Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 356 votes, 5.00 average. Display Modes
Old 03-30-2005, 09:36 AM   #21
Seth_Horwitz
My Ride: 330ci, 911 Turbo X50
Originally Posted by darkmanlfe
Yes. There is one without cutting oem amp wiring.
1. Wire splices or
2. use a copper 1 strand wire to insert in the holes of the pins and then glue gun it to secure it.
This is my setup... Flawlessly works.
Can you tell me where you got that wire? I've managed to fabricate my own by soldering resistor pins (with the resistor snipped off, obviously) to some multi stranded wire. I've looked around, but couldn't find a single strand wire that was thick enough. Thanks.
Seth_Horwitz is offline   Reply With Quote
Old 03-30-2005, 10:03 AM   #22
Canuck328i
My Ride: 09 Altima Cpe
Belden carries small rolls of solid "buss wire" of all gauges, maybe 22 or 24 gauge would work. Plus the pins would need to be larger for the speaker wire side of the connector, right?
Mark
Canuck328i is offline   Reply With Quote
Old 03-31-2005, 01:11 AM   #23
darkmanlfe
My Ride: rocket propelled 323
Send a message via AIM to darkmanlfe
I got it off Radio Shack
Albert Einstein once said - Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
darkmanlfe is offline   Reply With Quote
Old 03-31-2005, 11:59 AM   #24
Seth_Horwitz
What guage?
Old 04-01-2005, 02:21 PM   #25
Seth_Horwitz
bump
Old 04-01-2005, 02:47 PM   #26
rcurley55
My Ride: 2001 IR M3 Coupe
1. Wire splices or
Or a third way - build your own male harness - it's very very easy, I can post info a bit later....
Life's too short not to be M-Powered
rcurley55 is offline   Reply With Quote
Old 04-01-2005, 05:59 PM   #27
Seth_Horwitz
Please do.
Old 04-01-2005, 06:05 PM   #28
rcurley55
Originally Posted by Seth_Horwitz
Please do.
http://forum.e46fanatics.com/showpos...3&postcount=14
there you go
Old 04-02-2005, 05:18 PM   #29
Seth_Horwitz
Would you know which pins you used? The ones that I have are a little too flexible for what I need them to do. They work, but I'm not sure how they'll hold up long term.
Old 04-09-2005, 09:14 PM   #30
Seth_Horwitz
Bump for HDClown
Old 04-12-2005, 12:02 PM   #31
Seth_Horwitz
Mods? Sticky? You could at least return a PM.
Old 04-13-2005, 08:46 AM   #32
Hans_ACS
AC Schnitzer Fanatic
My Ride: E53 X5 3.0d
Send a message via MSN to Hans_ACS
One question, since it is not clear from the pictures : where do you connect the VEN4 to ? to the outputs of the Headunit ?
Because I expect the signal path to be as follows :
OEM Headunit speakeroutputs -> ven4 -> aftermarket amp -> speakers (connected via the speakerwires coming out of the old oem amp)
Freude am Fahren...
Hans_ACS is offline   Reply With Quote
Old 04-13-2005, 10:44 AM   #33
rcurley55
Thats how I did mine....
Old 04-17-2005, 09:30 AM   #34
Seth_Horwitz
Sticky?
Old 04-18-2005, 05:20 PM   #35
Dave
Moderator
Dave's Avatar
My Ride: 323,330,M3,M3,M3
stuck. Excellent writeup, thanks. I may try to copy this in a month or so.
Perhaps you think multi-million dollar ad campaigns make a beer taste better. Perhaps you're mouthing your words as you read this.
Dave is offline   Reply With Quote
Old 04-21-2005, 03:19 PM   #36
Canuck328i
Thanks Dave...
Mark
Old 05-14-2005, 09:46 PM   #37
Dave
Moderator
Dave's Avatar
Can anyone give a newbie to ICE a rundown on how these would differ for a sedan? I have a coupe but we'll be doing my girlfriend's 323i this summer. Seems that her non HK unit has the tweeters up near the side view mirrors, would that affect anything?
Also, what kind of useful mount points for the amp exist for those with a full service spare?
So this whole thing uses 6 speakers instead of the 10 from the factory, and still kicks ass? Pretty cool. No need whatsoever for rear door speakers?
Old 05-15-2005, 05:21 PM   #38
Pedrito
My Ride: 320d M
Ive heard that doing an OEM upgrade its no so good because like HU doesnt have rcas, amplifiers produces a lot of noise although you use a hi/low conversor. Is it true or not. Im thinking on do this but Im not sure.
sign designed by adamu77777
ACS3 2.0d
Pedrito is offline   Reply With Quote
Old 05-15-2005, 09:48 PM   #39
Seth_Horwitz
You've heard that from someone trying to sell you more equipment. First, Line Output Convertors (LOC) have come a long way. Popular ones like the Peripheral SVEN4 (as listed above) shouldn't have any noise issues if installed properly. Second, the BMW head unit DOES have an RCA output, it's just an atyical balanced signal, which the SVEN4 converts to "standard" RCA's as good as any from any other head unit. Third, try the SVEN4 route, and if that doesn't go right, you're only out $30 for the part. You can then by a new headunit and run RCA cables from the new head unit to the amps. Personally, I'd think it's worth the $30 risk, over definitly buying a new head unit and paying for labor to run RCAs to the trunk. (Plus you'd easily get $15 for the SVEN4 on these boards, so you'd only be out $15)
Old 05-15-2005, 09:56 PM   #40
Seth_Horwitz
It really shouldn't make much of a difference in components, just the techniques to take the speakers out.
You could do it on the floor of the trunk and make it liftable, mount it on either side, or hang it from the roof of the trunk. (The last one might have some critics.) It's up to you.
I'm installing the stealthboxes in my rear deck and have only removed the rear speakers. (No subs installed yet) I already think the car sounds better. There are many true audiophiles out there who never put in "rear fill" as they feel it confuses the sound stage. I'm now agreeing as I only have sound coming from the front and I think it sound s great. Can't wait for the subs and replacement speakers!
