///M3 Forum
Old 04-26-2005, 07:36 PM   #1
xkrnxnamjahx
My Ride: E46 M3
Exclamation Tire Pressure
I just set mine at 38 front and 40 rear
i have 2003 BMW M3 with SMG transmission, 18'' stock OEM rims with Michelin pilot sports tires.
I just installed a system in the back (200 lbs)
and i have usually 2 - 3 people in my car.
What's the best tire pressure? or is 38 front and 40 rear perfect for my car?
xkrnxnamjahx is offline   Reply With Quote
Old 04-26-2005, 09:33 PM   #2
bengwie
My Ride: 2004 M3 Coupe
should be inside the manual,
I have 19 inch OEM rims, and I set mine 33 front and 35 rear. Should be in the manual, but I forgot for your rim's size.
2003 330i sold
2004 ///M3 sold
bengwie is offline   Reply With Quote
Old 04-27-2005, 12:35 AM   #3
gpoints
My Ride: 2003.5 M3
That's what I'm running with OEM 19's...
gpoints is offline   Reply With Quote
Old 04-27-2005, 05:15 AM   #4
DXBBimmer
My Ride: A330 + '03 M3
its all in the manual... READ!
DXBBimmer is offline   Reply With Quote
Old 04-27-2005, 06:51 AM   #5
///M3Pilot19
My Ride: 2004 M3 SMG
Send a message via AIM to ///M3Pilot19
seriously I think some people just wait on this board to say "READ THE MANUAL!!" or SEARCH. Yea, the manual has recommended tire pressure for OEM wheels.. I'm quite sure alot of people experiment and try different setups. For the record I try to keep my 19s at 37fr 39rear.
-Kevin
2004 ///M3
Alpine White/Black SMG SOLD
2003.5 ///M3
Carbon Black/Cinnamon 6MT SOLD!!
///M3Pilot19 is offline   Reply With Quote
Old 04-27-2005, 09:03 AM   #6
Amalfi
My Ride: BMW
Is that the pressure you used to run with your 68M wheels when you had the 330?
The manual for my car (330) says 32F/38R, but I've found 34F/36R to be a good compromise between comfort, handling & wear. The rears seemed to be wearing too much in the middle at 38R and the fronts just seemed a little low at 32F.
I'm surprised at 33F/35R for the 19's, I would think that's too low for protecting the rims from bends, but I don't have them so
Amalfi is offline   Reply With Quote
Old 04-27-2005, 11:43 AM   #7
BlackE46M3
My Ride: 2002 M3
I run mine about 37 all the way around and tire wear has been great but I am going to experiment with 38 rear/36 Front and see how that works out. Probably not that much of a difference.
When I autocrossed the car last weekend I had them cranked up to 45 all around!
photos.yahoo.com/DaveYZF
2002 M3 6 Speed
19" SSR GT3 Wheels
More to come...
BlackE46M3 is offline   Reply With Quote
Old 04-27-2005, 11:57 AM   #8
xkrnxnamjahx
My Ride: E46 M3
umm i know what the OEM recommended tire pressure is. I was just looking for the ride + comfort, or any other combination.
Old 04-27-2005, 10:55 PM   #9
SpinHouse247
My Ride: 2001 525iT
Send a message via AIM to SpinHouse247
What is your driving style? I typically drive agressive and tend to keep my rears 2psi less than the book. Fronts are usually kept at the recommended rate. This has essentially been the same for all of my BMW's and been a pretty good setup for my style of driving.
SpinHouse247 is offline   Reply With Quote
Old 09-12-2009, 12:24 AM   #10
Amuse M3
My Ride: 2003 BMW M3
41/48
Do not know, I set mine at 41 front 48 in the back, great performance, but not sure it is too high?
Amuse M3 is offline   Reply With Quote
Old 09-12-2009, 07:33 AM   #11
WytLytnyn
My Ride: 2005 M3 6MT
Seems pretty high to me. I run 36psi all around on OEM 19's.
WytLytnyn is offline   Reply With Quote
Old 09-14-2009, 12:06 AM   #12
2003 bmw m3
My Ride: 2003 M3 tiag vert
yo i have 19''s and i run 31/36 because i don't usually carry more than 2 people, its all about the weight i think more people more psi.
2003 bmw m3 is offline   Reply With Quote
Old 09-14-2009, 12:09 AM   #13
kuksul08
My Ride: M3
It depends if you're carrying a lot of people and luggage or not. Since only half the time I have passengers, I put it in the middle... about 34 front, 38 rear. Seems to work fine...
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 09-14-2009, 03:57 PM   #14
daleatty
My Ride: 2003 M3 convertible
Mine have been set at 36F and 38R for a while. Seems to work well. I have not noticed any bad tire wear (PS1's on stock 18s).
daleatty is offline   Reply With Quote
Old 09-14-2009, 08:46 PM   #15
Alan
Alan's Avatar
My Ride: 2006 M3
Borrow a pyrometer and check inside, center and ourside tread temperatures immediately after a typical trip with typical load. Raise or lower pressures to achieve a balanced temperature across these three tread zones. There is no pat answer to your question where one answer fits all uses and styles of driving.
Alan is offline   Reply With Quote
Old 09-14-2009, 08:49 PM   #16
Blacke46bmws
My Ride: black 2001 330i
plan driving thats fine, if ur tracking the car aroud 43 pounds all round
<-----454 Big Block Chevy,Cams Racing Headers Dominator 1000CFM carb Chevy 12 bolt posy diff Roll cage Tubbed 16" Slicks 560 HP--->1973 Pontiac astro
Codename: WD40
Blacke46bmws is offline   Reply With Quote
