Old 08-25-2002, 09:11 PM   #1
samir@technik
samir@technikpower.com
My Ride: 335/330/M3
GruppeM Intake functionality explained...
Sorry for delaying to address this (my digicam broke and I couldn't take pics)...
Originally posted by valerie
It sounds like you enjoyed the sound, but any idea how much air it moves? The headlight assemblies on our cars are very well sealed (rubber seals around the lights and the bumper) - so I'm unclear how its jamming air into the engine. I think (but could be wrong) that the tube aspect of the Dinan and the angle have something to do with airflow and I want to know how exactly this one works to maximize the CAI to the engine in its way...
With the intake removed the engine bay has a straight intake "port" from the fog housing/brake duct area. The GruppeM heat shield is specifically shaped to take advantage of this port by collecting the air as the car is in motion...
in addition to the pressure area around the inner edge of the headlight and driver-side kidney grill...albeit most of the air is collected from the fog housing, additional CFM is generated by the headlight area, which only helps to make more power. The factory intake has a port just for this area as well.
Factory airbox...
Lastly, the heat shield is further cooled by the kidney vent...
The E46 intake system includes the following...
Any questions, please feel free to email me or respond to this thread. I have extended the GB by 3 days till Wednesday.
samir@renn-sport.net
samir@technik is offline   Reply With Quote
Old 08-25-2002, 09:22 PM   #2
Nics
My Ride: Cooper S
damn! too bad I cant afford that intake now, even at GB rates
Someone wanna buy me an intake?
Nics is offline   Reply With Quote
Old 08-25-2002, 09:28 PM   #3
samir@technik
My Ride: 335/330/M3
One more pic of the intake installed (I chose not to install the optional mount bracket, since it was an eyesore to me...doesn't affect the MAF sensor).
Old 08-25-2002, 09:31 PM   #4
CrazyBimmer
Manwhore
My Ride: 09 M3 Sedan
Send a message via AIM to CrazyBimmer
Send ya a Email.
-Jesal
You take Credit card.. correct?
CrazyBimmer is offline   Reply With Quote
Old 08-25-2002, 09:37 PM   #5
Orient Blue 3
I know all about that...
Orient Blue 3's Avatar
My Ride: 08 335i Coupe
Send a message via AIM to Orient Blue 3
You think companies like GruppeM would make the rubber sleeve black. ECIS put a black tape around it. Why not just produce it black? It kinda ruins the visual effect with the blue ring IMHO. But if I'm not mistaken they are available at hardware stores right?
Orient Blue 3 is offline   Reply With Quote
Old 08-25-2002, 09:41 PM   #6
CrazyBimmer
Manwhore
I acutally like the blue ring...
This is the only intake i like besides the Dinan one... and one thing that worries me about dinan is that its closer to the ground... and with gruppeM I wont have to worry about Hydrolocking.
Old 08-25-2002, 09:44 PM   #7
Orient Blue 3
I'd buy it if I wasn't on my 2nd intake already.
Old 08-25-2002, 09:45 PM   #8
KevinJ_2k1_325ci
My Ride: 2001 325ci
It may be a question of heat rating.
I was looking around for intake tubing and I found that better rated tubing came in odd colors. However there are some silicone tubing manufacturers that just do show stuff and produce many colors but aren't necessarily high quality couplers and hose.
This isnt hardware store stuff, you want a couple that will last and not crack over time from the heat and wont take on to much heat and heat the air entering the intake track.
KevinJ_2k1_325ci is offline   Reply With Quote
Old 08-25-2002, 09:49 PM   #9
Orient Blue 3
Re: It may be a question of heat rating.
Thanks, i never really thought about that but you think they'd come up with a way to make an effective one that looks purdy.
Old 08-25-2002, 09:54 PM   #10
CrazyBimmer
Manwhore
Which has a deeper sound to it.... Dinan or Gruppe??
Old 08-25-2002, 09:54 PM   #11
samir@technik
My Ride: 335/330/M3
GruppeM also makes intakes for the following cars...
F355
360 Modena
512
996 GT3
996 Twin Turbo
E55
Nissan Skyline GT-R
RX-7 FD3S
And superchargers for the...
NSX
Old 08-25-2002, 09:54 PM   #12
navidbmw330ci
TPS Report Coverer
My Ride: 01 330ci
Forgive my ignorance, but couldn't you just paint the blue part in any different color with the right kind of paint? (I forget the name, but the spray paint that has high heat tolerance) Or would this compromise the part?
navidbmw330ci is offline   Reply With Quote
Old 08-25-2002, 09:54 PM   #13
jAb
I've got cool scars
jAb's Avatar
My Ride: 09 335i & 00 328Ci
only questions i have are.....
1) how are the numbers compared to the usual suspects (dinan, ecis)?
2) how is the sound compared to them
3) do you still have my address or do you need it so you can send me an evaluation unit?
jAb is offline   Reply With Quote
Old 08-25-2002, 09:54 PM   #14
samir@technik
My Ride: 335/330/M3
I have heard both...definitely the GruppeM.
Old 08-25-2002, 09:56 PM   #15
Orient Blue 3
JAb so a search for the dyno Samir posted.
Old 08-25-2002, 09:57 PM   #16
jAb
I've got cool scars
jAb's Avatar
also how do you pronounce gruppe?
grup.... group... ???
Old 08-25-2002, 09:59 PM   #17
samir@technik
My Ride: 335/330/M3
Expect +4% HP and +5% Torque.
330 Dyno (crank figures are in parenthesis)
Will have a sound clip shortly...
No
Old 08-25-2002, 10:10 PM   #18
KevinJ_2k1_325ci
My Ride: 2001 325ci
Re: Re: It may be a question of heat rating.
Check with summit racing, you can find header wrap. I know I saw it in white and black before. Usually the tape is used for headers but should work nicely to cover the blue.
The best covering for a couple was on a NSX air intake. The coupler was red with fish net on top. You cant get any sexier than that.
Old 08-25-2002, 10:14 PM   #19
gdoan
My Ride: '16 F22 M235i
Question Samir?
How do I participate in the group buy and what kind of warranty does the intake have?
Greg
BMW CCA #168184
gdoan is offline   Reply With Quote
Old 08-25-2002, 10:16 PM   #20
MCD007
Im The Man
My Ride: 325ci
Send a message via AIM to MCD007
Does this intake become useless if I get an SC??
MCD007 is offline   Reply With Quote
