Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
Rating:
Display Modes |
#41 |
Iīve installed a sub moved with an amplifier, for this installation Iīve tapped rear speakers wires. Signal is converted directly from the speaker wires to rcaīs by a Caliber hi/low conversor. Is Sven 4 similar to this?
I donīt understand when you say that business has "balanced signal". Signal is not taken directly from the speaker outputs of the HU?
sign designed by adamu77777 ACS3 2.0d |
#42 |
This is what Iīve installed for sub
#43 | |
In the US, though, the RCA outputs from the Head Unit are called "balanced." This is where the SVEN4 shines above the similar Line Output Convertors from Radio Shack or any other store as it "corrects" the balanced signal to an industry standard RCA. Basically, unless you're having issues with alternator whine or poor sound quality, I'd leave things the way they are. (It's a subwoofer so I'm not even sure you can hear any difference in quality.) If you are having issues, the SVEN4 might be an option if only for the reason that so many guys on this board are using it and could help you out. Good luck. (Buena Fortuna?) I haven't taken Spanish in a long time! |
#44 |
Thanks for your answers Seth.
"Buena suerte" is better. In Spain speakers came from stock HU directly. Amplifiers are in the soundmodul or HK systems. Where does balanced outputs came from. Soundsystem output? I know that in sub it doesnt matter cuality of input but I want to amplify all the speakers, thatīs why I donīt know what to do. Amplifier with speaker level inputs? ampli and HI/LO conversor? or remove HU(best cuality, no oem look) Thanks for all and excuse me for my english
#45 |
UCLA
Is the SVEN4 still recommended or the Audio Control LC6?
#46 | |
#47 |
UCLA
I guess they have slightly different applications, SVEN4 accepts balanced inputs where the LC6 does not, so the LC6 has to be fed from after the stock amp, therefor an extra box in the trunk. I'm going to go with the 2XS and run my fronts/sub off that.
#48 |
Gracias
Thanks a lot seth, thats a great post. Some of the technical stuff is a little over my head, but for someone with little idea about how it all works that was a great thing to read before making decisions for myself.
#49 | |
#50 |
Excellent post! This is exactly what I was looking for!
Now I have to go see if the pictures match my car |
#51 |
FYI on the SVEN4 or SVEN2
I went to walmart for something else even though i hate that place and noticed in their car audio section they have a standard line-level converter. The thing is, it has the same or very very similar circuitry (audio transformer, some caps, etc) as the SVEN. If someone is in a pinch, they should try this $18 part - its a 4 channel unit. |
#52 |
non-HK and Nav?
This DIY is awesome! I think I'm going to go for a sub and amp soon, but I have a non-HK and Nav system in my MY2004 M3 Coupe. How different is the install? I know the nav DVD drive and HU are in the area where this DIY shows the amp being installed. Is there a similar DIY for non-HK and Nav cars?
Thanks! |
#53 |
Thanks so much for the information. I used this last weekend and it was extremely valuable.
![]() Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI cables on a BMW board since 2005. 2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD/JL (works for me) 1968 Ford Mustang with Polk/ADS (my first car and runs strong) 2007 Lexus GS350 with every option (I loved it) 2000 BMW DINAN M5 (will be missed) 2001 BMW 330ci (will be missed) |
#54 |
can someone please tell me where to tap in for the LOC (hi-low converter)??? i know the rear speakers, but I heard you are supposed to tap in before the amp, and if this is true, what is the wiring diagram for the non-HK amp?? and just to make sure is the amp on the driver side or the passenger side?? my car is an '02 325ci (and this is just for simple a mono-subs install
#55 |
nice DIY but just wanna know, will this work with 05 ZHP, that came w/ HK + NAV ? i not to sure cause i try to install an amp for my mid and high (since i already got the bass) they say that if i add just the amp i will lost the NAV's voice? so if you can give me an wiring diagram, or a link how to. thank you
#56 |
UCLA
has anyone noticed distortion at high volumes with the stock head unit?
#57 |
thanks!
Everyone, thanks for posting. This will help me out with some things I want to do with my 03 330i. At the very least let me know what I am in for.
I replaced my stock head unit with the alpine cda-9855. So I might just go directly from the head unit and rewire. However, I may just use a similar approach. Oh and finally, thanks for sourcing the links!
[IMG]C:\Documents and Settings\BMW\My Documents\My Pictures\bmwlogo2.jpg[/IMG]
#58 | |
Banned
My Ride: Black '99 328i Sedan
#59 |
thanks!
#60 |
Burns Rubber(s)
q
