Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 4.88 average. Display Modes
Old 03-24-2010, 05:07 PM   #81
bobo2004
My Ride: BMW 330ci
I had a code p0369 and p0340 come up camshaft A & B after I replace one of them at same location you got, but the engine light still on. Which one is A & B. Does any one can help me out?
Thanks you very much
bobo2004 is offline   Reply With Quote
Old 06-06-2010, 02:23 PM   #82
Mteknic330ci
My Ride: Turbo E36 M3, 335i
Send a message via AIM to Mteknic330ci
I just did this, I found it was easiest to pull the sensor connector in and out with the left hand.
-Jake-
SOLD-95' 325i Lightly Modded
Mteknic330ci is offline   Reply With Quote
Old 06-22-2010, 12:52 PM   #83
wardpower
My Ride: 99' 328i Sedan
I was throwing codes P1519 and P0340 as well as a few misfire codes. Just changed my intake CPS, was easy as pie thanks to this great write up, I only had a 1-1/4 open ended wrench for the vanos solenoid but it did the trick. Seems to be running better with more torque after initial test drive. Now I gotta clear codes and see what comes back. Also does anyone know if theres a way to test the old CPS and verify that it was indeed bad?
wardpower is offline   Reply With Quote
Old 07-20-2010, 12:47 PM   #84
Capt1014
My Ride: 2002 325xi
ok so after reading a couple years worth of psots about changing out the CPS sensor, here's my question,
What indications, or issues, did you notice to suspect that the sensor needed to be changed?
Mods, Bilstein HD Struts & Shocks, H&R Springs, F1 Racing Stage 2 Clutch & Chromoly Ltw Flywheel...more to come.
Overkill is an often underrated state of achivement!
Capt1014 is offline   Reply With Quote
Old 07-20-2010, 07:33 PM   #85
325myAZ
My Ride: 2001 325i
The Check Engine Light came on. The car was very difficult to start, and ran horribly. (limp mode?) Pulled the code, and it indicated the Intake side was faulty. Replaced it with an original BMW sensor, and all is fine.
325myAZ is offline   Reply With Quote
Old 07-21-2010, 08:03 AM   #86
Capt1014
My Ride: 2002 325xi
Thanks, guess I don't have to worry bout it then.
Old 07-22-2010, 05:38 PM   #87
325myAZ
My Ride: 2001 325i
You'll KNOW when you do!!
Old 08-04-2010, 01:51 PM   #88
stapler12345
My Ride: 11 InterlagosBlue M6
I typed 12147539165 into AutohausAZ search box and it came back with 12141438081? Anyone know why?
Originally Posted by Penguin Koolaid View Post
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
Old 08-04-2010, 03:43 PM   #89
stapler12345
"Part number 12141438081 was superseded by part number 12147539165."
Old 08-05-2010, 02:08 PM   #90
Chocolate Lab
My Ride: 2000 328i black 5-sp
Okay, mine's gotten bad enough that I really need to do this now.
Are there *any* aftermarket brands that are acceptable? What about a German brand like Meyle? My car is old and I may not have it much longer, plus I'm a total rookie mechanic, so I hate to pay more than I have to. But of course I will if it's truly necessary.
Chocolate Lab is offline   Reply With Quote
Old 08-05-2010, 05:14 PM   #91
stapler12345
the lowest i found was thru Amazon, and then AutohausAZ
http://www.amazon.com/Camshaft-Posit...1046389&sr=8-2
http://www.autohausaz.com/search/pro...er=12147539165
Old 08-09-2010, 11:57 AM   #92
OrientBlau
My Ride: 2003 330i
Question Question:
After reading this thread, I'm eager to perhaps replace both of my CPS sensors too.
Is there any gain to be had from replacing if you didn't get a SES code? Or do you really only need to relace if you get a code. Car has been sluggish as of late. Doing some preventive maintenance now. New air filter and cleaning the MAF has helped. Will do O2 sensors and fuel filter next. Just wondering if the CPS is something I should add to list.
Since we're onthe tpic, how about repalcing the VANOS solenoids? Worht it for imporved performance without getting a code?
OrientBlau is offline   Reply With Quote
Old 08-16-2010, 01:57 PM   #93
mashupmark
My Ride: BMW 316i E46
All sorted now! It takes about 3 minutes to do on the 2001 316i SE.
I've made a video. I'll post it later
mashupmark is offline   Reply With Quote
Old 08-17-2010, 09:16 AM   #94
NoVaDreier
My Ride: 2001 325i
See #4 for the camshaft pulse generators.
NoVaDreier is offline   Reply With Quote
Old 08-17-2010, 02:00 PM   #95
NoVaDreier
My Ride: 2001 325i
Yes. One sensor for each camshaft.
Old 08-17-2010, 04:47 PM   #96
mashupmark
This diy not applicable to the 2001 316i SE.
You need different parts. I'll post my DIY soon Thanks for everyones help!
Old 08-20-2010, 05:07 PM   #97
mashupmark
Here you go. Takes all of 2 mins. Only need an Allen key! Enjoy my little video
Old 08-21-2010, 11:17 AM   #98
redwood77
My Ride: e46
i'm a total newb with my peake tool. i am getting code 15 followed by 12 on my 2000 328Ci. this seems to indicate table 15, code 12, which is "camshaft sensor, exhaust cam." am i reading the peake tool correctly? is this the same as the P0340 code, indicating i need to replace the CPS? am i missing something?? thanks
redwood77 is offline   Reply With Quote
Old 09-02-2010, 11:22 AM   #99
Chocolate Lab
Question, fellas... I went to the trouble to find a good used internet dealer, and I just got the part. Problem is, I think it's not OEM, which is the whole reason I got a used part to begin with.
Doesn't the OEM part have BMW on it somewhere? I guess it's possible it doesn't, but I'd think it definitely would. The part looks pretty new, so I don't think it would be a case of the logo being worn off.
Old 09-02-2010, 11:30 AM   #100
OrientBlau
My Ride: 2003 330i
What do you mean "used" internet dealer? you dont mean to buy used parts, do you?
My only advice/input is that the CPS should be OEM and new. Aftermarket brands seem to fail quickly or do not function properly.
OE = Original equipment and will have a BMW stamp.
OEM = Original Equipment Manufacturer and will be stamped with the mfgs. logo. It means that it was made by the manufacturer that made the OE.
I bought two pre-cat O2 sensors and they are Bosch. They cost $65 each andwould be considered OEM. BMW OE O2 sensors are identical but cost almost $200 each!
