 1 438 081 save me some money! My problem is the SES light is still on any thoughts on reseting the light
leeroy74 is offline   Reply With Quote
Old 03-21-2010, 11:41 PM   #80
UtahG8R
My Ride: 01 330i
Just replaced my cam sensor, much easier than it looked, the info here made it much easier. Thanks for the great write up.
UtahG8R is offline   Reply With Quote
