Miscellaneous
Old 03-29-2005, 09:55 AM   #1
ADA
Banned
My Ride: 323ci
Transmission Filter Kit --Brand New OEM--
Guys,
Do you need to replace your transmission filter? I just change mine and I am glad that I did. I currently have 70,000 miles on my car and my transmission fluid and filter looks dirty and had tons of metal shaving.
If you want to change your transmission filter and/or fluid this kit is perfect for you. This is the Original BMW Transmission Filter Kit. This kit comes with everything you need. It comes with a Brand New Transmission Filter. A Brand New Gasket and various bolts and nuts.
This transmission filter kit works with all E46 that uses the automatic GMW transmission (A5S 360R/390R).
It may work with other BMW models but I have had a chance to verify it with my ETK software. You can check via www.realoem.com at the following url:
http://www.realoem.com/bmw/showparts...4&fg=15&hl=107
Additional Information:
-Item Description: Transmission Filter Kit (Filter, Gasket, nuts/bolts)
-Brand: Original BMW parts
-Condition: Brand New
-Quantity: 1
-Part Number: 24-11-7-510-012
-Price: $70 (shipped) or $65 (local pickup)
-I paid $85 for it at my local dealer (w/ tax)
Pictures to follow. I will take them when I get home
Local Pickup is encouraged. I currently live in the following city:
Oakland, CA
Alameda, CA
Pinole, Ca
Fairfield, CA
After APRIL 15, you will find me in Central Texas (Waco-Austin)
ADA is offline   Reply With Quote
Old 03-30-2005, 08:49 PM   #2
ADA
Banned
My Ride: 323ci
As promised, this is the BMW OEM Transmission filter kit.
Comes with a new filter, gaskets, and bolts/nuts
Old 05-19-2005, 08:46 AM   #3
ADA
Banned
My Ride: 323ci
BUMP
or best offer
For e46 that uses the GM automatic transmission
Old 05-19-2005, 08:54 AM   #4
kevmo
kevmo's Avatar
My Ride: vDubDizzle
Send a message via AIM to kevmo
is it ez to do urself?... or how much did u pay to get it done?....
i thought u weren't suppose to change ur ATF.. thought it's "lifetime"
kevmo is offline   Reply With Quote
Old 05-19-2005, 09:18 AM   #5
ADA
Banned
My Ride: 323ci
lifetime fluid is highly debatable. There are numerous debate on this topic both on bimmerforums.com and e46fanatics.com
Changing the ATF can be a DIY. I did it myself and so did a lot of people.
Old 05-19-2005, 09:21 AM   #6
kevmo
kevmo's Avatar
My Ride: vDubDizzle
how long did it take?... did u need to lift the car? and do u happen to have a link to the diy?... i'd prob pick this up if it doesn't cost to make to change it cuz i have 92K on my car
how much total did it cost u?
Old 05-19-2005, 09:30 AM   #7
ADA
Banned
My Ride: 323ci
I paid a little under $90 for it.
yes, you can either jack your car or lift it up. It is necessary because the transmission pan is underneath your car.
Your biggest issue right now is to determine whether you have a ZF or GM transmission.
Here is a DIY. this is for the e36 but you can use this DIY as a reference. e46 is much easier to change. Same concept though. I am willing to help. It took me less than 2 hours to change my fluid. The longest part is letting the transmission cool down before draining.
http://www.pelicanparts.com/bmw/tech...Fluid_Auto.htm
Old 05-19-2005, 09:37 AM   #8
kevmo
kevmo's Avatar
My Ride: vDubDizzle
90 bucks total?.. including the ATF?.. i thought that stuff was expensive!! damn for 90 bucks.. i'll do it can't hurt after 92K miles right?
ps.. how do i find out which type of fluid i have?
Old 06-05-2005, 12:54 AM   #9
Mikygunz
My Ride: '01 330ci
i dont think it includes the atf........regardless, is this still available?
Mikygunz is offline   Reply With Quote
Old 06-05-2005, 03:54 AM   #10
ADA
Banned
My Ride: 323ci
yes it is =)
